2nd Salinity module w/Cloud Wifi Hub
Hello Roberto,
I know it's not possible to have two salinity probes with a single RA* but is it possible to directly program my Cloud Wifi Hub to directly read a salinity module/probe? Like many others, I'd like to use it at my remote mixing station which I'm trying to automate.
When we were setting up a 2nd dimming module with my Cloud WiFi Hub (used with an RA*) in the below thread,
https://forum.reefangel.com/viewtopic.p ... 2&start=30
You mentioned that I'd have to program the Cloud wifi hub code itself to get lightening effects to work with it - not trying this just yet as my lights are functioning correctly and the room is not setup for that kind of show .
Try to learn something about everything and everything about something... Thomas Huxley
210gal DT | 50gal sump/refug | Jebao DCP 10000 pump | RO 200-int skimmer | DIY built stand | DIY 160 led, 12 channel, 458 watt, on MakersLED 72" heatsink
Re: 2nd Salinity module w/Cloud Wifi Hub
Yes, each cloud wifi hub can be used to have an additional salinity module.
Nice! Could you please help me set it up?
I generated the following code with the Wizard:
and I changed this section to:
but as I read the comments, don't think it was necessary.
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
#include <CloudGlobals.h>
// Change fallback ports below
// Fallback ports will be turned on when cloud connection is lost
// Add each port separated by a |
// For example, if you would like for port 1 and port 5 of Relay Box 1 to be turned on when cloud connection is lost,
// you should add Port1Bit | Port5Bit
// It would look like this:
// #define Relay1FallBack Port1Bit | Port5Bit
#define Relay1FallBack 30
#define Relay2FallBack 0
#define Relay3FallBack 0
#define Relay4FallBack 0
#define Relay5FallBack 0
#define Relay6FallBack 0
#define Relay7FallBack 0
#define Relay8FallBack 0
// Redirect expansion modules to another custom expansion field.
// This is only required if you have multiple modules of the same parameter.
// For example, if you have one Cloud module with an existing salinity module already and wants to add another Cloud module
// with anoter salinity module and report those readings as a Custom Expansion Module 1
// In this case you have to change the CloudCustomModule1 to CUSTOM_SALINITY.
// The values that can be entered are:
// CUSTOM_NONE 0
// CUSTOM_SALINITY 1
// CUSTOM_ORP 2
// CUSTOM_PHEXP 3
// CUSTOM_WL 4
// CUSTOM_MULTI_WL1 5
// CUSTOM_MULTI_WL2 6
// CUSTOM_MULTI_WL3 7
// CUSTOM_MULTI_WL4 8
#define CloudCustomModule1 CUSTOM_NONE
#define CloudCustomModule2 CUSTOM_NONE
#define CloudCustomModule3 CUSTOM_NONE
#define CloudCustomModule4 CUSTOM_NONE
#define CloudCustomModule5 CUSTOM_NONE
#define CloudCustomModule6 CUSTOM_NONE
#define CloudCustomModule7 CUSTOM_NONE
#define CloudCustomModule8 CUSTOM_NONE
// Assign Temperature probes ID
// Only assign temperature probes IDs that you currently are not using in the head unit.
// If you have a total of more than 3 probes, make sure to add the following line on the setup section of the head unit code:
// ReefAngel.AddExtraTempProbes();
// For example, if you only have 1 probe connected to the head unit, assign IDs 2 and 3.
// If you have 2 probes in the head unit and 2 probes in the Cloud Wifi Hub, you must add the above line and you would assign
// IDs 3 and 4.
// Assign ID 0 to unused probes in the Hub.
byte TempProbeIDs[] = {2, 0};
// Do not change anything below
#define LED_GREEN 7
#define LED_BLUE 6
#define LED_RED 0
#define TempPin 5
unsigned long wifi_connection = millis();
int status = WL_IDLE_STATUS;
byte data[2];
byte data2[12];
byte addr[8];
byte addr1[8];
byte addr2[8];
OneWire ds(TempPin);
void MQTTSubCallback(char* topic, byte* payload, unsigned int length);
PubSubClient MQTTClient(MQTTServer, MQTTPORT, MQTTSubCallback, mqttclient);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
pinMode(LED_RED, OUTPUT);
digitalWrite(LED_GREEN, HIGH);
digitalWrite(LED_BLUE, LOW);
digitalWrite(LED_RED, LOW);
wdt_initialize();
wdt_enable();
randomSeed(analogRead(0));
Serial.begin(57600);
Serial.setTimeout(100);
delay(1500);
Serial.println("Init");
Wire.begin();
FoundIP = false;
MQTTReconnectmillis = millis();
MQTTSendmillis = millis();
SalinityFound = false;
ORPFound = false;
PHExpFound = false;
WLFound = false;
MultiWLFound = false;
HumidityFound = false;
sprintf(pub_salinity, "sal");
sprintf(pub_orp, "orp");
sprintf(pub_phexp, "phe");
sprintf(pub_wl, "wl");
sprintf(pub_multiwl, "wl");
sprintf(pub_humidity, "hum");
// Temperature
byte count = 0;
while (ds.search(addr))
if (addr[0] == 0x28)
count++;
if (count == 1) memcpy(addr1, addr, 8);
if (count == 2) memcpy(addr2, addr, 8);
ds.reset_search();
Serial.print(count);
Serial.println(" temperature probe(s) found");
// Relay
for ( byte EID = 0; EID < MAX_RELAY_EXPANSION_MODULES; EID++ )
RelayDataE[EID] = 0;
RelayMaskOnE[EID] = 0;
RelayMaskOffE[EID] = 0xff;
RelayFallBackE[0] = Relay1FallBack;
RelayFallBackE[1] = Relay2FallBack;
RelayFallBackE[2] = Relay3FallBack;
RelayFallBackE[3] = Relay4FallBack;
RelayFallBackE[4] = Relay5FallBack;
RelayFallBackE[5] = Relay6FallBack;
RelayFallBackE[6] = Relay7FallBack;
RelayFallBackE[7] = Relay8FallBack;
// Dimming
lastcrc = -1;
for ( byte a = 0; a < PWM_EXPANSION_CHANNELS; a++ )
ExpansionChannel[a] = 0;
ExpansionChannelOverride[a] = 255;
// IO
Params.IO = 63;
OldParams.IO = 63;
// Leak
Params.Leak = 0;
OldParams.Leak = 0;
// ORP
Params.ORP = 0;
OldParams.ORP = 0;
ORPCal = false;
ORPMin = memory_read_int(Mem_I_ORPMin);
if (ORPMin==65535) ORPMin=0;
ORPMax = memory_read_int(Mem_I_ORPMax);
// Salinity
Params.Salinity = 0;
OldParams.Salinity = 0;
SalCal = false;
SalMax = memory_read_int(Mem_I_SalMax);
// pH Exp
Params.PHExp = 0;
OldParams.PHExp = 0;
PHExpCal = false;
PHExpMin = memory_read_int(Mem_I_PHExpMin);
if (PHExpMin==65535) PHExpMin=0;
PHExpMax = memory_read_int(Mem_I_PHExpMax);
// Humidity
Params.Humidity = 0;
OldParams.Humidity = 0;
// Water Level
for (int a = 0; a < WL_CHANNELS; a++)
Params.WL[a] = 0;
OldParams.WL[a] = 0;
WLCal[a] = false;
WLMin[0] = memory_read_int(Mem_I_WaterLevelMin);
WLMax[0] = memory_read_int(Mem_I_WaterLevelMax);
WLMin[1] = memory_read_int(Mem_I_WaterLevel1Min);
WLMax[1] = memory_read_int(Mem_I_WaterLevel1Max);
WLMin[2] = memory_read_int(Mem_I_WaterLevel2Min);
WLMax[2] = memory_read_int(Mem_I_WaterLevel2Max);
WLMin[3] = memory_read_int(Mem_I_WaterLevel3Min);
