Seasonal Temperatures
Reefology
Post by Reefology »
void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
hi, saw this and would love to add this to my ino but am worried I won't implement it properly.
is there anything I need to change or remove from my current code?
    InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800)
    ReefAngel.DCPump.Mode=ReefCrest;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,70,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    else if (InternalMemory.DCPumpMode_read()==11)
    ReefAngel.Portal( "" );
    ReefAngel.DDNS( "" ); // Your DDNS is
Re: Seasonal Temperatures
you will want to change the port in the seasonaltemps function to use port3, like your code.
then you will want to remove /comment out the standardheater function call from your loop and instead just call SeasonalTemps(); function.
it shouldn't affect anything else. the only other thing to check on is your overheat temperature value and make sure it is higher than the temperatures listed in the seasonaltemps function.
Reefology
Post by Reefology »
thats awesome, thanks Curt.
is there a way to do something similar with my lighting? i.e.. longer days when it's warmer and shorter days when the water is cooler.
in theory, you certainly could. if you did it this way, you would have to hard code the light schedule instead of using the memory (although you could do memory, it would just be more complicated).
do you have an idea of what what the light schedule would be?
would there be a ramp up or ramp down for leds or is it just an outlet turning on/off?
Reefology
Post by Reefology »
I don't want anything complicated so hard code would be just fine. I currently ramp my white leds from 0 to 65 on slope over 90 mins and my actinics from 0 to 80 over 90 mins as well.
how would I go about hard coding this?
to do it, you will need to create an array of the parameters that would be used. if the slope ranges always stay the same, then that will simply things. I'm assuming that they will and you will be adjusting the overall total daylight.
so, what I would start with is creating an array of start/stop times for the daylight, like the low and high temps.
{8,0,16,0} - on at 8am and off at 1600 (4p). so on hour, on minute, off hour, off minute.
make an array for all the months of the year.
once you have that, then we need a function that calls the sloping of the lights with the hard coded values based on the month. like the temp calls the hard coded standardheater function with values.
that's a start for you.
Reefology
Post by Reefology »
Thanks for your help Curt
so something like this for daylight on port 2?
void SeasonalDaylight ()
  static int heatArray[][2] = { {13,0,22,0},// default in case of error in month=0 (May)
                    {15,0,22,0},//January (winter)
                    {14,30,22,0},//February (winter)
                    {14,0,22,0},//March (early spring)
                    {13,30,22,0},//April (spring)
                    {13,0,22,0},//May (spring)
                    {12,30,22,0},//June (early summer)
                    {12,0,22,0},//July (summer)
                    {12,30,22,0},//August (summer)
                    {13,0,22,0},//September (early fall)
                    {13,30,22,0},//October (fall)
                    {14,0,22,0},//November (fall)
                    {14,30,22,0} };//December (early winter)
  ReefAngel.DayLights( Port2,heatArray[month()][0],heatArray[month()][1]);
 }//end SeasonalDaylight
and actinics on port 1
void SeasonalActiniclight ()
  static int heatArray[][2] = { {12,30,22,30},// default in case of error in month=0 (May)
                    {14,30,22,30},//January (winter)
                    {14,0,22,30},//February (winter)
                    {13,30,22,30},//March (early spring)
                    {13,0,22,30},//April (spring)
                    {12,30,22,30},//May (spring)
                    {12,0,22,30},//June (early summer)
                    {11,30,22,30},//July (summer)
                    {12,0,22,30},//August (summer)
                    {12,30,22,30},//September (early fall)
                    {13,0,22,30},//October (fall)
                    {13,30,22,30},//November (fall)
                    {14,0,22,30} };//December (early winter)
  ReefAngel.ActinicLights( Port1,heatArray[month()][0],heatArray[month()][1]);
 }//end SeasonalActinics
thats my best guess at coding :D not sure how to ramp lights up via slope or adjust the intensity by month/season?
thanks
close, but you need some tweaking. give me a few hours to tweak it some for you and I'll post some code for you to test
Do you have 2 sets of lights? Looking at your code, you toggle Port 1 for your Actinic lights and Port 2 for your Daylight Lights. Plus, you also have the PWM channels using the ActinicPWMSlope and DaylightPWMSlope.
I'm assuming that you have the power supplies for your LEDs plugged into the Relay Box and you just turn the power supplies off when you want the LEDs to be off in addition to dimming them down.
Is this correct?
Reefology
Post by Reefology »
I have one set of lights. I use pwm channels for the same lights because they dim down low but won't shut down completely unless they are plugged into the relay box. I would like to use those ports for something else, is there a way to shut them down with the pwm alone?
Reefology wrote:I have one set of lights. I use pwm channels for the same lights because they dim down low but won't shut down completely unless they are plugged into the relay box. I would like to use those ports for something else, is there a way to shut them down with the pwm alone?
Often times if you set the PWM value to 0, it will shut the lights off. My old set of LED's would only dim down to like 20% and then I had to set them to 0 to get them to shut off.
I would suggest testing out setting the pwm value to 0 for the channels to see if that shuts the light off completely. If it does, then your problem is solved and we can just set the value to 0 to shut off the lights completely and you will be able to plug the power supplies into a regular outlet and not one of the RA outlets. If it does not shut off the lights completely, then you will need to toggle the port to shut off the lights like you are currently doing.
