led dimming to led on/off ports
Posted: Fri May 18, 2018 6:30 pm
i want to add update led code i tryed my self from code from lnevo but it dont do anything i moved controller to my moms tank so none of my old code works with this when i remove parts i dont want
what do i need to add/remove to have port 3 turn on when dimming add-on channel 0 is grater then 0% and and off if at 0%
what do i need to add/remove to have port 4 turn on when dimming add-on channel 1 is grater then 0% and and off if at 0%
// Define Custom Memory Locations
#define Mem_B_AtoHourInterval 101
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write(Mem_B_AtoHourInterval,1); //mb101
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.SingleATO(true, Port1 , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
ReefAngel.StandardLights( Port3,9,0,19,0 );
ReefAngel.StandardLights( Port4,9,0,19,0 );
ReefAngel.StandardHeater( Port5,775,785 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,65,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,45,0) );
ReefAngel.DCPump.SetMode( NutrientTransport,70,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.DCPump.ExpansionChannel[4] = Sync;
ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
ReefAngel.Portal( "troylong45" );
