Hi,
I'm wondering if anyone using ethernet to connect to the portal would know if my sketch would be smaller vs using wifi.
I have a first gen board and my understanding is the <RA_Wifi.h> portion of the sketch is quite large. Could I omit it if I use ethernet?
Using Ethernet to Make Sketch Smaller?
Re: Using Ethernet to Make Sketch Smaller?
No, it will not do you any good.
You need the wifi library to use the ethernet too.