Reefology
Post by Reefology »
I think I've been doing that all along, the portal indicates 0%, but the lights stay very low when plugged into regular outlet.
Reefology
Post by Reefology »
btw, thanks for helping me with this Curt, really appreciate it!
Ok. With that being said, you will probably need to continue doing the relay toggling. Here's some code for you to test out. I have it toggling the relay port and put a comment in about removing the line if you didn't need to toggle the port. Also, I have the outlets turn on at the specified times in the arrays and the lights start to slope up/down appropriately. The slope values / percentages are based off of the internal memory values BUT could be changed and handled in the code if you wanted to (it would be pretty simple actually).
Just so you know, I just copied the code for the PWM slope function and tweaked it so it could be controlled manually outside of the libraries.
Anyways, here's the code. I know it compiles against the libraries version 1.1.3. I just tested the compile but I have not uploaded it to a controller to test out everything fully. The only thing that I changed was the code for the lights. So, you will want to verify that the times used for the lights are what you want.
  static int daylightArray[][4] = {
    {13,0,22,0},  // default in case of error in month=0 (May)
    {15,0,22,0},  //January (winter)
    {14,30,22,0}, //February (winter)
    {14,0,22,0},  //March (early spring)
    {13,30,22,0}, //April (spring)
    {13,0,22,0},  //May (spring)
    {12,30,22,0}, //June (early summer)
    {12,0,22,0},  //July (summer)
    {12,30,22,0}, //August (summer)
    {13,0,22,0},  //September (early fall)
    {13,30,22,0}, //October (fall)
    {14,0,22,0},  //November (fall)
    {14,30,22,0}  //December (early winter)
  // Port 2 is power supply for Day lights
  ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(
    daylightArray[month()][0],
    daylightArray[month()][1],
    daylightArray[month()][2],
    daylightArray[month()][3],
    InternalMemory.PWMSlopeStartD_read(),
    InternalMemory.PWMSlopeEndD_read(),
    InternalMemory.PWMSlopeDurationD_read(),
    ReefAngel.PWM.GetDaylightValueRaw()
  TODO comment out the next line if the power supply for the lights is not needed
       and the lights are plugged into a power strip. Otherwise, if the lights
       are plugged into the relay, you will need to toggle the port to turn
       the lights off
  ReefAngel.StandardLights(Port2, daylightArray[month()][0], daylightArray[month()][1],
                                  daylightArray[month()][2], daylightArray[month()][3]);
  static int actinicArray[][4] = {
    {12,30,22,30},  // default in case of error in month=0 (May)
    {14,30,22,30},  //January (winter)
    {14,0,22,30},   //February (winter)
    {13,30,22,30},  //March (early spring)
    {13,0,22,30},   //April (spring)
    {12,30,22,30},  //May (spring)
    {12,0,22,30},   //June (early summer)
    {11,30,22,30},  //July (summer)
    {12,0,22,30},   //August (summer)
    {12,30,22,30},  //September (early fall)
    {13,0,22,30},   //October (fall)
    {13,30,22,30},  //November (fall)
    {14,0,22,30}    //December (early winter)
  // Port 1 is power supply for Actinic Lights
  ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(
    actinicArray[month()][0],
    actinicArray[month()][1],
    actinicArray[month()][2],
    actinicArray[month()][3],
    InternalMemory.PWMSlopeStartA_read(),
    InternalMemory.PWMSlopeEndA_read(),
    InternalMemory.PWMSlopeDurationA_read(),
    ReefAngel.PWM.GetActinicValueRaw()
       the lights off
  ReefAngel.StandardLights(Port1, actinicArray[month()][0], actinicArray[month()][1],
                                  actinicArray[month()][2], actinicArray[month()][3]);
    //ReefAngel.ActinicLights( Port1 );
    //ReefAngel.DayLights( Port2 );
    // Light code
    SeasonalDaylight();
    SeasonalActiniclight();
    //ReefAngel.PWM.DaylightPWMSlope();
    //ReefAngel.PWM.ActinicPWMSlope();
    // Wavemaker
    static int rmode;
    changeMode=false;
    // Night/Quiet mode
    //Storm mode
Hopefully everything makes sense to you. If you need to alter any of the times, you should be able to figure it out from the code (arrays). This code also allows for both the Actinic and Daylight channels to be controlled independently. We could simplify things if they always used the same schedule OR if they were always 30 minutes (or whatever time offset) apart.
Let me know if you have any further questions or comments.
Reefology
Post by Reefology »
that looks great Curt, I'll give it a try.
I do have a questions though:
how does the controller use the default month? and why do we need it?
{774,778},// default in case of error in month=0 (May)
thanks a bunch!
that's added in for 2 reasons: 1) on the off chance the controller gets a 0 returned when it calls the month function, which should never happen since there's not a month 0 but you never know (so it's a sanity check) 2) the month function returns a value between 1 and 12 inclusive. arrays in c/c++ always start with an index of zero. since there's not a zero month, in order for the months to match up with the indices, you would either have to subtract 1 from the month function call (which there is lots of them) or you pad the array (like we did). either option would work, however our option would result in less instructions/operations being called and it's a simple index to the array. it can also yield a little easier to read code as well.
so the default values should never be used but are there just in case. hopefully this explanation makes sense.