WLMax[3] = memory_read_int(Mem_I_WaterLevel3Max);
WLMin[4] = memory_read_int(Mem_I_WaterLevel4Min);
WLMax[4] = memory_read_int(Mem_I_WaterLevel4Max);
for (int a=0; a<5; a++)
if (WLMin[a]==65535) WLMin[a]=0;
ApplyCalibration(1, CloudCustomModule1);
ApplyCalibration(2, CloudCustomModule2);
ApplyCalibration(3, CloudCustomModule3);
ApplyCalibration(4, CloudCustomModule4);
ApplyCalibration(5, CloudCustomModule5);
ApplyCalibration(6, CloudCustomModule6);
ApplyCalibration(7, CloudCustomModule7);
ApplyCalibration(8, CloudCustomModule8);
sprintf(clientid, "%s%02d", CLOUD_USERNAME, random(10000));
sprintf(pub_buffer, "%s/in", CLOUD_USERNAME);
sprintf(sub_buffer, "%s/out/#", CLOUD_USERNAME);
Serial.println("Start");
wdt_reset();
status = WiFi.status();
while ( status != WL_CONNECTED) {
if (millis() - wifi_connection > 1000)
Serial.print("Attempting to connect to Network named: ");
Serial.println(WIFI_SSID); // print the network name (SSID);
if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
server.begin(); // start the web server on port 2000
printWifiStatus(); // you're connected now, so print out the status
digitalWrite(LED_BLUE, HIGH);
MQTTClient.loop();
if (millis() - MQTTReconnectmillis > 5000)
if (!MQTTClient.connected())
Serial.println(F("MQTT Connecting..."));
wdt_reset();
if (MQTTClient.connect(clientid, CLOUD_USERNAME, CLOUD_PASSWORD))
Serial.println(F("MQTT succeeded"));
digitalWrite(LED_RED, HIGH);
MQTTClient.subscribe(sub_buffer);
Publish(pub_buffer, "all:0");
wdt_reset();
Serial.println(F("MQTT failed"));
MQTTClient.disconnect();
// Relay
byte TempRelay = RelayDataE[EID];
TempRelay &= RelayMaskOffE[EID];
TempRelay |= RelayMaskOnE[EID];
TempRelay = RelayFallBackE[EID];
Wire.beginTransmission(I2CExpModule + EID);
Wire.write(~TempRelay); // MSB
Wire.endTransmission();
// Dimming
byte thiscrc = 0;
thiscrc += ExpansionChannel[a] * (a + 1);
thiscrc += ExpansionChannelOverride[a] * (a + 1);
if (millis() % 60000 < 200) lastcrc = -1;
if (lastcrc != thiscrc || millis() < 5000)
lastcrc = thiscrc;
// setup PCA9685 for data receive
// we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
Wire.beginTransmission(I2CPWM_PCA9685);
Wire.write((uint8_t)0);
Wire.write(0xa1);
int data;
if (ExpansionChannelOverride[a] <= 100)
data = ExpansionChannelOverride[a] * 40.96;
data = ExpansionChannel[a] * 40.96;
Wire.write(0x8 + (4 * a));
Wire.write(data & 0xff);
Wire.write(data >> 8);
if (MQTTClient.connected())
// IO
Wire.requestFrom(I2CIO_PCF8574, 1);
if (Wire.available())
Params.IO = Wire.read();
if (Params.IO != OldParams.IO)
OldParams.IO = Params.IO;
sprintf(buffer, "io:%d", Params.IO);
Publish(pub_buffer, buffer);
// Leak
int iLeak = 0;
Wire.requestFrom(I2CLeak, 2);
iLeak = Wire.read();
iLeak = iLeak << 8;
iLeak += Wire.read();
Params.Leak = iLeak > 2000;
if (Params.Leak != OldParams.Leak)
OldParams.Leak = Params.Leak;
sprintf(buffer, "leak:%d", Params.Leak);
if (millis() - Paramsmillis > 1000)
Paramsmillis = millis();
// Temperature
if (addr1[0] != 0)
ds.reset();
ds.select(addr1);
ds.write(0xBE); // Read Scratchpad
for (byte i = 0; i < 2; i++)
data[i] = ds.read();
Params.Temp[1] = (data[1] << 8) + data[0]; //take the two bytes from the response relating to temperature
Params.Temp[1] = Params.Temp[1] / 1.6;
if (Params.Temp[1] == 0) Params.Temp[1] = 0;
if (Params.Temp[1] > 850) Params.Temp[1] = 0;
Params.Temp[1] = Params.Temp[1] * 1.8 + 320;
if (Params.Temp[1] != OldParams.Temp[1])
OldParams.Temp[1] = Params.Temp[1];
sprintf(buffer, "t:%d:%d",TempProbeIDs[0], Params.Temp[1]);
if (TempProbeIDs[0]!=0) Publish(pub_buffer, buffer);
if (addr2[0] != 0)
ds.reset();
ds.select(addr2);
Params.Temp[2] = (data[1] << 8) + data[0]; //take the two bytes from the response relating to temperature
Params.Temp[2] = Params.Temp[2] / 1.6;
if (Params.Temp[2] == 0) Params.Temp[2] = 0;
if (Params.Temp[2] > 850) Params.Temp[2] = 0;
Params.Temp[2] = Params.Temp[2] * 1.8 + 320;
if (Params.Temp[2] != OldParams.Temp[2])
OldParams.Temp[2] = Params.Temp[2];
sprintf(buffer, "t:%d:%d",TempProbeIDs[1], Params.Temp[2]);
if (TempProbeIDs[1]!=0) Publish(pub_buffer, buffer);
// ORP
unsigned long temporp = 0;
int iORP = 0;
for (int a = 0; a < 20; a++)
Wire.requestFrom(I2CORP, 2);
iORP = Wire.read();
iORP = iORP << 8;
iORP += Wire.read();
temporp += iORP;
temporp = temporp / 20;
if (temporp != 0)
Params.ORP = map(temporp, ORPMin, ORPMax, 0, 470); // apply the calibration to the sensor reading
Params.ORP = constrain(Params.ORP, 0, 550);
if (pub_orp[0] == 'o') ORPFound = true;
if (ORPCal)
sprintf(buffer, "%sc:%d", pub_orp, temporp);
if (Params.ORP != OldParams.ORP)
OldParams.ORP = Params.ORP;
sprintf(buffer, "%s:%d", pub_orp, Params.ORP);
// Salinity
unsigned long tempsal = 0;
int iSAL = 0;
Wire.requestFrom(I2CSalinity, 2);
iSAL = Wire.read();
iSAL = iSAL << 8;
iSAL += Wire.read();
tempsal += iSAL;
tempsal = tempsal / 20;
if (tempsal != 0)
Params.Salinity = map(tempsal, 0, SalMax, 60, 350); // apply the calibration to the sensor reading
if (pub_salinity[0] == 's') SalinityFound = true;
if (SalCal)
sprintf(buffer, "%sc:%d", pub_salinity, tempsal);
if (Params.Salinity != OldParams.Salinity)
OldParams.Salinity = Params.Salinity;
sprintf(buffer, "%s:%d", pub_salinity, Params.Salinity);
// pH Exp
unsigned long tempphexp = 0;
int iPHExp = 0;
Wire.requestFrom(I2CPH, 2);
iPHExp = Wire.read();
iPHExp = iPHExp << 8;
iPHExp += Wire.read();
tempphexp += iPHExp;
tempphexp = tempphexp / 20;
if (tempphexp != 0)
Params.PHExp = map(tempphexp, PHExpMin, PHExpMax, 700, 1000); // apply the calibration to the sensor reading
Params.PHExp = constrain(Params.PHExp, 100, 1400);
if (pub_phexp[0] == 'p') PHExpFound = true;
if (PHExpCal)
sprintf(buffer, "%sc:%d", pub_phexp, tempphexp);
if (Params.PHExp != OldParams.PHExp)
OldParams.PHExp = Params.PHExp;
sprintf(buffer, "%s:%d", pub_phexp, Params.PHExp);
// PAR
unsigned long temppar = 0;
int iPAR = 0;
Wire.requestFrom(I2CPAR, 2);
iPAR = Wire.read();
iPAR = iPAR << 8;
iPAR += Wire.read();
temppar += iPAR;
temppar = temppar / 20;
if (temppar != 0)
temppar *= 5000; // apply the calibration to the sensor reading
temppar /= 8192;
Params.PAR = temppar;
if (Params.PAR != OldParams.PAR)
OldParams.PAR = Params.PAR;
sprintf(buffer, "par:%d", Params.PAR);
// Humidity
int iHumidity = 0;
int reply[10];
Wire.beginTransmission(I2CHumidity);
Wire.endTransmission(); // For some reason, it needs this to work??? Bug with sensor??
