relay expansion help
i just installed a expansion relay box and nothing i plug into it powers on. when i connect it to power and plug the serial cable into the expansion hub, the light on the expansion box lights. any ideas??
Re: relay expansion help
i took the box apart and didn't see the dip switches to do that. shouldn't it power on even if not connected to the controller?
i found the switches and changed and it didn't help.
still no power. shouldnt it work just plugged into the wall by itself?
without being connected to the controller.
If it is not connected to the controller, nothing will turn on.
The controller is the one that tells which ports to turn on.
Run I2Cscanner and send the results:
http://forum.reefangel.com/viewtopic.php?p=18831#p18831
i uploaded the code and now the controller is just blinking red
keep following the instructions on the link.
send the results on serial monitor
this is what happens when i plug the expansion box in directly to the controler. things flash on for a sec then off
I2CScanner ready!
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
I2CScanner ready!
here is the monitor with everything plugged back in
I2CScanner ready!
addr: 39 addr: 3A addr: 3B addr: 3C found!
addr: 45 addr: 46 addr: 47 addr: 48 found!
addr: 4D found! addr: 4E addr: 4F found! addr: 50 found!
I2CScanner ready!
so....what does that mean?
Your module is set to ID5. You need to set it to ID1.
When you set to ID1, it will be found as 38 instead of 3C.
is this better? how do you read this?
I2CScanner ready!
addr: 39 found! addr: 3A addr: 3B addr: 3C
done
I2CScanner ready!
done
still not working
I2CScanner ready!
addr: 35 addr: 36 addr: 37 addr: 38 found!
done
I2CScanner ready!
done
here is the code i uploaded and it is still not working.
ReefAngel.AddHumidityExpansion(); // Humidity Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPorts = Port8Bit;
ReefAngel.LeakShutoffPortsE[0] = 0;
InternalMemory.OverheatTemp_write( 835 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port7,13,0,22,30 );
ReefAngel.WaterLevelATO( Port8,25,80,90 );
if (ReefAngel.WaterLevel.GetLevel()>0 && ReefAngel.WaterLevel.GetLevel() < 80) ReefAngel.Relay.On(Port8);
if (ReefAngel.WaterLevel.GetLevel() >=85) ReefAngel.Relay.Off(Port8);
ReefAngel.Portal( "fishflipper" );
ReefAngel.DDNS( "nickgrill.getmyip.com" ); // Your DDNS is fishflipper-nickgrill.getmyip.com.myreefangel.com
Humm.
Can you swap svga cables with the main box?
If it still doesn't work, can you test the relay box itself as the main box?
when connecting the box directly to the controller it does work.
ugh!!! all this and its seems to be the expansion hub. plugged the relay into my other hub and the lights came on. do the expansion hubs just plug into each other to work, right? the light was on so i thought it was working.
No, you can only use one hub per system.
The signal won't propagate to the 2nd hub.
Oh, really? Any future thoughts of adding it? Can the usb port on the expansion box still be used?
Robert, i just want to say thank you for the quick replies and the help on this matter the other night. everything is working great! i do have one more question though.....i know you said only one expansion hub is supported but can the usb port on the expansion module still be used?
No, not yet. This relay box is on a second tank with a 15 foot usb cable and I only had one so was hoping to not have to run another one to the hub.
