ATO questions
rossbryant1956
ATO questions
Post by rossbryant1956 »
found this line of code earlier and playing with it, had questions:
ReefAngel.SingleATO(true, Port7, InternalMemory.ATOExtendedTimeout_read(), 3); // Runs ATO for 60 seconds every 3 hours
Float valve plugged into ATOlow, time out set to 60 seconds in wizard. Outlet comes on the first time and times out normally, but doesn't come back on. Status light is lit on RA.
If I go bump the float valve the outlet comes back on and runs the normal time out but status light stays on
Question: what controls that status light and how does it get reset? Is this line of code correct for the app? I want the pump to run for X seconds, time out, and then come back on at next time interval.
thx
rossbryant1956
Re: ATO questions
Ok, this line of code seems to work, AS LONG AS IT DOESN'T TIME OUT. Is there an article somewhere that explains the time out feature, what it does and doesn't do, how you reset it, etc.?
I'm still testing and thank you in advance for your help!!
Re: ATO questions
Click the joystick, go to timeouts, ATO clear.
rossbryant1956
Re: ATO questions
I didn't know about the joystick, so thanks ... I also found it in the android app. This is now working beautifully as well. Thank you.