Wire.write(0x3); // 0x3 for read 0x10 for write to registers
Wire.write((byte)0x0); // start at address 0x0 for humidity
Wire.write(2); // request 2 bytes data for humidity or 4 bytes for temperature+humidity
Wire.requestFrom(I2CHumidity, 6); // Request 6 bytes
for (int i=0;i<6;i++)
if(Wire.available()) reply[i] = Wire.read();
if (reply[0]==0x3 && reply[1]==0x2) // The response need to contain function (0x3) and length of data (0x2)
int crc=reply[5];
crc<<=8;
crc+=reply[4];
if (crc == crc16(reply,4))
iHumidity=reply[2];
iHumidity<<=8;
iHumidity+=reply[3];
Params.Humidity=iHumidity;
if (Params.Humidity != OldParams.Humidity)
OldParams.Humidity = Params.Humidity;
sprintf(buffer, "hum:%d", Params.Humidity);
// Water Level
for (int i = 0; i < WL_CHANNELS; i++)
unsigned long tempwl = 0;
int iWL = 0;
if (i == 0)
Wire.requestFrom(I2CWaterLevel, 2);
iWL = Wire.read();
iWL = iWL << 8;
iWL += Wire.read();
tempwl += iWL;
if (tempwl != 0 && pub_wl[0] == 'w') WLFound = true;
Wire.beginTransmission(I2CMultiWaterLevel);
Wire.write(1); // Config Pointer
byte addr = (0xb + i) << 4; // Select which channel to read
addr += 0x03; // Programmable Gain
Wire.write(addr);
Wire.write(0x83);
delay(10); // It takes 10ms for conversion to be completed
Wire.write((uint8_t)0); // Convert Pointer
Wire.requestFrom(I2CMultiWaterLevel, 2); // Request converted value
iWL = Wire.read();
iWL = iWL << 8;
iWL += Wire.read();
tempwl += iWL >> 4;
if (tempwl != 0 && pub_multiwl[0] == 'w') MultiWLFound = true;
tempwl = tempwl / 20;
if (tempwl != 0)
Params.WL[i] = map(tempwl, WLMin[i], WLMax[i], 0, 100); // apply the calibration to the sensor reading
Params.WL[i] = constrain(Params.WL[i], 0, 255);
if (WLCal[i])
if (i == 0)
if (pub_wl[0] == 'c')
sprintf(buffer, "%s%d", pub_custom_wl, tempwl);
sprintf(buffer, "%sc:%d", pub_wl, tempwl);
if (pub_multiwl[0] == 'c')
sprintf(buffer, "%s%d", pub_custom_multiwl, tempwl);
sprintf(buffer, "%sc:%d", pub_multiwl, tempwl);
if (Params.WL[i] != OldParams.WL[i])
OldParams.WL[i] = Params.WL[i];
if (i == 0)
sprintf(buffer, "%s%d", pub_wl, Params.WL[i]);
sprintf(buffer, "%s:%d:%d", pub_wl, i, Params.WL[i]);
sprintf(buffer, "%s%d", pub_multiwl, Params.WL[i]);
sprintf(buffer, "%s:%d:%d", pub_multiwl, i, Params.WL[i]);
ds.reset();
ds.select(addr1);
ds.write(0x44, 0);
ds.reset();
ds.select(addr2);
ds.write(0x44, 0);
void MQTTSubCallback(char* topic, byte* payload, unsigned int length) {
boolean data_found = false;
int payload_data = 0;
byte data_index = 0;
if (payload[0] == 'R' && payload[1] == 'O' && payload[2] == 'F' && payload[3] == 'F' && payload[5] == ':')
data_found = true;
data_index = payload[4] - '0' - 1;
for (byte a = 6; a < length; a++)
if (payload[a] != 10 && payload[a] != 13)
payload_data *= 10;
payload_data += payload[a] - '0';
RelayMaskOffE[data_index] = payload_data;
else if (payload[0] == 'R' && payload[1] == 'O' && payload[2] == 'N' && payload[4] == ':')
data_found = true;
data_index = payload[3] - '0' - 1;
for (byte a = 5; a < length; a++)
payload_data *= 10;
RelayMaskOnE[data_index] = payload_data;
else if (payload[0] == 'R' && payload[2] == ':')
data_found = true;
data_index = payload[1] - '0' - 1;
for (byte a = 3; a < length; a++)
payload_data *= 10;
RelayDataE[data_index] = payload_data;
else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == 'E' && payload[5] == ':')
data_found = true;
data_index = payload[4] - '0';
payload_data *= 10;
ExpansionChannel[data_index] = payload_data;
else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == 'E' && payload[5] == 'O' && payload[6] == ':')
data_found = true;
for (byte a = 7; a < length; a++)
payload_data *= 10;
ExpansionChannelOverride[data_index] = payload_data;
else if (payload[0] == 'O' && payload[1] == 'R' && payload[2] == 'P' && payload[3] == 'C' && payload[4] == ':' && ORPFound)
Serial.println(F("ORP calibration"));
data_found = true;
if (payload[5] == '0')
ORPCal = false;
else if (payload[5] == '1')
ORPCal = true;
else if (payload[5] == '2')
payload_data *= 10;
CalVal1 = payload_data;
else if (payload[5] == '3')
payload_data *= 10;
memory_write_int(Mem_I_ORPMin, CalVal1);
memory_write_int(Mem_I_ORPMax, payload_data);
ORPMin = CalVal1;
ORPMax = payload_data;
ORPCal = false;
else if (payload[0] == 'S' && payload[1] == 'A' && payload[2] == 'L' && payload[3] == 'C' && payload[4] == ':' && SalinityFound)
Serial.println(F("Sal calibration"));
data_found = true;
SalCal = false;
SalCal = true;
payload_data *= 10;
memory_write_int(Mem_I_SalMax, payload_data);
SalMax = payload_data;
SalCal = false;
else if (payload[0] == 'P' && payload[1] == 'H' && payload[2] == 'E' && payload[3] == 'C' && payload[4] == ':' && PHExpFound)
Serial.println(F("PH Exp calibration"));
data_found = true;
PHExpCal = false;
PHExpCal = true;
payload_data *= 10;
payload_data *= 10;
memory_write_int(Mem_I_PHExpMin, CalVal1);
memory_write_int(Mem_I_PHExpMax, payload_data);
PHExpMin = CalVal1;
PHExpMax = payload_data;
PHExpCal = false;
else if (payload[0] == 'W' && payload[1] == 'L' && payload[3] == 'C' && payload[4] == ':' && (WLFound || MultiWLFound))
Serial.println(F("WL calibration"));
data_found = true;
data_index = payload[2] - '0';
WLCal[data_index] = false;
if (data_index == 0 && WLFound)
WLCal[data_index] = true;
if (data_index > 0 && MultiWLFound)
payload_data *= 10;
payload_data *= 10;
if (data_index == 0)
memory_write_int(Mem_I_WaterLevelMin, CalVal1);
memory_write_int(Mem_I_WaterLevelMax, payload_data);
if (data_index > 0 && data_index < 5)
memory_write_int(Mem_I_WaterLevel1Min + (data_index * 2) - 2, CalVal1);
memory_write_int(Mem_I_WaterLevel1Max + (data_index * 2) - 2, payload_data);
WLMin[data_index] = CalVal1;
WLMax[data_index] = payload_data;
