Tide function (proper use quesiton)
saf1
Post by saf1 »
Are there options to pass to the tide function or do you edit the header file for changes?
Right now I'm just declaring Tide, then use it as tide.isIncoming to set the dc pumps and channels. I thought I read somewhere about some values in the .h file and saw below. Was going to see if I can get a bit more alternate flow between the two pumps when they are on/off or have it change more frequently during the day.
Based on the header I'm starting to think that I'm not using it properly or there are more options (or abetter way to use tide such that I don't need to call setMode with reefCrest)?
Here is what I see in the tide.cpp file:
Tide::Tide()
m_WaveLength=12*SECS_PER_HOUR;
m_MaxOffset = 50;
m_MinOffset = 10;
m_Speed = 50;
m_Amp = 1;
m_CurrSpeed=m_Speed;
Part of my code:
if (tide.isIncoming()) {
else {
if (hour()>=21 || hour()<8)
// Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
if (hour()>=8 && hour()<14) {
ReefAngel.DCPump.SetMode( TidalSwell,40,10 );
else if (hour()>=14 && hour()<18) {
ReefAngel.DCPump.SetMode( ReefCrest,30,10 );
else if (hour()>=18 && hour()<21) {
ReefAngel.DCPump.SetMode( NutrientTransport,40,10 ); // Nutrient Transport on sync mode
Re: Tide function (proper use quesiton)
Sorry for taking so long. I owe you a proper answer, but I need to look up the API so I can tell you properly :) should be able to respond tomorrow.
saf1
Post by saf1 »
lnevo wrote:Sorry for taking so long. I owe you a proper answer, but I need to look up the API so I can tell you properly :) should be able to respond tomorrow.
No rush. I am actually reading your RA code thread and another thread which someone is asking similar questions with the sun routines. I have my current code base and trying to see how the sun, longitude stuff, and tie works together.
I'm trying to correlate and test tide with the DCPump.DaylightChannel and DCPump.ActinicChannels to your vortec. The way I have it now just one side is on all time and not alternating so I'm doing something wrong. Yours is pretty complex with random patterns. Very cool. Your RA does everything and the dishes it seems :)
Thanks. Still reading and testing on my side. Learning is good :)
Based on the code you have above you set each channel to Sync or AntiSync and the other to None. You *should* be setting one to sync and the other to anti-sync and flipping them based on if tide is incoming or not. You could also set an offset so that the Sync is more powerful.
ReefAngel.DCPump.AntiSyncOffset=50; // 50% power on the Anti-Sync channel
The best ways to modify the Tide class that you've declared is with the following functions:
Tide.SetSpeed(speed); //
Tide.SetOffset(min,max);
Tide.SetWaveLength(wavelength); // Default is 12 hours
The values you showed in your original post are "private" variables, meaning you can only set them with the functions above and not directly.
What you're missing in your usage is that the Tide also calculates speed. Depending on the time of the day the tide will be stronger or weaker and at it's peak will switch direction. Also as the MoonPhase affects the tide more the speed will adjust between the min and max offsets. This is so you can control how variable this is over the month. You can see how that looks in the attached image.
graphra (1).png (17.73 KiB) Viewed 15792 times
I have found with this type of setup, you don't even need the night mode because it usually goes through 2 slower periods each day with the "late" one going overnight. All you need to do is replace the speeds you have hardcoded with the function Tide.GetSpeed();
So that pretty much takes care of the usage I think. Let me know if you have any questions. Also to know how to use things it's best to look in the .h file. This is where all the functions and variables get defined. If you want to know *what* that function does.. then look it up in the cpp file. Hope that helps with the learning.
You can see btw where I changed my max speed from 65 to 70 :)
saf1
Post by saf1 »
Thanks Lnevo. Very detailed and powerful code. It defineatly packages everything I'd like to use once I get it dialed in. So thanks for explaining it.
I'll fix the tide isIncoming block.
If I understand correctly I don't need the if logic at all for flow or limit after hours. I just did a quick test and removed it. However, when I tried to replace the hard coded values it didn't compile. So I'm pretty sure I'm calling it incorrectly.
ReefAngel.DCPump.SetMode( ReefCrest,30,10): works, but it isn't working if I replace the numbers with Tide.GetSpeed(), etc.
