The code you attached is the reefangelsimple code.
The problem that you had was caused by not having an initial internal memory file loaded into the controller.
You can generate your own internal memory file with RAGen, or you can just load the one below.
After that, you can load your own PDE and it should stop the clicks.
// Autogenerated file by RAGen (v1.2.0.140), (01/31/2012 21:45)
// Memory_013112_2145.pde
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
#include <ReefAngel_EEPROM.h>
Phillips6610LCDInv e;
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOffHour_write(15);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(15);
InternalMemory.LEDPWMActinic_write(50);
InternalMemory.LEDPWMDaylight_write(50);
InternalMemory.WM1Timer_write(200);
// display the values
char buf[128];
sprintf(buf, "MH %2d:%02d-%2d:%02d,%d", InternalMemory.MHOnHour_read(), InternalMemory.MHOnMinute_read(),
InternalMemory.MHOffHour_read(), InternalMemory.MHOffMinute_read(),
InternalMemory.MHDelay_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, buf);
sprintf(buf, "Std %2d:%02d-%2d:%02d", InternalMemory.StdLightsOnHour_read(), InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(), InternalMemory.StdLightsOffMinute_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, buf);
sprintf(buf, "LED A: %d%% D: %d%%", InternalMemory.LEDPWMActinic_read(), InternalMemory.LEDPWMDaylight_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*3, buf);
sprintf(buf, "WM1: %ds", InternalMemory.WM1Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, buf);
sprintf(buf, "WM2: %ds", InternalMemory.WM2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, buf);
sprintf(buf, "F: %ds", InternalMemory.FeedingTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*6, buf);
sprintf(buf, "S: %ds", InternalMemory.LCDTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*7, buf);
sprintf(buf, "H On: %d -> %d", InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*9, buf);
sprintf(buf, "C On: %d -> %d", InternalMemory.ChillerTempOn_read(), InternalMemory.ChillerTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*10, buf);
sprintf(buf, "PH %d - %d", InternalMemory.PHMax_read(), InternalMemory.PHMin_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*11, buf);
delay(10000);
sprintf(buf, "OH: %dF", InternalMemory.OverheatTemp_read());
sprintf(buf, "ATO L: %ds (%dh)", InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
sprintf(buf, "ATO H: %ds (%dh)", InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
sprintf(buf, "DP1: %2d:%02d", InternalMemory.DP1OnHour_read(), InternalMemory.DP1OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP1Timer_read());
sprintf(buf, "DP2: %2d:%02d", InternalMemory.DP2OnHour_read(), InternalMemory.DP2OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*8, buf);
delay(10000);
