If you plan to use the Development libraries (recommended for more functionality), you will need a lot more includes in the PDE file. So the equivalent to the code you provided would be:
// this next line only needed if you plan on doing any USB or WIFI communications
// so if you are going to use Client Suite, you need this line
//#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
