On the LAN page, I can only see the Relay expansion box, and not the main relay box.
I've added the water level expansion in my code, and expect to see a single water level data point, but the local (and, for that matter, remote) portal shows 5 channels of water level data (I only have the single water level expansion).
I see a section labeled "Ecotech Vortech" in addition to the section labeled "DC Pump" -- not sure why. No reference in my INO to Vortech.
Any input is much appreciated!
Here's my test code (not up and running yet):
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit;
ReefAngel.WaterChangePortsE[0] = Port4Bit;
ReefAngel.CustomLabels[0]="Heater1";
ReefAngel.CustomLabels[1]="Heater2";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Neck Wipe";
ReefAngel.CustomLabels[4]="Refugium Light";
ReefAngel.CustomLabels[5]="Filters";
ReefAngel.CustomLabels[6]="Ozone";
ReefAngel.CustomLabels[7]="Air Pump";
ReefAngel.CustomLabels[8]="Circulation";
ReefAngel.CustomLabels[9]="Diverter";
ReefAngel.CustomLabels[10]="Kalk Stirrer";
ReefAngel.CustomLabels[11]="ATO Pump";
ReefAngel.StandardHeater( Port2 );
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.DosingPumpRepeat2( Box1_Port3 );
ReefAngel.WaterLevelATO( Box1_Port4 );
if (ReefAngel.Params.ORP>450) ReefAngel.Relay.Off(Port7);
if (ReefAngel.Params.ORP<400 && ReefAngel.Params.ORP>0) ReefAngel.Relay.On(Port7);