else if (payload[0] == 'C' && payload[1] == 'E' && payload[2] == 'X' && payload[3] == 'P' && payload[5] == 'C' && payload[6] == ':')
Serial.println(F("Custom Exp calibration"));
data_found = true;
if (payload[7] == '0')
if (pub_salinity[0] == 'c' && CustomExpansion[data_index] == CUSTOM_SALINITY) SalCal = false;
if (pub_orp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_ORP) ORPCal = false;
if (pub_phexp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_PHEXP) PHExpCal = false;
if (pub_wl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_WL) WLCal[0] = false;
for (int a = 1; a < WL_CHANNELS; a++)
if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] >= CUSTOM_MULTI_WL1 && CustomExpansion[data_index] <= CUSTOM_MULTI_WL4) WLCal[a] = false;
else if (payload[7] == '1')
if (pub_salinity[0] == 'c' && CustomExpansion[data_index] == CUSTOM_SALINITY) SalCal = true;
if (pub_orp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_ORP) ORPCal = true;
if (pub_phexp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_PHEXP) PHExpCal = true;
if (pub_wl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_WL) WLCal[0] = true;
if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL1) WLCal[1] = true;
if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL2) WLCal[2] = true;
if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL3) WLCal[3] = true;
if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL4) WLCal[4] = true;
else if (payload[7] == '2')
for (byte a = 9; a < length; a++)
payload_data *= 10;
else if (payload[7] == '3')
payload_data *= 10;
if (pub_salinity[0] == 'c')
SalCal = false;
if (pub_orp[0] == 'c')
ORPMin = CalVal1;
ORPCal = false;
if (pub_phexp[0] == 'c')
PHExpMin = CalVal1;
PHExpCal = false;
WLMin[0] = CalVal1;
WLMax[0] = payload_data;
WLCal[0] = false;
if (pub_multiwl[0] == 'c' && WLCal[a] == true)
memory_write_int(Mem_I_WaterLevel1Min + (a * 2) - 2, CalVal1);
memory_write_int(Mem_I_WaterLevel1Max + (a * 2) - 2, payload_data);
WLMin[a] = CalVal1;
WLMax[a] = payload_data;
WLCal[a] = false;
if (data_found)
blink_data_led(30);
for (int a = 0; a < length; a++)
Serial.write(payload[a]);
Serial.println();
const char* ip_to_str(const uint8_t* ipAddr)
static char buf[16];
sprintf(buf, "%d.%d.%d.%d", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
return buf;
void ApplyCalibration(byte module, byte type)
CustomExpansion[module - 1] = type;
switch (type)
case CUSTOM_SALINITY:
sprintf(pub_salinity, "cexp:%d:", module - 1);
break;
case CUSTOM_ORP:
sprintf(pub_orp, "cexp:%d:", module - 1);
break;
case CUSTOM_PHEXP:
sprintf(pub_phexp, "cexp:%d:", module - 1);
break;
case CUSTOM_WL:
sprintf(pub_wl, "cexp:%d:", module - 1);
sprintf(pub_custom_wl, "cexpc:%d:", module - 1);
break;
case CUSTOM_MULTI_WL1:
case CUSTOM_MULTI_WL2:
case CUSTOM_MULTI_WL3:
case CUSTOM_MULTI_WL4:
sprintf(pub_multiwl, "cexp:%d:", module - 1);
sprintf(pub_custom_multiwl, "cexpc:%d:", module - 1);
break;
case CUSTOM_NONE:
break;
void blink_data_led(byte timer)
delay(timer);
void Publish(char* pub_buffer, char* buffer)
MQTTClient.publish(pub_buffer, buffer);
Serial.println(buffer);
blink_data_led(50);
byte memory_read_byte(int address)
byte rdata = 0xFF;
Wire.beginTransmission(I2CEEPROM1);
Wire.write((int)(address >> 8)); // MSB
Wire.write((int)(address & 0xFF)); // LSB
Wire.requestFrom(I2CEEPROM1,1);
rdata = Wire.read();
return rdata;
void memory_write_byte(int address, const byte data)
if (memory_read_int(address) != data)
Wire.write(data);
delay(10);
int memory_read_int(int address)
int rdata = 0xFFFF;
Wire.requestFrom(I2CEEPROM1,2);
rdata += (Wire.read())<<8;
return rdata;
void memory_write_int(int address, const int data)
Wire.write(data%256);
Wire.write(data>>8);
delay(10);
void printWifiStatus() {
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
unsigned int crc16(int *ptr, byte len)
unsigned int crc=0xFFFF;
byte i;
byte temp=0;
int test;
while(len--)
crc^=*ptr++;
for(i=0;i<8;i++)
if(crc & 0x01)
crc>>=1;
crc^=0xA001;
crc>>=1;
return crc;
void wdt_initialize()
GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
GCLK_GENCTRL_GENEN |
GCLK_GENCTRL_SRC_OSCULP32K |
GCLK_GENCTRL_DIVSEL;
while (GCLK->STATUS.bit.SYNCBUSY); // Syncronize write to GENCTRL reg.
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
GCLK_CLKCTRL_CLKEN |
GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CTRL reg.
WDT->CONFIG.reg = WDT_CONFIG_PER(0xA); // 0xA = 8192 ms
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CONFIG reg.
WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX1/i5QS5BGZK5riC7X8v1MxE964GYStk988=
// RA_STRING2=U2FsdGVkX19Lc9oWoOxRrp/GbHgXXsr2gDQc6rBkTKk=
// RA_STRING3=K2GVR
// CUSTOM_NONE 0
// CUSTOM_ORP 2
// CUSTOM_PHEXP 3
// CUSTOM_WL 4
#define CloudCustomModule1 CUSTOM_SALINITY
Can you post a photo of the board?
I need to see the revision number.
The board is a Cloud Wifi Expansion v 1.4. I'll take a picture later today if needed.
No need for photo.
This is the newest Could wifi hub and it doesn't work with the webwizard.
We will need to compile the code and upload it on your computer using the Arduino IDE.
It uses ESP8266 chip.
Start Arduino and open Preferences window.
Enter http://arduino.esp8266.com/stable/packa ... index.json into Additional Board Manager URLs field. You can add multiple URLs, separating them with commas.
Open Boards Manager from Tools > Board menu and find esp8266 platform.
Select the version you need from a drop-down box.
Click install button.
After it is installed, just to be sure, close Arduino and start it again to load everything it needs.
Then, go to menu Tools->Boards and you will see a bunch of ESP8266 boards. Pick the Adafruit HUZZAH ESP8266.
Try to compile this code:
This is the code we previously loaded with the 16ch Dimming feature enabled.
