Can someone tell my why my lights aren't working?
MDB1029
Post by MDB1029 »
Just got the dimming expansion today and hooked everything up, loaded my code and my lights won't come on.
my whites are on channel 0 and my blues are on channel 1
int DaylightPWMValue=0;        // For cloud code
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardLights( Port7,18,0,10,0 );
    ReefAngel.DayLights( Box1_Port1 );
    ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
    DaylightPWMValue=PWMSlopeHighRes(9,30,21,0,0,30,60,0);
 CheckCloud();
 ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue);
    ReefAngel.Relay.Set(Port8, now()%21600<10800);
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 18
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
    #define Start_Cloud_After NumMins(11,00)
    #define End_Cloud_Before NumMins(20,00)
      // Add Random Lightning modes
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
              // Send the trigger
              Strike();
            break;
          case Mega2:
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
          int x=0;
          else x=17;
          else x=35;
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          else x=57;
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          else x=75;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
I would really appreciate any help you can give me
Re: Can someone tell my why my lights aren't working?
First of all are you sure that your lights are able to be controlled by a third party controller?
What kind of lights are they?
What are on Port 7 and Box 1 Port 1, they are listed as lighting too?
Have the lights ever worked on the Dimming module or the PWM ports on the Relay?
I would remove all the code for the cloud and Lightning and get the lights working first them once they are working and set to the time you want go back in and add the cloud and Lightning code.
MDB1029
Post by MDB1029 »
Sacohen wrote:First of all are you sure that your lights are able to be controlled by a third party controller?
They are DIY I switched to LDD drivers from ELN drivers with this switch so they have been controlled by the RA for 6 months now just through the relay which doesn't support 0-5v.
Port 7 is my fuge light and not sure why but it always lists box1 port 1. I feel this is the problem but have been tinkering with it for an hour now and can't figure out how to make port 7 come on at 6pm and go off at 10am so i can
remove those lines. Some assistance on that would be great.
I am in the process of giving this last bit a whirl.
MDB1029
Post by MDB1029 »
    ReefAngel.PWM.Channel0PWMSlope();
Still no lights
MDB1029
Post by MDB1029 »
So I got the lights on and it seems they are on at the right percentage but i am unable to change the percentage they are running any thoughts?
Where are you trying to change the percentage that they are running?
You can't change the percentage from the Portal unless you have them set to the internal memory, which it doesn't look like you do.
They can only controlled by the Android app and possibly the U-App (I'm really not familiar with the U-App).
MDB1029
Post by MDB1029 »
i am trying to change it with the android app
You need to hold the selection for about 10 seconds and then a slider will come up that you change and then accept.
MDB1029
Post by MDB1029 »
right it takes the adjustment but it doesn't actually change
MDB1029
Post by MDB1029 »
So, they are on. Not sure what percentage they are at but they definitely are not ramping down for when they are supposed to turn off.
I'm having the same issue with my lights that I'm setting up now.
From what I've been able to determine is if the lights are on, but not full power there is either a reversed or bad ground.
I hope this helps.
MDB1029
Post by MDB1029 »
Can you help me out with what a reversed ground is? What i need to look at for that?
Basically the + of the RA dimming module is going to the - of the lights and the - of the RA is going to the + of the lights rather than + to + and - to - as it should.
A bad ground would be they are connected correctly, but there is a bad solder or connection and the circuit is not complete.
MDB1029
Post by MDB1029 »
Thank you, i will check those things.
Is it dim at a constant level?
Like 50% and won't go higher or lower.
I'm guessing a reversed + -.
MDB1029
Post by MDB1029 »
It doesn't look like it is reversed unless i can't read the manual for the dimming expansion. Left side is the + terminals and the right 3 are the -?
That's correct.
It's hard to tell without knowing your memory values. Let's re-write the code with hard coded values. What are the times you want each to run, and what are the percentages (low and high) you want to use?
MDB1029
Post by MDB1029 »
cosmith71 wrote:It's hard to tell without knowing your memory values. Let's re-write the code with hard coded values. What are the times you want each to run, and what are the percentages (low and high) you want to use?
I would like the whites to run from 10am to 8pm they are on channel 0, i am acclimating to the new power of the lights so i am wanting the low for them 0% and high 30%.
Blues can start and end 30 minutes longer on each end and I wanted to try them at 5% low and 30% high.
I also can't seem to add my fuge lights in here which are on port 7 and i want them running from 6 pm to 10am if you could help me out with that as well.
I appreciate your help
Try this. Note that the PWMParabola is going to ramp up much slower than PWMSlope, so your blues will ramp up slower.
  ReefAngel.PWM.SetChannel(0,PWMSlope(10,0,20,0,0,30,60,0));  // Whites from 1000 to 2200 with a 60 minute ramp
  ReefAngel.PWM.SetChannel(1,PWMParabola(9,30,20,30,5,30,0));  // Blues from 0930 to 2230 on a parabola
  ReefAngel.StandardLights(Port7,18,0,10,0);  // Fuge light from 1800 to 1000
Once we get the lights working at the most basic level we can work on the extras.
MDB1029
Post by MDB1029 »
I am going to add and upload this now. With the code this way, will I be able to change the %s from the internal memory or the app?
MDB1029
Post by MDB1029 »
Is this missing a 0 at the end of the blue channel?
I don't believe so. PWMParabola takes one less argument than PWMSlope.
MDB1029
Post by MDB1029 »
I have this uploaded with the change. I know it doesn't change with the app but not sure if it will or not. I won't know if it is working correctly until i drive on my street after work and see the lights on or not.
You should be able to override the percentage with the app. Go to the "Dimming" page and long press the value to bring up a slider. Make sure it's the dimming page that show all 6 channels and not the main "controller" page that has temps, pH, etc on it.
If you want to use the memory locations to change max brightness, times, etc. then it won't work. Lets get the basics first and then we can do that.
MDB1029
Post by MDB1029 »
So the lights were shining down the street when i turned the corner at 15 past midnight. So still not working properly.
With the wiring, I have channel 0 going to 2 drivers which go to my white lights and channel 1 also goes to 2 drivers which go to my blue lights. Would this have some effect on why this is not working? I have checked over all the wiring and can't find anything wrong with it, not saying i am not missing something though.
2 drivers shouldn't be a problem. Up until recently I was running 4 per channel.
I think there is a hardware problem.
Do you have a voltmeter? Can you check the voltage across your PWM outputs on the dimming expansion? Need to know the voltage between channel 0 and ground, and channel 1 and ground, and the percentage they're supposed to be running at.
MDB1029
Post by MDB1029 »
Channel 0 - 11.9 v dc at 16%
Channel 1 - 11.12 v dc at 30%
This is on the 20V DC setting
Did you check on the dimming expansion? Should be less than 5v.
That doesn't seem correct.
First of all are you sure you have the jumpers on the dimming module set to 0-5v becuase you shouldn't be getting 11v out of it if you do.
Second of all 30% of 12v is 3.6v not 11.12v and 16% of 12v is 1.92v. 30% of 5v would be 1.5v and 16% of 5v would be 0.8v.
I hope you didn't fry your drivers by sending them 0-12v instead of 0-5v
