Why are my lights dropping to 0 at end of daily slope?
DmnYnkee
Post by DmnYnkee »
I am wanting them to stop at 1% for charting purposes. With my current code, which incorporated the cloud code from Colin, they are going all the way to 0.
Do I need to change the values here to 40.95 instead of 1?
    int ActinicPWMValue0=1;        // For cloud code, channel 0, left blue
    int ActinicPWMValue2=1;        // For cloud code, chennel 2, center blue
    int ActinicPWMValue4=1;        // For cloud code, chennel 4, right blue
    int DaylightPWMValue1=1;        // For cloud code, channel 1, left white
    int DaylightPWMValue3=1;        // For cloud code, chennel 3, center white
    int DaylightPWMValue5=1;        // For cloud code, chennel 5, right white
I would also like to know what the zero at the end of the string is for: PWMSlopeHighRes(9,30,21,30,1,65,230,0);
Here is my current full code:
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
             int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    ReefAngel.Init();        //Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(1800);                                        // Feeding timer at 30 minutes (in seconds)
    ReefAngel.FeedingModePorts = Port7Bit;                                                   // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit;                                // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;   // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 820 );                                                // Set the Overheat temperature setting
    CustomOverheatClear(T1_PROBE);
    // Virtual Ports that are always off
    ReefAngel.Relay.Off( Box1_Port1);
    ReefAngel.Relay.Off( Box1_Port2);
    ReefAngel.Relay.Off( Box1_Port3);
    ReefAngel.Relay.Off( Box1_Port4);
    ReefAngel.Relay.Off( Box1_Port5);
    ReefAngel.Relay.Off( Box1_Port6);
    ReefAngel.Relay.Off( Box1_Port7);
    ReefAngel.Relay.Off( Box1_Port8);
    // Delayed start for skimmer to allow sump level to return to normal after water change
    ReefAngel.Relay.DelayedOn( Port7,4 );
    sl.Init(28.5700, -81.6800);    // Lat/long for Clermont, FL
    sl.SetOffset(-2,0,-2,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="BlueLED";
    ReefAngel.CustomLabels[2]="WhiteLED";
    ReefAngel.CustomLabels[3]="Refugium";
    ReefAngel.CustomLabels[4]="Moonlights";
    ReefAngel.CustomLabels[5]="Heater";
    ReefAngel.CustomLabels[6]="Skimmer";
    ReefAngel.CustomLabels[7]="ATO RoDi";
    // Virtual Ports reserved for custom lighting functions and effects
    ReefAngel.CustomLabels[8]="Lights:  B60/W40";
    ReefAngel.CustomLabels[9]="Lighta: Whites 40";
    ReefAngel.CustomLabels[10]="Lights: Blues 60";
    ReefAngel.CustomLabels[11]="Not Used";
    ReefAngel.CustomLabels[12]="Storm";
    ReefAngel.CustomLabels[13]="Weather";
    ReefAngel.CustomLabels[14]="Weather";
    ReefAngel.CustomLabels[15]="Weather";
    // seasonal temperatures
    SeasonalTemps();
// Lights on Dimming Expansion. (Left=East, Center=Center, Right=West)
//if (ReefAngel.Relay.Status( Box1_Port1 )); // Set Lights 60/40
//   ActinicPWMValue0=60;        // Virtual port, channel 0, left blue
//   ActinicPWMValue2=60;        // Virtual port, chennel 2, center blue
//   ActinicPWMValue4=60;        // Virtual port, chennel 4, right blue
//   DaylightPWMValue1=40;        // Virtual port, channel 1, left white
//   DaylightPWMValue3=40;        // Virtual port, chennel 3, center white
//   DaylightPWMValue5=40;        // Virtual port, chennel 5, right white
// Default lighting program
ActinicPWMValue0=PWMSlopeHighRes(9,30,21,30,1,65,230,0);  // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(9,45,21,45,1,65,230,0);
ActinicPWMValue4=PWMSlopeHighRes(10,00,22,0,1,65,230,0);
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,175,0);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,175,0);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,175,0);
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,ActinicPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,ActinicPWMValue2);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(4,ActinicPWMValue4);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3);  //  lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5);  //  lightning if it's time.
