Kessil Test
icecool2
Kessil Test
I'm looking for a quick way to test my Kessil's functionality. I'd love to be able to do a repeating sunrise/sunset cycle that lasts 60 seconds. Is there an existing test file (I searched and didn't find one) or a quick few lines of code I can run?
Re: Kessil Test
Try this:
It will go from 0 to 100% incrementing 1% every second.
ReefAngel.Init();
ReefAngel.PWM.SetDaylight(now()%100);
ReefAngel.PWM.SetActinic(now()%100);
icecool2
Re: Kessil Test
Thank you. OK, it wasn't my code that was the problem.
I'm recalling something about a booster jumper, but not the specifics. I think I must be in an alternate mode to what I need. I was running this for PWM output previously, but now I need 0-10V. Isn't there a jumper for that?
Sorry, it's been like 4 years since I've messed with this.
EDIT: In the relay box, I have two of three jumpers installed. 1+2, 3+4 are jumpered together. 5+6 are open.
Re: Kessil Test
This is probably an older relay box that required the booster.
If you only have jumpers, it means it is only putting out 0-5 PWM signal.
The booster will put out 0-10 PWM signal, but it won't make the conversion to analog signal, which is what you need for the kessils.
I think the best way is to either get a new relay box with analog signal or the dimming module.
I can make you a PWM booster with analog signal, but it would just end up being the same price.
icecool2
Re: Kessil Test
Crud! I should have checked that before I bought the cable
For the price, I might just pick up the Kessil spectral controller... Crud crud crud...
