wavemaker on port 6 problem
Reefology
Post by Reefology »
wondering if someone can tell me why my code compiles but wavemaker on port 6 never comes on?
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    // Password Protection username:xxx password:xxx
    // ReefAngel.Network.WifiAuthentication("xxx:xxx");
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.WavemakerRandom( Port5,120,1500 );
    ReefAngel.WavemakerRandom( Port6,180,1000 );
    ReefAngel.DCPump.ActinicChannel = Sync; // Now pump will be affected by the portal settings
    // Remove next 2 lines for single dc pump
    // ReefAngel.DCPump.DaylightChannel = AntiSync; // Now pump will be affected by the portal settings
    // ReefAngel.DCPump.AntiSyncOffset=100;
  // Wavemaker Koralia night mode
    if (hour()>=23 || hour()<8) ReefAngel.Relay.Off (Port6);
  // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%600==0 || changeMode==true) { // Change every 10 (600seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<1800) {
    // Continue NutrientTranspot Mode for 30 minutes
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=30;
    ReefAngel.Portal( "Reefology" );
    ReefAngel.DDNS("xxx"); // Your DDNS is Reefology-xxx.myreefangel.com
Re: wavemaker on port 6 problem
Try changing this:
To this:
    ReefAngel.WavemakerRandom1( Port5,120,1500 );
    ReefAngel.WavemakerRandom2( Port6,180,1000 );
Reefology
Post by Reefology »
Will try it...thank you sir!
on another note Roberto, I sent you a pm regarding my DDNS and didn't hear back. Can you please respond when you have a moment?
Sorry, yeah, I tested and it worked for me
