RA* Unable to Update via Remote Upload
ReefingHavoc
Post by ReefingHavoc »
I've got my RA* up and running with the exception of being able to update the code via Remote Upload through the wizard.
  • The unit is showing connected to the cloud
    I'm able to check the status and turn ports on/off through uapp
    If I connect via a com port on my PC I can upload code
Any thoughts?
Here's my code:
    ReefAngel.Star();
    ReefAngel.FeedingModePortsE[0] = Port2Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[1] = 0;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPortsE[1] = 0;
    ReefAngel.LightsOnPortsE[1] = 0;
    ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,83 );//Alk
    ReefAngel.SingleATO( true,Box1_Port2,1000,0 );//ATO
    ReefAngel.DosingPumpRepeat( Box1_Port3,30,60,82 );//Cal
    ReefAngel.StandardHeater( T1_PROBE,Box1_Port4,780,785 );
    ReefAngel.StandardLights( Box1_Port6,12,0,19,0 ); //T5
    ReefAngel.StandardLights( Box1_Port7,23,0,6,0 ); //Refugium Lights
    ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
    ReefAngel.DCPump.SetMode( LongPulse,80,60000 );
    ReefAngel.DCPump.Daylight2Channel = AntiSync;
    ReefAngel.DCPump.Actinic2Channel = None;
    boolean buzzer=false;
    if ( ReefAngel.isATOTimeOut() ) buzzer=true;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff();
	 static unsigned long feeding;
    //feeding mode nutrient transport time
    if (now()-feeding<3600) {
        ReefAngel.DCPump.SetMode(NutrientTransport,100,4000);
    //vacation mode
    if (hour()==17 && minute()==0 && second()==0)
        ReefAngel.FeedingModeStart();
    if (hour() > 21 || hour() < 7)
        ReefAngel.DCPump.SetMode( Lagoon,60,10 );
    if (hour() >= 8 || ReefAngel.Params.PH > 860)
        ReefAngel.Relay.Off (Box1_Port1);
        ReefAngel.Relay.Off (Box1_Port3);
    ReefAngel.Network.Cloud();
    ReefAngel.ShowTouchInterface();
Re: RA* Unable to Update via Remote Upload
This code seems to be missing something at the end.
ReefingHavoc
I didn’t paste the commented out code that includes the encrypted password. Is that what you meant?
Yes. I just wanted to make sure they were there
ReefingHavoc
Checking back in to see if anyone has ideas on this. I'm still unable to upload remotely. Not sure if something is going on with the unit as I see what looks like a download message periodically (see image below). It is not there all the time, but when it is, always says 1%.
Not sure why it is not downloading for you.
I just tested this and it worked.
ReefingHavoc
Any other thought out there? It’s not only frustrating that I can’t remote upload, but can’t receive alerts either
Is there anything with my router that I should be looking at?
Connect to your computer and use Arduino to get the serial monitor log.
ReefingHavoc
Here is what I get:
10.0.0.23
Portal Call
MQTT Connecting...
MQTT failed
Disconnected
Connecting...
10.0.0.23
Connected
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
Server: Microsoft-IIS/8.5
X-Powered-By: PHP/5.6.24
Date: Wed, 12 Sep 2018 00:14:32 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
MQTT Connecting...
MQTT succeeded
I don't think your controller is configured correctly.
If you browse to http://10.0.0.23:2000/r99 , what do you get?
ReefingHavoc
<RA>
<ID>ReefingHavoc</ID>
<T1>0</T1>
<T2>0</T2>
<T3>0</T3>
<PH>852</PH>
<R>0</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>144</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>1</EM>
<EM1>6</EM1>
<REM>1</REM>
<BID>4</BID>
<AF>0</AF>
<SF>0</SF>
<PWMA>0</PWMA>
<PWMD>80</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<PWMA2>0</PWMA2>
<PWMD2>0</PWMD2>
<PWMA2O>255</PWMA2O>
<PWMD2O>255</PWMD2O>
<DCM>4</DCM>
<DCS>80</DCS>
<DCD>100</DCD>
<DCT>30</DCT>
<LEAK>0</LEAK>
<ALARM>0</ALARM>
<PWME0>0</PWME0>
<PWME0O>255</PWME0O>
<PWME1>0</PWME1>
<PWME1O>255</PWME1O>
<PWME2>0</PWME2>
<PWME2O>255</PWME2O>
<PWME3>0</PWME3>
<PWME3O>255</PWME3O>
<PWME4>0</PWME4>
<PWME4O>255</PWME4O>
<PWME5>0</PWME5>
<PWME5O>255</PWME5O>
</RA>
ReefingHavoc
More came through on the monitor:
Portal Call
Data Sent
HTTP/1.1 200 OK
Cache-Control: private
Content-Type: text/html; charset=utf-8
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Date: Wed, 12 Sep 2018 00:19:33 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Ok, so whatever you did a while ago made the controller connect to the portal.
http://forum.reefangel.com/status/chart ... &filter=ph
You can see that it started sending data about half hour ago.
