RA Net with Relay doesn't seem to be working correctly.
I just set up the RA Net and Rely that I got several months ago and it doesn't seem to be working right.
The logo on the Relay is pulsing between White and off about every second.
I have port 8 set to be on all the time, but when I test the ports the only one that is getting power is what I would consider Port 7 with the logo and imprinting in the upright position.
When I try to turn the port off from the Adriod App nothing happens.
The only light on the RA Net board in the head unit is the bottom right (the one that is blinking in Roberto's video, but mine is steady).
[youtube]http://www.youtube.com/watch?v=JMBARknej_Y[/youtube]
Re: RA Net with Relay doesn't seem to be working correctly.
I have been using the wireless relay for quite some time now. What happens is , it loses connectivity with the head unit on and off. I have sent a PM to Roberto about this. I hope he has some solution for this.
Thanks.
I'm going to double check my dip switches when I get home,but I don't think that is the issue.
If it was the unit would still sync with the head unit, but not control anything.
It looks like I'm not syncing.
I think the port7 on is remaining of the test I performed in the box.
It was set as fallback.
This was the code I used:
#include <SoftwareSerial.h>
//Box1_Port1
ReefAngel.Init();
ReefAngel.Use2014Screen();
ReefAngel.Relay.RANetFallBackE[0]=Port7Bit;
ReefAngel.AddRANet();
ReefAngel.Relay.Set(Box1_Port1,now()%6<3);
ReefAngel.PWM.SetChannel(0,(byte)(100*(now()%9<3?1:0)));
ReefAngel.PWM.SetChannel(1,(byte)(100*((now()%9<6)&&(now()%9>=3)?1:0)));
ReefAngel.PWM.SetChannel(2,(byte)(100*(now()%9>=6?1:0)));
Does the fallback get set in the Relay, because I've never had this code on my unit?
That still doesn't explain why it's not connecting.
Am I right that it's not connected with the logo pulsing between whit and off every second or so?
The fall back ports get saved in internal memory of the relay box.
It needs to store it in case of power failure.
You are correct. I think it is not even syncing.
Did you have add the RANet feature to your code?
I check that too.
So the line of code for the RA NEt would be this...
I don't think I ever added that.
that! and there's some file attached in one of these threads that you need to manually paste in your arduino folderSacohen wrote:So the line of code for the RA NEt would be this...
I don't think I ever added that.Code: Select all
Thank you bencollinz.
My laptop died over the weekend so I need to try and get it working again or use another system in my house.
Hopefully I can pull my latest code of the drive in the laptop at least.
I think what I have under INO/PDE may be a little out of date, but not much.
my code to show you the ranet placement
#define Heater 1
#define Return 2
#define 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
#define Sump Light 8
byte vtechmode, vtSpeed, vtDuration;
ReefAngel.FeedingModePorts = Port2Bit;
// ReefAngel.FeedingModePortsE[0] = 0;
// ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
// ReefAngel.WaterChangePortsE[0] = 0;
// ReefAngel.LightsOnPorts = 0;
// ReefAngel.LightsOnPortsE[0] = 0;
// ReefAngel.OverheatShutoffPortsE[0] = 0;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
// ReefAngel.SalMax=3300; // 35ppt
vtechmode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
static unsigned long feeding;
ReefAngel.StandardHeater( Port1,778,782 );
ReefAngel.WaterLevelATO( Port7,180,71,74 );
ReefAngel.StandardLights( Port8,15,0,2,0 );
// ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //LIME
ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,21,00,15,90,30,0) ); //RB
ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,50,30,0) ); //WHITE
ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN
ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (now() % 10800 == 0 ) while(1);
if (hour() >=13 && hour() < 20)
// if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
// ReefAngel.RF.SetMode(ReefCrest,60,20);
feeding=now();
if (now()-feeding<5400) {
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,75,10);
ReefAngel.RF.SetMode(Constant,10,0);
if (vtechmode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtechmode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
ReefAngel.Portal( "bencollinz" );
char text[7];
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
ReefAngel.LCD.Clear(255,59,29,128,39);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
// water level
ReefAngel.LCD.DrawText(0,255,68,58,"WL");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
Yes Thanks. I saw that in the code Roberto posted earlier.
Thank you. Thank worked. The wireless relay works as it should now,
It was all working properly. (I really have nothing programmed on it yet, but it was on ans working.)
I unplugged the multi strip I had the Relay plugged into and when I plugged it directly into the outlet it would not reconnect.
I rebooted and still not connection. not even the white blinking light I had before. no light on the logo at all.
I set the fallback to port 8 as on and uploaded the new code and still nothing.
Why would it not reconnect after it lost power for about 3 seconds?
Can you check the red switch on top?
Does it light up when you switch to on?
Never noticed a red switch on top or are you talking about the one on the face between the 2 rows of outlets and just to the left of the logo?
That one lights up.
Sometime last night the unit gained sync. The logo is a bluish/white, but no reaction to the portal or App any more.
I added ReefAngel.Relay.RANetFallBackE[0]=Port8Bit; to my code to leave port 8 on as a fallback.
That shouldn't effect anything, should it?
That one lights up.
Yes, that switch.
So, if the unit is fading blue/white, it's connected to the head unit.
Flashing white is not connected.
Is port 8 turned on?
The power switch is illuminated red.
The logo doesn't look like it's fading. It seems to be a consistent bluish/white, maybe it's just my perception of the color.
No Port 8 is not on.
No. Port 7 & 8 are definitely not on.
I'm not sure about any other ports, but nothing except port 8 should be on.
Are all the dip switches in the up position?
I will double check, but I would think so since it did work properly the day before.
Everything was fine until In unplugged it from the multi-strip and plugged it directly into the wall.
I tried plugging it back into the multi-strip and things are still not working correctly.
Also, disconnect the RANet Add-On from the head unit or turn it off for more than 10 seconds. Does the relay box blink white?
No problem. I'll check it tonight.
Can I disconnect and reconnect the RANet module from the head unit without powering it off and not hurt anything?
LED on relay unit when Head unit is off.
http://m.youtube.com/watch?v=_B5bL2K3giop
LED on relay unit when Head unit is on but not in sync.
http://m.youtube.com/watch?v=067azYoRu74
davaraj your videos are in private mode.
I just changed the settings to public. Hope the vides are visible nowSacohen wrote:davaraj your videos are in private mode.
Roberto;
The dip switches are all up.
I unplugged the serial cable from the head unit and left it off for 30 seconds or so and the logo did not flash. It stayed solid white.
Sometime during the day Port 8 decided to go back to the on state, but I still can not turn any ports on or off from the Portal or Andriod App.
Yes the videos work now.davaraj wrote:I just changed the settings to public. Hope the vides are visible nowSacohen wrote:davaraj your videos are in private mode.
At first my led logo did do a slow flash of white to off and then it came on full and stayed on.
As I said above the logo did not go out or flash when I shut down the RA head until for about 30 seconds, it just stayed on solid.
