led dimming to led on/off ports
troylong45
Post by troylong45 »
i want to add update led code i tryed my self from code from lnevo but it dont do anything i moved controller to my moms tank so none of my old code works with this when i remove parts i dont want
what do i need to add/remove to have port 3 turn on when dimming add-on channel 0 is grater then 0% and and off if at 0%
what do i need to add/remove to have port 4 turn on when dimming add-on channel 1 is grater then 0% and and off if at 0%
        // Define Custom Memory Locations
        #define Mem_B_AtoHourInterval     101
void init_memory() {
          // Initialize Custom Memory Locations
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //mb101
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.SingleATO(true, Port1 , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
    ReefAngel.StandardLights( Port3,9,0,19,0 );
    ReefAngel.StandardLights( Port4,9,0,19,0 );
    ReefAngel.StandardHeater( Port5,775,785 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,65,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,45,0) );
    ReefAngel.DCPump.SetMode( NutrientTransport,70,10 );
    ReefAngel.DCPump.ExpansionChannel[4] = Sync;
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
    ReefAngel.Portal( "troylong45" );
Re: led dimming to led on/off ports
troylong45 wrote: what do i need to add/remove to have port 3 turn on when dimming add-on channel 0 is grater then 0% and and off if at 0%
This should work for the standard PWM expansion device (with 6 channels)
You would need something like this inside your loop() section:
if (ReefAngel.PWM.GetChannelValue(0) > 0) {
   // Value over 0%
   ReefAngel.Relay.On(Port3);
   // otherwise, value IS 0 or less (which should never happen)
   ReefAngel.Relay.Off(Port3);
troylong45 wrote: what do i need to add/remove to have port 4 turn on when dimming add-on channel 1 is grater then 0% and and off if at 0%
And for this one...
if (ReefAngel.PWM.GetChannelValue(1) > 0) {
   // Value over 0%
   ReefAngel.Relay.On(Port4);
   ReefAngel.Relay.Off(Port4);
Then, I would also remove these lines too:
Because they will override the port status from the PWM channels.
So, your loop section would look like this:
   // Value over 0%
   // Value over 0%
troylong45
Thanks ill try that i think the code I was trying was missing some of These symbols }{ or actually I think there was a { be for the "if" command. That might be why so it never was reading the if or maybe else reading , cus it would force the lights on no matter % or relay overuse setting I would set
Ill be back if i get no where
Is there a code for dummies section like what call outs are and mean and commands
There's not really a section or manual that spells out what all the functions are and how to use them or what they mean. The data is scattered throughout the forum and it ultimately lies inside the libraries. I think there was an effort to do this a while back but I do not know off hand if anything was finished or worked on.
troylong45
it worked great thanks
libraries would help me understand more on my own?
troylong45 wrote:it worked great thanks
yes, looking at the libraries will (or should) help you understand better. if you can understand the code and how things function, it could benefit you.
troylong45
get the if ,else deal .
Like what maybe "if(X LOCATION(X VALUE) = X VALUE"
it is looking for the location to be = to value
And will make "{X LOCATION (X COMMAND) ; }else{X LOCATION (X COMMAND) ; }
So maybe
if (reefangel.pwm.daylights) = 50 { reefangle.relay.on(port6) ; }else{reefangle.relay.off(port6) ; }
If spelled correct+correct location and capitalized correctly then that make
Relay box main port 6 on only if daylights is 50% and off if not
yeah, you got the right idea (and yes, if you use proper capitalization and formatting)
troylong45
Then the rest is just kinda math and calling out What's already been created.
I realize there is way more behind the scenes when I opened lib. On dropbox Lol
Is the wave pattern topic up todate I was trying to find that info on drop box but must have missed it I wanna try to take a crack at adapting the dcpump mode to my liking and pumps and to find sync and antisync off sets (plus or minus value)
troylong45 wrote:Then the rest is just kinda math and calling out What's already been created.
yes, that topic is up-to-date, however there is some additional information that is in a post towards the end of the thread. not sure how critical it is but I'm pretty sure it is important (something like saying the wave forms are built in the libraries or something like that). just make sure you read through the entire thread and not just the first post.
one thing to note is that you may have to experiment with the settings and modes. I have some gyres that won't do some of the modes and I found out during testing.
