RA+ upgrade board + old LCD not working
duck
Post by duck »
I installed the upgrade board today and swapped the LCD to the new board. I uploaded the old code to get the tank up and running. Everything works except the LCD is dark but it looks like the backlight is on and stays on. Is there anything I could try to get my screen back up? Here is my old code.
    byte ActinicPWMValue=0;
    byte DaylightPWMValue=0;
    //Return              1
    //Blue LED and Fans   2
    //White LED           3
    //Alk                 4
    //Powerhead           5
    //Heater              6
    #define ATO           7
    //Skimmer             8
      ReefAngel.PHMin=200;
    ReefAngel.PHMax=807;
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
      ReefAngel.StandardLights( Port2, 10,0,21,0 );
      ReefAngel.StandardLights( Port3,12,0,20,0 );
      ReefAngel.StandardHeater( Port6,760,777 );
      ActinicPWMValue=PWMSlope(10,00,21,00,12,80,12,ActinicPWMValue);
      DaylightPWMValue=PWMSlope(12,00,20,00,12,35,12,DaylightPWMValue);
      CheckCloud();
      //Alk Dosing Pump 1 Minute Every 45 Minutes
      if (now()%2700<60) ReefAngel.Relay.On(Port4); else ReefAngel.Relay.Off(Port4);
      //Powerhead On Every 4 Hours With 30 Min Pause
      if (now()%1800<12600) ReefAngel.Relay.On(Port5); else ReefAngel.Relay.Off(Port5);
      ReefAngel.SingleATO(true,ATO,300,0);
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 11
    #define Min_Clouds_per_Day 6
    #define Max_Clouds_per_Day 17
    #define Start_Cloud_After NumMins(12,30)
    #define End_Cloud_Before NumMins(19,30)
    #define Lightning_Change_per_Cloud 93
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
    #ifdef forcecloudcalculation
        if (cloudchance==255)
    #else
    #endif
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
            else lightningstatus=0;
            if (lightningstatus)
              DaylightPWMValue=100;
              ActinicPWMValue=100;
              DaylightPWMValue=0;
              ActinicPWMValue=0;
            delay(1);
          cloudindex++;
          if (cloudindex < numclouds)
          int x=0;
        if (lightningchance)
          int x=0;
      cstart*=60;
      cend*=60;
      if (n>cend) return PWMStart;
Re: RA+ upgrade board + old LCD not working
Add this to your setup() right before ReefAngel.Init()
  InternalMemory.LCDID_write(255);
duck
Post by duck »
Hey thanks alot, works perfect!
