RA status app/wifi?
RA status app/wifi?
ive connected the wifi to the controler using the wifi test code provided and typed in the http://xxx.xxx.xxx.2000 but when i try to use the app it doesnt do anything. when i goto portal on the forum it says my status is unreachable
Re: RA status app/wifi?
everything on the relay shut off too? how do add the code to the controller properly?
if you just loaded the wifi test code, then you most likely do not have any code running other than the test code. you will need to load your code on the controller to be able to run it. the test code just tests if the wifi connects (i believe) and does nothing else.
am i adding the wifi code into the code generated in the wizard? my wifi attachment is blinking green(one LED). Ive added the ddns code that you provided in a different forum. that was verified and i uploaded the code onto the RA.in the portal it says i dont have a reachable wifi address. on a different topic the clock on my unit keeps going to 3pm. my lights are on and off at wierd hours. i just tried reinstalling the code and waiting too see what happens
No, if you have green LED, you are all set with the wifi attachment.
The portal is saying unreachable because it can't connect to your controller.
By default, all routers block incoming connections. It's the default state of any firewall.
You need to setup up port forwarding to allow any external incoming connection. The portal and the apps need this to be able to connect to your wifi attachment.
Ok cool thanks. Where do go to do this?
You have to do it in your router settings.
Check with your router manufacturer if you are unsure on how to access the settings.
Ok then it should work?
ok so ive gotten into the router. how do i forward the RA?
We use port 2000. So, you need to forward tcp port 2000 to the ip address of your wifi attachment.
Im sorry im really not any good with computers. How will i find the wifi ip and how do i forward it
When i goto connected devices the reef angel wifi shows up. When i goto port forwarding i do not see anything regarding reef angel.to add 2000 to the IP, Port forwarding is enabled.the portal wont connect.
Shimmerlessreef, what brand router are you using? I might be able to help.
-James-
