Dosing Code Check
Paul_Velasco
Dosing Code Check
Post by Paul_Velasco »
Will this work?
Two dosers:
Doser 1 = Turn on at 9:00AM and dose for 2 minutes. Repeat every 4 hours
Doser 1 = Turn on at 9:15AM and dose for 2 minutes. Repeat every 4 hours
Want to make sure I am not overdosing as this will be Amino Acid and do not want to pollute the tank.
///Code to make Vinegar Dosing Work 4 mins
    ///02.15.16 = Changed to dosing Amino Acid every 4 hrs for 2 mins, on top of hours
    ///Start at 9:00AM
        ReefAngel.DosingPumpRepeat(Box1_Port8,540,240,120);
    ///Do not turn on Vinegar if lights are off
    ///02-15-16 = Changed to Dosing AA throughout the day
    ///    if (hour()<=8 || hour()>21) {
    ///      ReefAngel.Relay.Off(Box1_Port8);
    //Code to make Magnesium Dosing Work
    ///02.15.16 = Changed to dosing Amino Acid every 4 hrs for 2 mins, on 15 of hour
    ///Start at 9:15AM
        ReefAngel.DosingPumpRepeat(Box1_Port4,555,240,120);
Re: Dosing Code Check
Yes, replied on your duplicate thread.
