auto feed code not working.
GugsJr
Post by GugsJr »
I'm sure I have a setting off some where in here but I can't figure it out.
I thought I had it set to go into feed mode at 5pm and then cycle port 6.
After feed mode to go in to Nutrient Transport Mode for 2.5 hours.
Looking at the relay graph it doesn't seem like it went into feed mode.
Any help would be appreciated
// Define Relay Ports by Name
#define Feeder             Port6
int DaylightPWMValue0=0;        // For cloud code, channel 0
int DaylightPWMValue2=0;        // For cloud code, chennel 2
    ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
    ReefAngel.DCPump.Threshold=30; //Jebao won't go over 30%
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port7 );
// seasonal temperatures
    SeasonalTemps();
    ReefAngel.StandardLights( Port1,14,25,1,5 );
    ReefAngel.StandardLights( Port2,14,25,3,10 );
    ReefAngel.StandardLights( Port3,22,55,2,30 );
    ReefAngel.StandardLights( Port4,23,55,3,0 );
    ReefAngel.StandardATO( Box1_Port6 );
    ReefAngel.MoonLights( Box1_Port7 );
   ReefAngel.PWM.SetChannel( 1, PWMSlopeHighRes(14,30,23,30,1,50,240,0) );  // Schedule for front blues 2:30pm-11:30pm
ReefAngel.PWM.SetChannel( 3, PWMSlopeHighRes(15,0,0,0,0,50,240,0) ); // Schedule for rear blues 3pm-Midnight
DaylightPWMValue0=PWMSlopeHighRes(16,00,22,0,0,35,240,0);    //  Schedule for front whites 4pm-10pm
DaylightPWMValue2=PWMSlopeHighRes(16,30,22,00,0,35,240,0); // Schedule for rear whites 4:30pm-10:30pm
CheckCloud();    //  Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);  //  Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);  //  lightning if it's time.
    ReefAngel.DCPump.ExpansionChannel[0] = Sync;
// Lights turned on set Blues to 50% and whites to 35%
if (bitRead(ReefAngel.StatusFlags,LightsOnFlag))
     ReefAngel.PWM.SetChannel( 1,(35) ); //Set Front Daylight 35%
     ReefAngel.PWM.SetChannel( 2,(50) ); //Set Front Actinics 50%
     ReefAngel.PWM.SetChannel( 3,(35) ); //Set Rear Daylight 35%
     ReefAngel.PWM.SetChannel( 4,(50) ); //Set Rear Actinics 50%
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==61200)) //if it is 5 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<9000) {
  // Continue NTM for the 2 hours 30 minutes
} else if (now()%SECS_PER_DAY<1800 || now()%SECS_PER_DAY>=52200) { // 12:30am / 2:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=Lagoon;
  ReefAngel.DCPump.Speed=15;
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
    ReefAngel.Portal( "GugsJr" );
    ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
//Custom Main, Graph & Menu
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
 ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "GugsJr’s ReefAngel");
 ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
  ReefAngel.LCD.DrawLargeText(0,255,10,16,"  Jebao Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
  ReefAngel.LCD.DrawLargeText(0,255,17,49,"Display Temp");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,14,89, "Jebao Left");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,19,100, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,37,89, "Jebao Center");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,38,100, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "Jebao Right");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetDaylightValue());
void SeasonalTemps ()
  static int heatArray[][2] = { {780,785},// default in case of error in month=0 (June)
                    {770,774},//January (winter) 77.2
                    {774,778},//February (winter) 77.6
                    {775,779},//March (early spring) 77.7
                    {779,783},//April (spring) 78.1
                    {785,789},//May (spring) 78.7
                    {792,796},//June (early summer) 79.4
                    {799,803},//July (summer) 80.1
                    {806,810},//August (summer) 80.8
                    {796,800},//September (early fall) 79.8
                    {787,791},//October (fall) 78.9
                    {780,784},//November (fall) 78.2
                    {775,779} };//December (early winter) 77.7
ReefAngel.StandardHeater(Port5,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port3,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardHeater(Box1_Port5,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start cloud after 5pm
#define Start_Cloud_After NumMins(17,00)
#define Lightning_Change_per_Cloud 0
  // Add Random Lightning modes
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = {Calm,};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      else x=35;
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
// RA_STRING2=null
// RA_STRING3=null
Re: auto feed code not working.
Try changing this line:
to something like this.
if (hour()==17 && minute()==0 && second() <= 2)
GugsJr
Post by GugsJr »
Thank you
That worked great. Now a new problem arose.
I also feed the fish Mysis shrimp at 9pm. Is there a way to get port 6 to stay off at 9pm?
GugsJr
Post by GugsJr »
Would this work?
I just change the code from between 60 secs and 61 secs passed to turn on. To if it's a set time?
//AutoFeeder
if (hour()==17 && minute()==0 && second() <= 2)//if it is 5 pm
iif (hour()==17 && minute()==1 && second() <= 1)//if it is 5:01.01 pm
autofeeding = 0;
