Someone asked me if I would be able to adjust intensity of my LED's just by using the joystick on the Head Unit. I honestly didn't know, so I'm here to ask if this is possible?
Let me try to ask this as simply as possible. To do that, I'll break it down into 2 questions:
1. Can I override the current lighting schedule and manually select the intensity of my LED channels from choosing menu options with the joystick? (IE, can I goto main menu -> Select Daylight -> Turn knob to pick from 0% to 100% ?) If so, will it remain at this manual setting until I change it back, or will it switch back to automatic settings at the next lighting period cycle?
2. Is it possible to change the Daylight (or Actinic) channel schedule directly from the joystick, or will I need to re-upload new settings to the Head Unit from one of the software programs (RA Gen, RA Status, or RA Client?) every time I want to change time period and/or intensity settings.
The reason I'm curious is because I plan to acclimate my system to my new LEDs, and therefore will be changing the lighting schedule quite often for a few weeks. From what I understand (from the person who asked me if I could do this), I would need to recalibrate the pH probe everytime I upload new code... is that true? If so, I would just not use the pH probe until after my lighting acclimation period is over.
Sorry if these seem like a simple questions, but since I don't even have my controller in hand to see what it can do, all I can do is ask others. Thanks in advance.
George
