Lights On override and Dimmer expansion module
dedvalson
Post by dedvalson »
Hi,
I was going to write some custom code for this, but I wanted to see if there is something standard for it already. If there is I haven't been able to find it.
I don't have any relays related to lighting. All of my lighting is controlled strictly from the 6 channel dimming expansion module (I use all 6 channels for Lighting).
I need the "LightsOn" override to turn these 6 dimming channels to some preset values, overriding what is being done by the normal code loop.
I can see how I could easily do this by checking for the override in my main loop, but I wondered if there was something built in for this.
Don
Re: Lights On override and Dimmer expansion module
I'm not sure if there is or not, but it's something I will need too, so I'm following along to see what comes up.
This is only available for the standard channels. You will need to code for the dimming channels.
joshlawless
Post by joshlawless »
Is there a way to check, in the code, whether the LightsOn mode is active?
Something like:
If ReefAngel.AreLightsOn() {ReefAngel.PWM.Set16ChannelRaw( 0, 4095)}
else {ReefAngel.PWM.Set16ChannelRaw( 0, PWMSmoothRampHighestRes( 7, 15, 22, 00, 0, 4095, 130, 0 ) );}
joshlawless
Looks like I found it (pasting here for posterity):
    if (bitRead(ReefAngel.StatusFlags,LightsOnFlag))
