I am hoping someone can help me get a code for running 2 dosing pumps.
I am wanting to run them several times a day for short equal periods. I don't have the actual specifics at this time but for an example I could manipulate with the times i will want to use could we have port 7 come on for 3 minutes every 4 hours starting at maybe midnight and port 8 running for 2 minutes every 4 hours starting at 2am?
I have been without a computer for a few months now and therefore have lost what little coding knowledge I had and am having trouble figuring out how to get this coded correctly.
Thank you for any help you can provide.
How do i code dosing pumps
MDB1029
- lnevo
MDB1029
MDB1029
MDB1029
Re: How do i code dosing pumps
Didn't realize it was able to be set up through the wizard. I feel like an idiot.
So with using internal memory,
I would just have to adjust how i wanted them to run from the portal, right?
ReefAngel.DosingPumpRepeat2( Port8 );- lnevo
Yes! Sorry I didnt get back to you. I would set your settings in portal then upload your new code.
MDB1029
