clock reseting?
shimmerlessreef
clock reseting?
Post by shimmerlessreef »
The clock keeps changing time then its saying its later or earlier than actual time. Like 6 -10 hours
Re: clock reseting?
What expansion modules do you have connected?
Sounds like a bus lock problem.
shimmerlessreef
Re: clock reseting?
I dont have any hooked up other than the wifi exp
Re: clock reseting?
Is this a new unit you just bought?
shimmerlessreef
Re: clock reseting?
I bought it used. I just looked and i have ato activated but nothing is plugged into the port. Could that do it?
Re: clock reseting?
You may have a bad head unit. Do you see any signs of water damage?
shimmerlessreef
Re: clock reseting?
No but that being said i havnt taken it apart. Everything else seems to work though
Re: clock reseting?
I had a loose battery terminal in mind that was causing it
