Ah, you missed one line on your DrawDate() function.
That line is very important as it initializes the variable with nothing. Otherwise, you get remaining garbage and it messes up when you concatenate strings with strcat()
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
int maxTemp=0;
int minTemp=2000;
time_t tsmax=now();
time_t tsmin=now();
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label};
void DrawTime(byte x, byte y, time_t ts)
//byte iTimeHourOffset=0;
char text[13];
char temp[]=" ";
strcpy(text,"");
//if (iTimeHour>12) iTimeHourOffset=12;
itoa(hourFormat12(ts),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,":");
itoa(minute(ts),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(ts),temp,10);
strcat(text,temp);
if (isAM(ts))
strcat(text," AM");
strcat(text," PM");
ReefAngel.LCD.DrawText(DateTextColor, DefaultBGColor, x, y, text);
// update the min and max temps
if (now()%86400==0)
minTemp=ReefAngel.Params.Temp1;
maxTemp=ReefAngel.Params.Temp1;
if (ReefAngel.Params.Temp1<minTemp)
tsmin=now();
// DrawTime(60,33);
if (ReefAngel.Params.Temp1>maxTemp)
tsmax=now();
// DrawTime(60,23);
DrawTime(60,23,tsmax);
DrawTime(60,33,tsmin);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 23, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 23, 10);
// Display the Sump temperature
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 10);
ReefAngel.LCD.DrawOutletBox(12, 45, TempRelay);
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
ReefAngel.LCD.DrawGraph(1, 75);
ReefAngel.Init(); //Initialize controller and start web banner timer
ReefAngel.Timer[4].SetInterval(180); // set interval to 180 seconds
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.WaterChangePorts = B10110000;
// ReefAngel.OverheatShutoffPorts = B00000111;
// ReefAngel.LightsOnPorts = B00001100;
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port7);
// Specific functions
//1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
ReefAngel.StandardHeater(Port1,788,792);
ReefAngel.StandardHeater(Port2,770,792);
ReefAngel.MHLights(Port3,10,0,20,0,5);
ReefAngel.StandardLights(Port4,9,0,21,0);
ReefAngel.StandardFan(Port8,792,820);
// Wavemaker Code with night option
if (ReefAngel.Timer[1].IsTriggered() )
if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
{ //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
// byte endPWM, byte Duration, byte oldValue)
wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
if (wmdelay)
ReefAngel.Timer[1].SetInterval(wmpulse); // WM delay function from 30-170 sec.
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(200-wmpulse); // WM bursts timing from 170-30 sec.
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-10p normal wave settings
ReefAngel.Relay.Toggle(Port6);
//Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
//other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
if (ReefAngel.Params.Temp1>830)
pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,HIGH);
{pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,LOW);
//Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
ReefAngel.WebBanner();