So, you should be able to set your email alerts now.
Try doing the remote upload again.
ReefingHavoc
Thought I'd close the loop on this. I had my connection running through a patch panel that was connected to a AT&T U-verse router. I did some troubleshooting to determine where the problem was as when I connected the RA* directly to a Netgear router, everything seemed to work. Patch panel and all connections turned out to be fine. Tried running the patch panel to the Netgear instead of U-verse and miraculously I'm able to able to now upload remotely and updates hitting the portal. Strange...
ReefingHavoc
ReefingHavoc wrote:Thought I'd close the loop on this. I had my connection running through a patch panel that was connected to a AT&T U-verse router. I did some troubleshooting to determine where the problem was as when I connected the RA* directly to a Netgear router, everything seemed to work. Patch panel and all connections turned out to be fine. Tried running the patch panel to the Netgear instead of U-verse and miraculously I'm able to able to now upload remotely and updates hitting the portal. Strange...
I guess it was too good to be true. I haven't touched the RA* since Sunday, but it looks like it stopped communicating yesterday (see attached)
ReefingHavoc
Any thoughts on what is going on? The unit will connect for short periods of time and all of a sudden stop updating to the portal (still shows connected on the unit). I've tried swapping out power cables, ethernet cables, connecting to different routers, observing traffic through a serial monitor. Just today the unit had a black screen and unresponsive to touch. I had to reboot it by unplugging and when it did, saw that the temperature in the tank dropped by 3 degrees. The RA+ was rock solid for years; not sure why I'm having so many issues.
When you were watching the monitor, what did you get when it was not communicating?
ReefingHavoc
rimai wrote:When you were watching the monitor, what did you get when it was not communicating?
I had it connected to a monitor for a couple hours and did not see issues, but when I plugged it back in to the power supply it stopped updating shortly after. I'll run a monitor on it for 24hrs to see what happens. The problem has been that my tank is in the basement and my PC is on the first floor so I have to disconnect the RA* from my system to monitor. I'll figure out how to keep it connected to the system with monitoring in place.
Thanks for the follow up
Mike
ReefingHavoc
I ran the monitor for 24 hours and did capture a 400 error at the time the Portal stopped being updated.
Data: 0
Header: 0
Disconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Sun, 23 Sep 2018 14:20:17 GMT - This is the time when Portal last updated
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Date: Sun, 23 Sep 2018 14:20:18 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Portal Call
Actinic 2Data Sent
Actinic 2HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Sun, 23 Sep 2018 14:25:18 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ÿDisconnected
Actinic 2Connecting...
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:25:19 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Disconnected
Actinic 2Portal Call
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:30:19 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:30:20 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:35:20 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:35:21 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:40:21 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:40:22 GMT
Connection: close
Content-Length: 339
The 400 error captured repeats until 6 PM EST when I disconnected the monitor
ReefingHavoc
Any thoughts on the 400 error?
Let me check the server log and see what the request looked like.
I couldn't find any log.
Maybe the server doesn't log this type of error.
I don't know what to make out of this.
Does it get disconnected from the cloud server too?
ReefingHavoc
No
ReefingHavoc
Any further thoughts on this?
Not sure.
I don't understand how it stays connected when you are monitoring by itself and not when you bring downstairs.
ReefingHavoc
The unit says connected and I can do things like turn on/off ports and clear alerts through my phone. The problem is that for some reason it stops connecting to the Portal after some time which prohibits me from sending remote uploads and receiving any email alerts or updates to the Portal. There is no difference on where it is located.
The reference to taking it downstairs had to do with troubleshooting. I originally thought the problem was where it was connected, thinking it was a networking issue. I proved that wrong by setting up the monitor and verifying that the device was logging a 400 error after some time. I left the monitor on for 24 hours and it never reconnected to the portal after the 400 errors started.
I am wondering if it does the same with a very basic code with just the cloudportal function.
ReefingHavoc
Let me know if you want me to test something
Try running a new code with just the cloudportal function and monitor.
ReefingHavoc
I uploaded the following to the RA*:
ReefAngel.Star();
After leaving it on the monitor for nearly 24 hours it looks like everything is going through fine. Here's my first and last monitor logs.
Connecting...
Connected
HTTP/1.1 200 OK
Date: Mon, 22 Oct 2018 23:53:10 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Tue, 23 Oct 2018 06:58:08 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Wed, 24 Oct 2018 05:42:50 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Date: Tue, 23 Oct 2018 22:42:53 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
So it looks like something with the code is causing the problem. What should my next steps be?