#include <FS.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <ESP8266httpUpdate.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
#include <Ticker.h>
#define Relay1FallBack 0
// CUSTOM_NONE 0
// CUSTOM_ORP 2
// CUSTOM_PHEXP 3
// CUSTOM_WL 4
// IDs 3 and 4.
byte TempProbeIDs[] = {4, 5};
// solid green - factory reset
// blink green - connecting wifi
// blink blue - configuration required (SoftAP)
// blink magenta - connecting to cloud server
// solid cyan - connected to cloud server
// blinking cyan - transmitting/receiving data
// solid yellow - firmware update
#define LED_GREEN 2
#define LED_BLUE 0
#define LED_RED 16
#define RESET_ALL A0
#define INPUT1 12
#define INPUT2 13
#define TEMP_PIN 14
#define version "1.0.1"
#define MQTTServer "cloud.reefangel.com"
#define MQTTPORT 1883 // MQTT server port
WiFiManager wifiManager;
WiFiClient espClient;
PubSubClient CloudClient(espClient);
Ticker ticker;
OneWire ds(TEMP_PIN);
byte data[2];
byte addr[8];
byte addr1[8];
byte addr2[8];
boolean first_connection = true;
boolean shouldSaveConfig = false;
boolean updating = false;
unsigned long cloudmillis = millis();
unsigned long client_timeout = millis();
unsigned long serial_timeout = millis();
String currentLine = ""; // make a String to hold incoming data from the client
char mqtt_username[32];
char mqtt_password[32];
void APtick()
//toggle state
int state = digitalRead(LED_BLUE); // get the current state of GPIO1 pin
digitalWrite(LED_BLUE, !state); // set pin to the opposite state
void Wifitick()
//toggle state
int state = digitalRead(LED_GREEN); // get the current state of GPIO1 pin
digitalWrite(LED_GREEN, !state); // set pin to the opposite state
void Cloudtick()
//toggle state
digitalWrite(LED_RED, !state); // set pin to the opposite state
void Datatick()
//toggle state
void LED_Color(int Red, int Green, int Blue)
analogWrite(LED_RED, 1023 - Red);
analogWrite(LED_GREEN, 1023 - Green);
analogWrite(LED_BLUE, 1023 - Blue);
return EEPROM.read(address);
EEPROM.write(address, data);
EEPROM.commit();
unsigned int crc = 0xFFFF;
byte i;
byte temp = 0;
int test;
while (len--)
crc ^= *ptr++;
for (i = 0; i < 8; i++)
if (crc & 0x01)
crc >>= 1;
crc ^= 0xA001;
crc >>= 1;
return crc;
delay(timer);
CloudClient.publish(pub_buffer, buffer);
Serial.print(pub_buffer);
Serial.print(": ");
blink_data_led(50);
void reconnect() {
// Loop until we're reconnected
if (!CloudClient.connected()) {
// Serial.print(F("Username: "));
// Serial.println(CLOUD_USERNAME);
Serial.println("Connecting to cloud server...");
// Attempt to connect
//Serial.println(sub_buffer);
if (CloudClient.connect(clientid, mqtt_username, mqtt_password)) {
Serial.println("Connected");
// Once connected, publish an announcement...
Serial.print("Subscribing to ");
CloudClient.subscribe(sub_buffer);
ticker.detach();
LED_Color(0, 1023, 1023);
//Serial.swap();
Serial.print("Failed, rc=");
Serial.print(CloudClient.state());
Serial.println(" try again in 30 seconds");
switch (type)
break;
case CUSTOM_ORP:
break;
case CUSTOM_PHEXP:
break;
case CUSTOM_WL:
break;
break;
case CUSTOM_NONE:
break;
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void configModeCallback (WiFiManager *myWiFiManager) {
LED_Color(0, 0, 0);
ticker.detach();
Serial.println("Entered config mode");
WiFi.softAPIP();
ticker.attach(0.5, APtick);
void WifiCheckCallback () {
WiFi.softAPdisconnect(true);
LED_Color(0, 0, 0);
ticker.detach();
Serial.println("Checking Wifi Credentials");
ticker.attach(0.5, Wifitick);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("cloud:");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
data_found = true;
payload_data *= 10;
data_found = true;
payload_data *= 10;
data_found = true;
payload_data *= 10;
data_found = true;
payload_data *= 10;
data_found = true;
payload_data *= 10;
else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == '1' && payload[4] == '6' && payload[5] == 'E' && payload[8] == ':')
data_found = true;
data_index = (payload[6] - '0') * 10;
data_index += (payload[7] - '0');
payload_data *= 10;
Expansion16Channel[data_index] = payload_data;
else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == '1' && payload[4] == '6' && payload[5] == 'E' && payload[6] == 'O' && payload[9] == ':')
data_found = true;
data_index = (payload[7] - '0') * 10;
data_index += (payload[8] - '0');
for (byte a = 10; a < length; a++)
payload_data *= 10;
Expansion16ChannelOverride[data_index] = payload_data;
data_found = true;
ORPCal = false;
ORPCal = true;
payload_data *= 10;
payload_data *= 10;
ORPMin = CalVal1;
ORPCal = false;
data_found = true;
SalCal = false;
SalCal = true;
payload_data *= 10;
SalCal = false;
data_found = true;
PHExpCal = false;
PHExpCal = true;
payload_data *= 10;
payload_data *= 10;
PHExpMin = CalVal1;
PHExpCal = false;
data_found = true;
payload_data *= 10;
payload_data *= 10;
data_found = true;
payload_data *= 10;
payload_data *= 10;
SalCal = false;
ORPMin = CalVal1;
ORPCal = false;
PHExpMin = CalVal1;
PHExpCal = false;
WLMin[0] = CalVal1;
WLCal[0] = false;
WLMin[a] = CalVal1;
WLCal[a] = false;
if (data_found)
blink_data_led(30);
Serial.println();
void setup() {
pinMode(INPUT1, INPUT_PULLUP);
pinMode(INPUT2, INPUT_PULLUP);
digitalWrite(LED_GREEN, LOW);
wifi_station_set_hostname( "ReefAngelCloudHub" );
Serial.setRxBufferSize(2048);
EEPROM.begin(512);
Wire.begin();
wifiManager.setDebugOutput(true);
Serial.println("");
Serial.print("Current version: ");
Serial.println(version);
ORPFound = false;
PHExpFound = false;
WLFound = false;
// Temperature
byte count = 0;
count++;
ds.reset_search();
// Relay
// Dimming
lastcrc = -1;
// 16 Channel Dimming
lastcrc16 = -1;
for ( byte a = 0; a < PWM16_EXPANSION_CHANNELS; a++ )
Expansion16Channel[a] = 0;
Expansion16ChannelOverride[a] = 255;
// IO
Params.IO = 63;
OldParams.IO = 63;
// Leak
Params.Leak = 0;
OldParams.Leak = 0;
// ORP
Params.ORP = 0;
OldParams.ORP = 0;
ORPCal = false;
if (ORPMin == 65535) ORPMin = 0;
// Salinity
SalCal = false;
// pH Exp
Params.PHExp = 0;
PHExpCal = false;
if (PHExpMin == 65535) PHExpMin = 0;
// Humidity
// Water Level
Params.WL[a] = 0;
WLCal[a] = false;
for (int a = 0; a < 5; a++)
if (WLMin[a] == 65535) WLMin[a] = 0;
if (analogRead(RESET_ALL) < 50)
// updating=true;
Serial.println("Resetting");
EEPROM.write(128, 0);
EEPROM.commit();
ESP.reset();
while (1);
wifiManager.setVersion(version);
if (EEPROM.read(128) != 1)
wifiManager.resetSettings();
SPIFFS.format();
EEPROM.write(128, 1);
EEPROM.commit();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(mqtt_username, json["mqtt_username"]);
strcpy(mqtt_password, json["mqtt_password"]);
Serial.println("failed to load json config");
Serial.println("failed to mount FS");
WiFiManagerParameter custom_mqtt_username("Cloud Username", "Cloud Username", mqtt_username, 40);
WiFiManagerParameter custom_mqtt_password("Cloud Password", "Cloud Password", mqtt_password, 40);
wifiManager.addParameter(&custom_mqtt_username);
wifiManager.addParameter(&custom_mqtt_password);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.setAPCallback(configModeCallback);
wifiManager.setCheckWifiCallback(WifiCheckCallback);