// Turn Actinic outlet on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2 || ReefAngel.PWM.GetChannelValue(2)>=2 || ReefAngel.PWM.GetChannelValue(4)>=2) ?  ReefAngel.Relay.On( Port2 ) :  ReefAngel.Relay.Off( Port2 );
// Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2 || ReefAngel.PWM.GetChannelValue(3)>=2 || ReefAngel.PWM.GetChannelValue(5)>=2) ?  ReefAngel.Relay.On( Port3 ) :  ReefAngel.Relay.Off( Port3 );
// Refugium Light: sPar38-Fuge
if (hour()<16 || hour() >=19)
 ReefAngel.Relay.On( Port4 );
 ReefAngel.Relay.Off( Port4 );
//  Moonlight Strip
if ((hour()>=21 && hour() <=23) || (hour()>=8 && hour()<10))
 ReefAngel.Relay.On( Port5 );
 ReefAngel.Relay.Off( Port5 );
// WP-25 powerheads schedule
if (hour()>=9 && hour()<13)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(55,15,true) ); // reefcrest at 55% +/- 15% on sync mode       (Day Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(55,15,false) ); // reefcrest at 55% +/- 15% on Anti-sync mode  (Day mode)
else if (hour()>=13 && hour()<19)
 byte random_speed=random(48,78);
 ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 48%-78% with 408ms pulse on sync mode (surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 48%-78%% with 408ms pulse on Anti-sync mode (surface wave)
else if (hour()>=19 && hour()<20)
 byte random_min=random(35,45);
 byte random_speed=random(65,80);
 byte random_duration=random(2,5);
 ReefAngel.PWM.SetDaylight( LongPulseMode(random_min,random_speed,random_duration,true) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on sync mode (nutrient transport)
 ReefAngel.PWM.SetActinic( LongPulseMode(random_min,random_speed,random_duration,false) ); // Long Pulse 35% ramping up to 65%-80% for 2-5 seconds on Anti-sync mode  (nutrient transport)
else if (hour()>=20 && hour()<21)
 ReefAngel.PWM.SetDaylight( ReefCrestMode(50,10,true) ); // reefcrest at 50% +/- 10% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(50,10,false) ); // reefcrest at 50% +/- 10% on Anti-sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic(1);
 ReefAngel.PWM.SetDaylight(1);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(35);
 ReefAngel.PWM.SetDaylight(35);
// enter feeding mode at 5:30pm
if ( (hour()==17 && minute()==30 && second()==0))
 ReefAngel.FeedingModeStart(); // turn on feeding mode
if(ReefAngel.HighATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
 ReefAngel.SingleATO(true,Port8,400,0);   //  Sump switch.  If ATO/RoDi runs for 400 seconds, then shut off and send alert.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {786,790},                  // default in case of error in month=0 (June)
                    {774,778},//January (winter)            // 77.6
                    {776,780},//February (winter)           // 77.8
                    {778,782},//March (early spring)        // 78.0
                    {780,784},//April (spring)              // 78.2
                    {782,786},//May (spring)                // 78.4
                    {786,790},//June (early summer)         // 78.8
                    {790,794},//July (summer)               // 79.2
                    {794,798},//August (summer)             // 79.6
                    {790,794},//September (early fall)      // 79.2
                    {786,790},//October (fall)              // 78.8
                    {782,786},//November (fall)             // 78.4
                    {778,782} };//December (early winter)   // 78.0
  ReefAngel.StandardHeater( Port6,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
// ------------------------------------ Auto overheat clear
void CustomOverheatClear(byte probe)
if((bitRead(ReefAngel.AlertFlags, OverheatFlag)) && (ReefAngel.Params.Temp[probe] <= InternalMemory.OverheatTemp_read()-30))
ReefAngel.OverheatClear();
// ------------------------------------------------------------  Weather section
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after 12:00pm
#define Start_Cloud_After NumMins(12,00)
#define Lightning_Change_per_Cloud 70
  // Add Random Lightning modes
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = { Mega };        // <---- set Storm modes here
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOn(Box1_Port5))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(Box1_Port5);    // Here, too.
