Temp probs reading 00.0
I have 3 temp probes and all three all of a sudden are reading 00.0 I reset the controller with no luck. What would cause all 3 to read 00.0?
Re: Temp probs reading 00.0
Just tried reloading program and still no luck.
If you got them on eBay like I did, the pins were reversed on mine.
No I've had these for awhile and they all worked then bam all three just read zero
Check for water damage and try one at a time.
Everytime you remove or insert a probe, make sure to power cycle to get the controller to recognize it.
It only scans for new probes on reboot.
Ok that did the trick thanks for the help