LED_Color(0, 0, 0);
wifiManager.autoConnect("ReefAngelCloudHub");
ticker.detach();
LED_Color(900, 0, 1023);
CloudClient.setServer(MQTTServer, MQTTPORT);
CloudClient.setCallback(callback);
strcpy(mqtt_username, custom_mqtt_username.getValue());
strcpy(mqtt_password, custom_mqtt_password.getValue());
Serial.print("username: ");
Serial.println(mqtt_username);
// Serial.print("password: ");
// Serial.println(mqtt_password);
sprintf(clientid, "%s%02d", mqtt_username, random(10000));
sprintf(pub_buffer, "%s/in", mqtt_username);
sprintf(sub_buffer, "%s/out/#", mqtt_username);
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["mqtt_username"] = mqtt_username;
json["mqtt_password"] = mqtt_password;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
Serial.println("");
json.printTo(configFile);
configFile.close();
//end save
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
void loop() {
if ((analogRead(RESET_ALL) < 50) && !updating)
if (WiFi.status() == WL_CONNECTED)
updating = true;
ticker.detach();
LED_Color(1023, 900, 0);
Serial.println("Updating...");
ESPhttpUpdate.update("forum.reefangel.com", 80, "/firmware/CloudWifiESP8266Hub.ino.bin");
EEPROM.commit();
ESP.reset();
while (1);
if (!CloudClient.connected() && (((millis() - cloudmillis) > 30000) || first_connection)) {
first_connection = false;
LED_Color(0, 0, 0);
ticker.detach();
ticker.attach(0.5, Cloudtick);
reconnect();
CloudClient.loop();
// Relay
// Dimming
byte thiscrc = 0;
lastcrc = thiscrc;
Wire.write(0xa1);
int data;
int thiscrc16 = 0;
thiscrc16 += Expansion16Channel[a] * (a + 1);
thiscrc16 += Expansion16ChannelOverride[a] * (a + 1);
if (millis() % 60000 < 200) lastcrc16 = -1;
if (lastcrc16 != thiscrc16 || millis() < 5000)
lastcrc16 = thiscrc16;
Wire.beginTransmission(I2CPWM_16CH_PCA9685);
Wire.write(0xa1);
int data;
if (Expansion16ChannelOverride[a] <= 100)
data = Expansion16ChannelOverride[a];
data = Expansion16Channel[a];
if (CloudClient.connected())
// IO
Params.IO = 63;
if (digitalRead(INPUT1) == HIGH) Params.IO += 64;
if (digitalRead(INPUT2) == HIGH) Params.IO += 128;
// Leak
int iLeak = 0;
iLeak = iLeak << 8;
// Temperature
if (addr1[0] != 0)
ds.reset();
ds.select(addr1);
sprintf(buffer, "t:%d:%d", TempProbeIDs[0], Params.Temp[1]);
if (TempProbeIDs[0] != 0) Publish(pub_buffer, buffer);
if (addr2[0] != 0)
ds.reset();
ds.select(addr2);
sprintf(buffer, "t:%d:%d", TempProbeIDs[1], Params.Temp[2]);
if (TempProbeIDs[1] != 0) Publish(pub_buffer, buffer);
// ORP
int iORP = 0;
iORP = Wire.read();
iORP = iORP << 8;
temporp += iORP;
if (temporp != 0)
if (ORPCal)
// Salinity
int iSAL = 0;
iSAL = Wire.read();
iSAL = iSAL << 8;
tempsal += iSAL;
if (tempsal != 0)
if (SalCal)
// pH Exp
int iPHExp = 0;
if (tempphexp != 0)
if (PHExpCal)
// PAR
int iPAR = 0;
iPAR = Wire.read();
iPAR = iPAR << 8;
temppar += iPAR;
if (temppar != 0)
temppar /= 8192;
// Humidity
int iHumidity = 0;
int reply[10];
for (int i = 0; i < 6; i++)
if (Wire.available()) reply[i] = Wire.read();
if (reply[0] == 0x3 && reply[1] == 0x2) // The response need to contain function (0x3) and length of data (0x2)
int crc = reply[5];
crc <<= 8;
crc += reply[4];
if (crc == crc16(reply, 4))
iHumidity = reply[2];
iHumidity <<= 8;
iHumidity += reply[3];
Params.Humidity = iHumidity;
// Water Level
int iWL = 0;
if (i == 0)
iWL = Wire.read();
iWL = iWL << 8;
iWL += Wire.read();
tempwl += iWL;
Wire.write(addr);
Wire.write(0x83);
iWL = Wire.read();
iWL = iWL << 8;
iWL += Wire.read();
tempwl += iWL >> 4;
if (tempwl != 0)
if (WLCal[i])
if (i == 0)
if (i == 0)
ds.reset();
ds.select(addr1);
ds.write(0x44, 0);
ds.reset();
ds.select(addr2);
ds.write(0x44, 0);
Having problems with the version. On the esp8266 select version drop down, I see the following:Open Boards Manager from Tools > Board menu and find esp8266 platform.
1.6.5 and 2.0 thru 2.5.0 versions. When I select 2.4 and 2.5 versions, the board closest available is Adafruit feather HUZZAH esp8266. The others that I tried 1.6.5 and 2.0.0 version have the Adfruit HUZZAH ESP8266 board but in all cases, the code would not compile with errors.
Ok, so I am compiling on version 2.3.
If it does give you compile errors, can you paste the errors here?
I get an error with 2.3 but it's different from the others.
Sorry, I'm a beginner with this language and haven't been able to figure out how to fix this missing WiFiManager.h file error.
I used the verbose option when I compiled.
Arduino: 1.8.5 (Windows 10), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino\hardware -hardware C:\Users\Loose\AppData\Local\Arduino15\packages -tools C:\Arduino\tools-builder -tools C:\Arduino\hardware\tools\avr -tools C:\Users\Loose\AppData\Local\Arduino15\packages -built-in-libraries C:\Arduino\libraries -libraries C:\Users\Loose\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\Loose\AppData\Local\Temp\arduino_build_558683 -warnings=all -build-cache C:\Users\Loose\AppData\Local\Temp\arduino_cache_59280 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino
C:\Arduino\arduino-builder -compile -logger=machine -hardware C:\Arduino\hardware -hardware C:\Users\Loose\AppData\Local\Arduino15\packages -tools C:\Arduino\tools-builder -tools C:\Arduino\hardware\tools\avr -tools C:\Users\Loose\AppData\Local\Arduino15\packages -built-in-libraries C:\Arduino\libraries -libraries C:\Users\Loose\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\Loose\AppData\Local\Temp\arduino_build_558683 -warnings=all -build-cache C:\Users\Loose\AppData\Local\Temp\arduino_cache_59280 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino
Using board 'huzzah' from platform in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266httpUpdate\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266httpUpdate\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPClient\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "nul"
"C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Loose\AppData\Local\Temp\arduino_build_558683/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Loose\Documents\Arduino\libraries\PubSubClient" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266httpUpdate\src" "-IC:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPClient\src" "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\sketch\Cloud_Wifi_Hub_Sal.ino.cpp" -o "C:\Users\Loose\AppData\Local\Temp\arduino_build_558683\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:7:25: fatal error: WiFiManager.h: No such file or directory
compilation terminated.
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Using library PubSubClient in folder: C:\Users\Loose\Documents\Arduino\libraries\PubSubClient (legacy)
Using library DNSServer at version 1.1.0 in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\DNSServer
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer
Using library ESP8266httpUpdate at version 1.1 in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266httpUpdate
Using library ESP8266HTTPClient at version 1.1 in folder: C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPClient
exit status 1
Error compiling for board Adafruit HUZZAH ESP8266.