    //is it time for cloud yet?
         // Increase Blue channel first, for better effect and to compensate for drop in Whites
      ActinicPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue0,ActinicPWMValue0+DaylightPWMValue1*.85,120);
      ActinicPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue2,ActinicPWMValue2+DaylightPWMValue3*.85,120);
      ActinicPWMValue4=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue4,ActinicPWMValue4+DaylightPWMValue5*.85,120);
         // Daylight dimming from cloud
      DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1/40.95,2,120)*40.95;
      DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3/40.95,2,120)*40.95;
      DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5/40.95,2,120)*40.95;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,120))<1 && (millis()-DelayCounter)>DelayTime)
          // Send the trigger
          int r=random(34);
          if (r<20) {
          Strike1();                // All 3 lights
        } else if (r<22) {
          Strike2();                // Left only
        } else if (r<24) {
          Strike3();                // Center only
        } else if (r<28) {
          Strike4();                // Right only
        } else if (r<30) {
          Strike5();                // Left & Center
        } else if (r<34)
          Strike6();                // Center & Right
          DelayTime=random(1800);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOff(Box1_Port5) && now()%60<10)
    SlowStrike();
    void SlowStrike()
    int r = random(80);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left, center, right, or All.
      if (r<10  ) {               // All 3
        DaylightPWMValue1=4095;
        DaylightPWMValue3=4095;
        DaylightPWMValue5=4095;
      } else if (r<12) {          // Left only
        DaylightPWMValue3=100;
        DaylightPWMValue5=100;
      } else if (r<14) {          // Center only
        DaylightPWMValue1=100;
      } else if (r<16) {          // Right only
      } else if (r<18) {          // Left & Center only
      } else {                    // Center & Right only
        delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike1()          //  All 3 lights
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*3));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 3.
    Wire.write(0x8+(4*5));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 5.
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(3);   // Use the channel number you're flashing here
    newdata=ReefAngel.PWM.GetChannelValueRaw(5);   // Use the channel number you're flashing here
    wdt_reset();    // Reset watchdog timer to avoid re-boots
void Strike2()          // Left only
  int a=random(1,4);    // Pick a number of consecutive flashes from 1 to 3.
    // Flash on
    int newdata=4095;
void Strike3()          // Center only
    // Flash on
    int newdata=4095;
void Strike4()          // Right only
    // Flash on
    int newdata=4095;
void Strike5()          //  Left & Center
    // Flash on
    int newdata=4095;
void Strike6()          // Center & Right
    // Flash on
    int newdata=4095;
void Strike()
    // Flash on
    int newdata=4095;
  cstart*=60;
  cend*=60;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Re: Why are my lights dropping to 0 at end of daily slope?
That's for what you want to do.
It will output zero when not during slope. If you want one, change it from zero to one.
DmnYnkee
Post by DmnYnkee »
That didn't fix it. All 6 channels still dropped to zero.
This is the portion I changed and added the 1's at the end.
ActinicPWMValue0=PWMSlopeHighRes(9,30,21,30,1,65,230,1);  // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(9,45,21,45,1,65,230,1);
ActinicPWMValue4=PWMSlopeHighRes(10,00,22,0,1,65,230,1);
DaylightPWMValue1=PWMSlopeHighRes(10,30,20,30,1,25,175,1);    //  Default for whites
DaylightPWMValue3=PWMSlopeHighRes(10,45,20,45,1,25,175,1);
DaylightPWMValue5=PWMSlopeHighRes(11,00,21,0,1,25,175,1);
You are using High res andit has resolution from 0-4095.
In order to have a one in a non high res, you need a value greater than 40.
Try using 41 instead.
DmnYnkee
Post by DmnYnkee »
That did the trick! I thought I needed to add 40+ somewhere due to the high res, but wasn't sure where the correct place was.
Thanks much, rimai!!!
