#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1,20 );
ReefAngel.StandardLights( Port3,18,0,10,0 );
ReefAngel.StandardHeater( Port7);
ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,21,0,5,55,180,5) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(7,5,21,5,5,45,180,5) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(7,10,21,10,5,55,180,5) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(7,15,21,15,5,45,180,5) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(7,20,21,20,5,55,180,5) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(7,25,21,25,5,45,180,5) );
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
ReefAngel.PWM.SetActinic( ElseMode(70,30,false )); // ElseMode on anti-sync mode, 70 +/- 30%
ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+70,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+108, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+70,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+108, y+20,1);
char buf[16];
// Temp and PH
y+=10;
ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+5, y+12, buf, Num8x16);
ReefAngel.LCD.DrawLargeText(T3TempColor, DefaultBGColor, x+40, y+12, buf, Num8x16);
y+=5;
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,10,18, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,33,18, 10 );
int t=x;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
custom code errors
custom code errors
I just got a second dosing pump and was going to set it up. when I tried to load my code it gave me an error, so I ran my last code that I have currently set up on my system and it also gave me an error yet it is currently running my system. when I run just he basic wizard set up it runs fine without errors. I have a custom screen code that seems to be causing the errors ( I think) that never occurred before. did something change with the software that would stop me from using my current custom screen coding?
Re: custom code errors
Take out the ElseMode function at the bottom. It's in the libraries now. If still getting errors post the error your getting
which else mode part are you talking about?
this is the code im trying to load
Dimming Expansion Module
Dimming Signal
Salinity Expansion Module
Wifi Attachment
Custom Main Screen
Extra Font - Numbers Only - Large Font (8x16 pixels)
DC Pump Control (Jebao/Tunze)
Simple Menu
Globals\Globals.cpp.o: In function `ElseMode(unsigned char, unsigned char, unsigned char)':
C:\Users\christina\Documents\Arduino\libraries\Globals/Globals.cpp:881: multiple definition of `ElseMode(unsigned char, unsigned char, unsigned char)'
sketch_07FEB15.cpp.o:C:\Users\CHRIST~1\AppData\Local\Temp\build5625720558528318428.tmp/sketch_07FEB15.cpp:187: first defined here
c:/program files (x86)/reef angel controller/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
this is the error I get#include <ReefAngel_Features.h>
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.StandardATO( Port1,30 );
ReefAngel.DosingPumpRepeat( Port3,15,360,2 );
ReefAngel.DosingPumpRepeat( Port4,15,360,5 );
ReefAngel.StandardHeater( Port7,770,775 );
char buf[16];
char buf[16];
// Temp and PH
y+=10;
y+=5;
int t=x;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
There is an entire ElseMode function at the end of your code.
That entire function is now part of the libraries. You should remove it from your code or it will complain about being duplicated.
is this what your talking about?
or should I remove everything in the code that says else?
ok got it. will my jeabos still function without that code? or was that competing against another code for controlling them?
Yes, they will. Like we said before, it has been added as part of the libraries and you don't need to explicit declare it in your code anymore.
Our libraries is ever evolving and codes that people use, try it and like it becomes eventually part of the libraries, so it makes it easy for everyone to use without having to add additional stuff to their code.
This is a example of such thing.
A user created this ElseMode function that has been adopted by several users and everyone liked. I went ahead and made it integral part of the libraries so everyone can use it too without having to add anything to their code and the Wizard is now capable of setting the DC Pumps to Else mode
Ok well I loaded the code without the else mode in there but my one jeabo is only pushing at 30% and the other one is off
According to your code, you didn't set any mode to your DC Pumps.
I recommend you updating your code to utilize the new libraries and remove the PWM class you are using now.
Change this:
To this:
Or to this if you want to control from phone app or portal:
Change this:
ReefAngel.DCPump.SetMode( Else,70,30 );