Ahh.
You need the latest dev branch of the libraries.
Replace the contents of /Documents/Arduino/libraries with these ones: https://github.com/reefangel/Libraries/archive/dev.zip
Thank you, libraries updated and recompiling.
Lot's of warnings/notes (I took it off verbose) but it did compile (used 2.3.).
Build options changed, rebuilding all
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: In function 'unsigned int crc16(int*, byte)':
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:172:8: warning: unused variable 'temp' [-Wunused-variable]
byte temp = 0;
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:173:7: warning: unused variable 'test' [-Wunused-variable]
int test;
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: In function 'void reconnect()':
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:224:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: At global scope:
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:272:6: warning: unused parameter 'myWiFiManager' [-Wunused-parameter]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: In function 'void callback(char*, byte*, unsigned int)':
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:295:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:632:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:288:6: warning: unused parameter 'topic' [-Wunused-parameter]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: In function 'void setup()':
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:859:59: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino: In function 'void loop()':
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:897:94: warning: 't_httpUpdate_return ESP8266HTTPUpdate::update(const String&, uint16_t, const String&, const String&)' is deprecated (declared at C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266httpUpdate\src/ESP8266httpUpdate.h:100) [-Wdeprecated-declarations]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1098:51: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1133:56: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1169:55: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1230:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
In file included from sketch\Cloud_Wifi_Hub_Sal.ino.cpp:1:0:
C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/Arduino.h:136:44: warning: comparison is always false due to limited range of data type [-Wtype-limits]
#define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1292:26: note: in expansion of macro 'constrain'
C:\Users\Loose\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266/Arduino.h:136:64: warning: comparison is always false due to limited range of data type [-Wtype-limits]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1299:60: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1301:55: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1306:65: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:1308:60: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
In file included from C:\Users\Loose\Documents\Arduino\Cloud_Wifi_Hub_Salinity\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal\Cloud_Wifi_Hub_Sal.ino:13:0:
C:\Users\Loose\Documents\Arduino\libraries\CloudGlobals/CloudGlobals.h: At global scope:
C:\Users\Loose\Documents\Arduino\libraries\CloudGlobals/CloudGlobals.h:96:13: warning: 'username' defined but not used [-Wunused-variable]
static char username[16];
C:\Users\Loose\Documents\Arduino\libraries\CloudGlobals/CloudGlobals.h:97:13: warning: 'password' defined but not used [-Wunused-variable]
static char password[16];
C:\Users\Loose\Documents\Arduino\libraries\CloudGlobals/CloudGlobals.h:154:16: warning: 'FoundIP' defined but not used [-Wunused-variable]
static boolean FoundIP=false;
C:\Users\Loose\Documents\Arduino\libraries\PubSubClient\PubSubClient.cpp: In member function 'boolean PubSubClient::subscribe(const char*, uint8_t)':
C:\Users\Loose\Documents\Arduino\libraries\PubSubClient\PubSubClient.cpp:492:15: warning: comparison is always false due to limited range of data type [-Wtype-limits]
if (qos < 0 || qos > 1) {
C:\Users\Loose\Documents\Arduino\libraries\WiFiManager\WiFiManager.cpp: In member function 'boolean WiFiManager::isIp(String)':
C:\Users\Loose\Documents\Arduino\libraries\WiFiManager\WiFiManager.cpp:780:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int i = 0; i < str.length(); i++) {
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::reset()':
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp:145:24: warning: unused variable 'reg' [-Wunused-variable]
volatile IO_REG_TYPE *reg IO_REG_ASM = baseReg;
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp:179:24: warning: unused variable 'reg' [-Wunused-variable]
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
C:\Users\Loose\Documents\Arduino\libraries\OneWire\OneWire.cpp:207:24: warning: unused variable 'reg' [-Wunused-variable]
Archiving built core (caching) in: C:\Users\Loose\AppData\Local\Temp\arduino_cache_555022\core\core_esp8266_esp8266_huzzah_xtal_80,vt_flash,exception_disabled,eesz_4M,ip_lm2f,dbg_Disabled,lvl_None____,wipe_none,baud_115200_af310de3343d0ab5be8a323c884dd04a.a
Sketch uses 403348 bytes (38%) of program storage space. Maximum is 1044464 bytes.
Global variables use 36972 bytes (45%) of dynamic memory, leaving 44948 bytes for local variables. Maximum is 81920 bytes.
Try to learn something about everything and everything about something... Thomas Huxley
210gal DT | 50gal sump/refug | Jebao DCP 10000 pump | RO 200-int skimmer | DIY built stand | DIY 160 led, 12 channel, 458 watt, on MakersLED 72" heatsink
Re: 2nd Salinity module w/Cloud Wifi Hub
Good.
So, in that code, replace this:
With this:
Modified and compiled successfully.
Ok, upload to your cloud expansion and plug in the salinity module to it.
It should start sending data as custom expansion 1. You may need to calibrate.
Code has been uploaded but once finished it it did reconnect to my local Wifi but it seems to be having trouble connecting to the cloud server (Blinking Magenta).
I can get it to fully connect with the reset/setup procedure (paper clip) and I can control my lights with the web uapp and the Android app on my phone but, if I take power away and then plug it back in, it will not reconnect to the server automatically.
Also, once connected how/where can I see the data from the salinity probe/custom expansion 1? I enabled Custom variables on the Android app but nothing is registering on Custom 0-7.
Sorry.
I forgot that we need to edit the cloud settings.
Open the file RA_CustomSettings.h and change the CLOUD_USERNAME and CLOUD_PASSWORD.
The Custom expansion 1 will show up on the screen of RA* only
We don't have any app that can display it too.
You can as a work around, assign a custom variable to have the 2nd salinity, but it will not have the decimal point. It would show for example 350 instead of 35.0
To do that, add this to your loop():
ReefAngel.CustomVar[0]=ReefAngel.CustomExpansionValue[0];
RA_CustomSettings.h modified. Do I need to upload directly to the Cloud Wifi hub again or will changing the file be sufficient?
"ReefAngel.CustomVar[0]=ReefAngel.CustomExpansionValue[0];" added to my loop()
Now, I'm sorry but, decimal points, LOL! The old Naval aviator here can translate that little dot on the fly .
The only problem I've got is the RA* rebooting when I touch the screen and move from one screen to the other; annoying but not a show stopper.
Readings are odd. I put the second probe in the display tank next to the DT probe (which is stable @30.3) and am getting values from 215 to 8; currently averaging 80.
Thoughts?
Thoughts?
So, I tried calibrating Custom Expansion Module 1 about 5 times from the RA* screen.
#1 - First 35ppt then RODI - Calibration value for both was 0. RA* Custom Expansion Module 1 showed 00.-29 <--- that is not a typo.
#2 - First RODI then 35ppt - Calibration value for both was 0. Android app showed constant 61; can't tell you what the RA* showed as it displayed overlapping numbers from top to bottom in that column, screen went blank, and it rebooted.
#3 - I cancelled this attempt because I started with RODI and then the next message was new as it said to put the probe in RODI and press OK.
#4 - 35ppt then RODI then 35ppt - Calibration value for both was 0. RA* went blank and rebooted when I tried to change menu pages, Android app showed 84, 88, then 224.
#5 - RODI then RODI then 35ppt - Calibration value for both was 0. App shows 0 with the probe in my DT.
It's late so I'm done for the evening.
If you open Serial monitor on Arudino, it should start displaying the log.
Can you record the log of when you start the salinity calibrating and post here?
Sure thing.
