I have used the wizard to create a script but having compiling issues.
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
2014 Main Screen
Salinity Expansion Module
ORP Expansion Module
Simple Menu
sketch_nov07b.cpp: In function 'void setup()':
sketch_nov07b:49: error: 'class ReefAngelClass' has no member named 'FeedingModePortsE'
sketch_nov07b:52: error: 'class ReefAngelClass' has no member named 'WaterChangePortsE'
sketch_nov07b:55: error: 'class ReefAngelClass' has no member named 'LightsOnPortsE'
sketch_nov07b:58: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
After wizard compiling error
Re: After wizard compiling error
Make sure to not select relay expansion module if you don't have one.
I have the module
AH its because I didn't have any ports turned on on the second board yet. Sorted now
