Hi all....first off, here's my code
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Portal( "skehole" );
ReefAngel.DDNS( "fish tank" ); // Your DDNS is skehole-fish tank.myreefangel.com
On my currently unused relay 4 I would like to program my reefbrite to come on at 11am and off at 9pm. No ramping or nothing. Simply on and then off. Can someone assist me? TIA!
Internal Mem Coding on and off help
Re: Internal Mem Coding on and off help
Have you tried using the wizard?
Also, don't use a space on your DDNS.
It will mess up the communication with the portal.
Spaces are not part of the HTTP protocol.
skehole
I have not used the wizard, I was already running this and was wondering if there was a way to add in a line or whatever of code.rimai wrote:Have you tried using the wizard?
Yeah, I fixed that on my actual code. That was cut and pasted from the thread where we came to the same conclusion about the Ddns.
