Before I get started I'm not the brightest crayon in the box with electronics. Disclaimer out the way.
So I built a led strip light to supplement my t5 that I'm going back to. I chopped up one of my old eBay lights to use the drivers.(pic below). I would like to be able to get the bars to dim up and down throughout the day.
I have located the ground and 10v line as it was labled on the pcb board attached to potentiometer. There is a third line labled on and off that I have no idea what to do with. I assume that third line is what turns driver completely off when potentiometer is turn all the way down.
My question is
1. do I need to hook that line up when I program to ra? If so to where.
2. Being as it that I'm going to plug up in relay box and can I just kill that outlet in the event I don't need that line?
3. How can I tell if it's analog or pwm signal?
Your input is appropriated