Tide is the classname not the variable instance of it you have declared.
Since in your code you're using tide.isIncoming, you would use the same name when retrieving the speed tide.GetSpeed();
That should take care of it.
saf1
Post by saf1 »
EDIT: Ok, I posted while off making changes - may still be applicable but this is what I had working before you replied. Sorry.
1. Needed to set variable
byte tideSpeed=tide.GetSpeed();
2. Removed older DCPump logic and added a single line
ReefAngel.DCPump.SetMode( ReefCrest, tideSpeed, 10);
// still reading on the last value does (set to 10 for now)
Compiled fine and running. Also set the AntiSyncOffset so will see how this goes for the next couple of hours. Looks good although I'm stuck at reef crest which may not be a bad thing since this is just a 40 breeder. Cool, thanks Lnevo. Just had to go through some more of your code (not programed in many many years, so forgot a lot).
Customer code now:
CheckCloud();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
saf1
Post by saf1 »
This is also working...
ReefAngel.DCPump.SetMode( ReefCrest, tideSpeed, tide.isIncoming());
saf1
Post by saf1 »
Lnevo - one more question. How did you generate the graph you posted?
I just reconnected my wireless module since I was done uploading code and wondering how you did it.
Thanks.
That was from reeftronics.net go check it out and sign up. You will get a 24 hour, 7 day history and 30 day graph of most parameters
CaliFSU
Post by CaliFSU »
I am having trouble with the tide speed call. My speed stays fixed on 50 no matter what time of day. Is this how the code is supposed to operate? I thought this would vary.
#include <SunLocation.h>
#include <Tide.h>
	strcat(text, "  ");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 93, "Salinity:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 75, 93, text);
	ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
Tide tide;
byte tideSpeed = tide.CalcTide();
SunLocation sun;
int DaylightPWMValue = 0;        // For cloud code
								 // Define Relay Ports by Name
#define MoonLights         1
#define ATOPump	           2
#define Unused             3
#define ATOCirculation     4
#define Skimmer            5
#define MainPump           6
#define WhiteLED           7
#define BlueLED	           8
	ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
	ReefAngel.FeedingModePorts = Port5Bit | Port4Bit | Port6Bit;  // Ports toggled in Feeding Mode
	ReefAngel.WaterChangePorts = Port5Bit | Port4Bit | Port6Bit;  // Ports toggled in Water Change Mode
	ReefAngel.DCPump.FeedingSpeed = 0;
	ReefAngel.DCPump.WaterChangeSpeed = 0;
	ReefAngel.LightsOnPorts = Port1Bit | Port7Bit | Port8Bit;
	ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
	InternalMemory.OverheatTemp_write(869);
	ReefAngel.Relay.On(Port2);
	ReefAngel.Relay.On(Port4);
	ReefAngel.Relay.On(Port5);
	ReefAngel.Relay.On(Port6);
	tide.Init(45, 10, 30);
	tide.SetWaveLength(12 + SECS_PER_HOUR);
	sun.Init(25.6839518, -80.4713138); // Miami, FL
	sun.SetOffset(-4, 0, -4, 0); //Offset to get Eastern Time Zone
	CheckCloud();
	ReefAngel.PWM.SetChannelRaw(0, DaylightPWMValue);
	sun.CheckAndUpdate();
	byte w_risehour = sun.GetRiseHour();
	byte b_risehour = sun.GetRiseHour(); //Starting Blues an hour before
	byte riseminute = sun.GetRiseMinute();
	byte w_sethour = sun.GetSetHour();
	byte b_sethour = (sun.GetSetHour()) + 1;
	byte setminute = sun.GetSetMinute();
	char label_rise_hr = sun.GetRiseHour();
	char label_rise_min = sun.GetRiseMinute();
	char label_set_hr = sun.GetSetHour();
