ReefAngel.PHMin=511;
ReefAngel.PHMax=760;
InternalMemory.DCPumpThreshold_write(15);
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
// Use T3 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 835 );
ReefAngel.DCPump.FeedingSpeed=16;
ReefAngel.Relay.On( Port2 ); //Dimming Module
ReefAngel.Relay.On( Port4 ); //Jebao DP4
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardLights( Port3,12,00,22,00 ); // Secondary Pump
ReefAngel.StandardLights( Port7,0,30,10,30 ); // Fuge Lamp
////// Light Schedule Below
//Set Channel 0 LED RED
if (PWMSlope(13,15,22,45,5,85,120,5)<=6)
ReefAngel.PWM.SetChannel( 0, 0);
ReefAngel.PWM.SetChannel( 3, 0);
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,15,22,45,5,85,120,5) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(13,15,22,45,5,85,120,5) );
//Set Channel 1 LED WHITE
if (PWMSlope(13,30,22,30,5,80,120,5)<=6)
ReefAngel.PWM.SetChannel( 1, 0);
ReefAngel.PWM.SetChannel( 4, 0);
ReefAngel.PWM.SetChannel( 1, PWMSlope(13,30,22,30,5,80,120,5) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(13,30,22,30,5,80,120,5) );
//Set Channel 2 LED BLUE
if (PWMSlope(13,0,23,0,5,100,120,5)<=6)
ReefAngel.PWM.SetChannel( 2,0);
ReefAngel.PWM.SetChannel( 5,0);
ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,23,0,5,100,120,5) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(13,0,23,0,5,100,120,5) );
////// End of Light Schedule
//Setting Jebao Pump Wave Patterns
if (hour()>=12 && hour()<13 ) // Morning mode between 12pm and 1pm
ReefAngel.DCPump.SetMode(ReefCrest,40,20 );
else if (hour()>=13 && hour()<15) // Day mode between 1m and 3pm
ReefAngel.DCPump.SetMode( ReefCrest,50,25 );
else if (hour()>=15 && hour()<20) // Day mode between 3pm and 8pm
ReefAngel.DCPump.SetMode( ReefCrest,75,25 );
else if (hour()>=20 && hour()<21) // Evening mode between 8pm and 9pm
ReefAngel.DCPump.SetMode( ReefCrest,60,15 );
else if (hour()>=21 && hour()<23) //Calming beween 9pm and 11pm
ReefAngel.DCPump.SetMode( ReefCrest,40,20 );
ReefAngel.DCPump.SetMode( ReefCrest,40,10 ); // Night Mode between 11pm and l2pm
ReefAngel.DCPump.ActinicChannel = AntiSync; //use None when inactivated
ReefAngel.Portal( "civics14" );