	char label_set_min = sun.GetSetMinute();
	byte vtDuration = InternalMemory.RFDuration_read();
	ReefAngel.StandardLights(Port7, w_risehour, riseminute, w_sethour, setminute);
	ReefAngel.StandardLights(Port8, b_risehour, riseminute, b_sethour, setminute);
	DaylightPWMValue = PWMSlopeHighRes(w_risehour, riseminute, w_sethour, setminute, 0, 50, 60, 0); //White SunLocation
	ReefAngel.PWM.SetChannelRaw(1, PWMSlopeHighRes(b_risehour, riseminute, b_sethour, setminute, 0, 85, 30, 0));  // Blues SunLocation
	ReefAngel.StandardLights(Port1, w_sethour, setminute, w_risehour, riseminute); //Moon Lights
	ReefAngel.CustomVar[0] = label_rise_hr; //Sunrise time label
	ReefAngel.CustomVar[1] = label_rise_min; //Sunrise time label
	ReefAngel.CustomVar[2] = label_set_hr; //Sunset time label
	ReefAngel.CustomVar[3] = label_set_min; //Sunset time label
	ReefAngel.CustomVar[4] = tideSpeed; //Tide speed
	ReefAngel.CustomVar[5] = vtDuration; //Tide duration
	ReefAngel.DCPump.Threshold = 20;
	if (hour() >= 0 && hour() < w_risehour) {
		ReefAngel.DCPump.SetMode(Lagoon, tideSpeed, vtDuration);
	else if (hour() >= w_sethour && hour() <= 24) {
	else if (hour() >= w_risehour && hour() <= w_sethour)
		ReefAngel.DCPump.SetMode(LongPulse, tideSpeed, vtDuration);
	ReefAngel.Portal("CaliFSU");
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(9,00)
	// Add Random Lightning modes
	// Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
	byte LightningModes[] = { Mega2,Mega,Mega };
	static byte cloudchance = 255;
	static byte cloudduration = 0;
	static int cloudstart = 0;
	static byte numclouds = 0;
	static byte lightningchance = 0;
	static byte cloudindex = 0;
	static byte lightningstatus = 0;
	static int LastNumMins = 0;
	static byte lightningMode = 0;
	static boolean chooseLightning = true;
	static time_t DelayCounter = millis();    // Variable for lightning timing.
	static int DelayTime = random(1000);      // Variable for lightning timimg.
	if (hour() == 0 && minute() == 0 && second() == 0) cloudchance = 255;
#ifdef forcecloudcalculation
	if (cloudchance == 255)
#else
	if (hour() == 0 && minute() == 0 && second() == 1 && cloudchance == 255)
#endif
		cloudchance = random(100);
		if (cloudchance>Cloud_Chance_per_Day) cloudchance = 0;
		if ((day() % Clouds_Every_X_Days) != 0) cloudchance = 0;
		// If we have cloud today
		if (cloudchance)
			numclouds = random(Min_Clouds_per_Day, Max_Clouds_per_Day);
			cloudstart = random(Start_Cloud_After, Start_Cloud_After + ((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2)));
			cloudduration = random(Min_Cloud_Duration, Max_Cloud_Duration);
			lightningchance = random(100);
			if (lightningchance>Lightning_Change_per_Cloud) lightningchance = 0;
	if (cloudchance)
		//is it time for cloud yet?
		if (NumMins(hour(), minute()) >= cloudstart && NumMins(hour(), minute())<(cloudstart + cloudduration))
			DaylightPWMValue = ReversePWMSlope(cloudstart, cloudstart + cloudduration, DaylightPWMValue / 40.95, 0, 180)*40.95;
			if (chooseLightning)
				lightningMode = LightningModes[random(100) % sizeof(LightningModes)];
				chooseLightning = false;
			switch (lightningMode)
			case Calm:
				break;
			case Mega:
				if (lightningchance && random(ReversePWMSlope(cloudstart, cloudstart + cloudduration, 100, 0, 180))<1 && (millis() - DelayCounter)>DelayTime)
					// Send the trigger
					Strike();
					DelayCounter = millis();    // If we just had a round of flashes, then lets put in a longer delay
					DelayTime = random(1000);   // of up to a second for dramatic effect before we do another round.
				break;
			case Mega2:
				if (lightningchance && random(ReversePWMSlope(cloudstart, cloudstart + cloudduration, 100, 0, 180))<2)
					Strike();
				break;
			case Fast:
				if (lightningchance && (NumMins(hour(), minute()) == (cloudstart + (cloudduration / 2))) && second()<5 && (millis() - DelayCounter)>DelayTime)
					Strike();
				break;
			case Slow:
				if (lightningchance && (NumMins(hour(), minute()) == (cloudstart + (cloudduration / 2))) && second()<5)
					if (random(100)<20) lightningstatus = 1;
					else lightningstatus = 0;
					if (lightningstatus)
						DaylightPWMValue = 4095;
					delay(1);
				break;
			default:
				break;
			chooseLightning = true; // Reset the flag to choose a new lightning type
		if (NumMins(hour(), minute())>(cloudstart + cloudduration))
			cloudindex++;
			if (cloudindex < numclouds)
				cloudstart = random(Start_Cloud_After + (((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2))*cloudindex * 2), (Start_Cloud_After + (((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2))*cloudindex * 2)) + ((End_Cloud_Before - Start_Cloud_After) / (numclouds * 2)));
	if (LastNumMins != NumMins(hour(), minute()))
		LastNumMins = NumMins(hour(), minute());
		if (cloudchance && (NumMins(hour(), minute())<cloudstart))
			int x = 0;
			if ((cloudstart / 60) >= 10) x = 11;
			else x = 17;
			//ReefAngel.CustomVar[3] = cloudstart / 60; // Write the hour of the next cloud to custom variable for Portal reporting
			if ((cloudstart % 60) >= 10) x = 29;
			else x = 35;
			//ReefAngel.CustomVar[4] = cloudstart % 60; // Write the minute of the next cloud to custom variable for Portal reporting
		//ReefAngel.CustomVar[7] = (cloudduration);    // Put the duration of the next cloud in a custom var for the portal
		if (lightningchance)
			int x = 0;
			if (((cloudstart + (cloudduration / 2)) / 60) >= 10) x = 51;
			else x = 57;
			//ReefAngel.CustomVar[5] = (cloudstart + (cloudduration / 2)) / 60;    // Write the hour of the next lightning to a custom variable for the Portal
			if (((cloudstart + (cloudduration / 2)) % 60) >= 10) x = 69;
			else x = 75;
			//ReefAngel.CustomVar[6] = (cloudstart + (cloudduration / 2)) % 60;
void Strike()
	int a = random(1, 5);    // Pick a number of consecutive flashes from 1 to 4.
	for (int i = 0; i<a; i++)
		// Flash on
		int newdata = 4095;
		Wire.beginTransmission(0x40);      // Address of the dimming expansion module
		Wire.write(0x8 + (4 * 1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
		Wire.write(newdata & 0xff);          // Send the data 8 bits at a time.  This sends the LSB
		Wire.write(newdata >> 8);            // This sends the MSB
		Wire.endTransmission();
		int randy = random(20, 80);    // Random number for a delay
		if (randy>71) randy = ((randy - 70) / 2) * 100;    // Small chance of a longer delay
									 // Flash off.  Return to baseline.
		newdata = ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
		Wire.beginTransmission(0x40);    // Same as above
		delay(random(30, 50));                // Wait from 30 to 49 ms
		wdt_reset();    // Reset watchdog timer to avoid re-boots
byte ReversePWMSlope(long cstart, long cend, byte PWMStart, byte PWMEnd, byte clength)
	long n = elapsedSecsToday(now());
	cstart *= 60;
	cend *= 60;
	if (n >= cstart && n <= (cstart + clength)) return map(n, cstart, cstart + clength, PWMStart, PWMEnd);
	if (n>(cstart + clength) && n<(cend - clength)) return PWMEnd;
	if (n >= (cend - clength) && n <= cend) return map(n, cend - clength, cend, PWMEnd, PWMStart);
	if (n>cend) return (int)PWMStart;
>>--Cali-->
Ok first off you copied the same mistake someone else made. If you set wavelength to 12 + SECS_PER_HOUR then it will be 72 minutes per high tide to low tide. Should be 12 * ... Unless you're troubleshooting maybe.
Also you only set tideSpeed once when you declare it so it isn't updating. Try setting it inside loop instead. Also you have w_sethour and label_rise_hr which are the same value. You could just consolidate them and reduce the number of variables you need.
CaliFSU
Post by CaliFSU »
Lee - thanks for your input. I got it working.
What are you doing to generate the vtDuration number? I wanted to see what I could tie this to in order for it to vary throughout the Tide cycle.
>>--Cali-->
I really only change that depending on the mode. If you look at my function RFCustom you'll see where I set it.