I did the full cal but am only posting from the start (35ppt solution) to the RODI to just putting the probe back into the 35ppt.
cloud:PWMD:52
cloud:PWMD2:92
cloud:WL1:96
cloud:T3:768
cloud:PWMD:50
cloud:PWMD2:94
cloud:WL1:93
cloud:T3:766
cloud:CEXP0C:1
CEXP0C:1
cloud:PWMD:49
cloud:PWMD2:95
cloud:WL1:96
Loose/in: cexp:0:c:1828
cloud:PWMD:46
cloud:PWMD2:98
cloud:C0:84
cloud:CEXP0:-12460
Loose/in: cexp:0:c:1827
cloud:C0:83
cloud:CEXP0:-12461
Loose/in: cexp:0:c:1829
cloud:PWMD:45
cloud:PWMD2:99
cloud:C0:85
cloud:CEXP0:-12459
cloud:C0:84
cloud:CEXP0:-12460
cloud:C0:85
cloud:T3:768
cloud:PH:821
cloud:CEXP0:-12459
cloud:PWME1:20
PWME1:20
Loose/in: cexp:0:c:1830
cloud:PWMD:46
cloud:PWMD2:98
cloud:WL1:97
cloud:C0:86
cloud:PH:820
cloud:CEXP0:-12458
cloud:PWMD:47
cloud:PWMD2:97
cloud:WL1:96
cloud:C0:85
cloud:T3:766
cloud:PH:821
cloud:CEXP0:-12459
cloud:PWMD:48
cloud:PWMD2:96
cloud:T1:719
cloud:T3:768
cloud:PH:820
cloud:PWMD:49
cloud:PWMD2:95
cloud:WL1:97
cloud:PWMD:51
cloud:PWMD2:93
cloud:WL1:96
cloud:T3:766
cloud:PWMD:53
cloud:PWMD2:91
cloud:T3:768
cloud:PWMD:55
cloud:PWMD2:89
cloud:WL1:97
cloud:C0:84
cloud:T1:717
cloud:CEXP0:-12460
cloud:PWMD:57
cloud:PWMD2:87
cloud:WL1:95
cloud:T1:719
cloud:PWMD:59
cloud:PWMD2:85
cloud:WL1:97
cloud:C0:85
cloud:CEXP0:-12459
cloud:PWMD:62
cloud:PWMD2:82
cloud:WL1:95
cloud:C0:83
cloud:T3:766
cloud:PH:821
cloud:SAL:306
cloud:CEXP0:-12461
cloud:PWMD:64
cloud:PWMD2:80
cloud:WL1:94
cloud:T3:768
cloud:PH:820
cloud:SAL:305
cloud:CEXP0:-12459
cloud:PWMD:67
cloud:PWMD2:77
cloud:WL1:96
cloud:C0:85
cloud:T1:717
cloud:T3:766
cloud:PWMD:69
cloud:PWMD2:75
cloud:WL1:95
cloud:T1:719
cloud:SAL:306
cloud:PWMD:72
cloud:PWMD2:72
cloud:WL1:96
cloud:T3:768
cloud:PWMD:75
cloud:PWMD2:69
cloud:C0:84
cloud:SAL:305
cloud:CEXP0:-12460
cloud:PWMD:77
cloud:PWMD2:67
cloud:PWMD:80
cloud:PWMD2:64
cloud:WL1:95
cloud:C0:85
cloud:SAL:306
cloud:CEXP0:-12459
cloud:PWMD:82
cloud:PWMD2:62
cloud:WL1:96
cloud:SAL:305
cloud:PWMD:85
cloud:PWMD2:59
cloud:PH:821
cloud:SAL:306
cloud:PWMD:87
cloud:PWMD2:57
cloud:WL1:95
cloud:PH:820
cloud:SAL:305
cloud:PWMD:89
cloud:PWMD2:55
cloud:C0:86
cloud:CEXP0:-12458
cloud:PWMD:91
cloud:PWMD2:53
cloud:WL1:97
cloud:T3:766
cloud:PWMD:93
cloud:R1:193
R1:193
cloud:PWMD2:51
cloud:WL1:0
cloud:WL2:0
cloud:WL3:0
cloud:WL4:0
cloud:C0:85
cloud:PH:821
cloud:SAL:60
cloud:CEXP0:-12459
cloud:PWMD:95
cloud:PWMD2:49
cloud:PH:820
cloud:PWMD:96
cloud:PWMD2:48
cloud:PWMD:98
cloud:PWMD2:46
cloud:C0:84
cloud:CEXP0:-12460
cloud:PWMD:99
cloud:PWMD2:45
cloud:C0:85
cloud:CEXP0:-12459
cloud:C0:84
cloud:PH:821
cloud:CEXP0:-12460
cloud:C0:85
cloud:CEXP0:-12459
cloud:PWMD:98
cloud:PWMD2:46
cloud:PH:820
cloud:C0:84
cloud:PH:821
cloud:CEXP0:-12460
cloud:PWMD:97
cloud:R1:195
R1:195
cloud:PWMD2:47
cloud:WL1:96
cloud:WL2:90
cloud:WL3:3
cloud:WL4:1
cloud:PH:820
cloud:SAL:305
cloud:PWMD:95
cloud:PWMD2:49
cloud:WL1:95
cloud:WL2:87
cloud:C0:85
cloud:SAL:306
cloud:CEXP0:-12459
cloud:PWMD:94
cloud:PWMD2:50
cloud:WL1:96
cloud:WL2:90
cloud:C0:83
cloud:CEXP0:-12461
cloud:PWMD:92
cloud:PWMD2:52
cloud:WL1:98
cloud:WL2:92
cloud:PH:821
cloud:SAL:305
Loose/in: cexp:0:c:1826
cloud:PWMD:90
cloud:PWMD2:54
cloud:WL1:100
cloud:WL2:93
cloud:C0:82
cloud:CEXP0:-12462
cloud:PWMD:88
cloud:PWMD2:56
cloud:WL1:97
cloud:WL2:94
cloud:PH:820
cloud:PWMD:86
Loose/in: cexp:0:c:1825
cloud:PWMD2:58
cloud:WL1:101
cloud:WL2:95
cloud:PWMD:84
cloud:PWMD2:60
cloud:WL2:96
cloud:C0:81
cloud:CEXP0:-12463
cloud:PWMD:81
cloud:PWMD2:63
cloud:WL1:103
cloud:WL2:97
cloud:SAL:306
cloud:PWMD:79
cloud:PWMD2:65
cloud:WL2:96
cloud:C0:82
cloud:T1:721
cloud:SAL:305
cloud:CEXP0:-12462
cloud:PWMD:76
Loose/in: cexp:0:c:1715
cloud:PWMD2:68
cloud:WL1:101
cloud:C0:81
cloud:CEXP0:-12463
cloud:PWMD:73
Loose/in: cexp:0:c:781
cloud:PWMD2:71
cloud:WL1:103
cloud:WL2:95
cloud:C0:227
cloud:T1:719
cloud:CEXP0:-12573
Loose/in: cexp:0:c:363
cloud:PWMD:71
cloud:PWMD2:73
cloud:WL1:100
cloud:WL2:94
cloud:C0:69
cloud:CEXP0:-14173
Loose/in: cexp:0:c:173
cloud:PWMD:68
cloud:PWMD2:76
cloud:C0:163
cloud:PH:819
cloud:CEXP0:-14363
Loose/in: cexp:0:c:85
cloud:PWMD:65
cloud:PWMD2:79
cloud:WL1:99
cloud:WL2:93
cloud:C0:229
cloud:PH:820
cloud:SAL:306
cloud:CEXP0:5185
Loose/in: cexp:0:c:43
cloud:PWMD:63
cloud:PWMD2:81
cloud:WL2:92
cloud:C0:23
cloud:T1:721
cloud:SAL:305
cloud:CEXP0:5143
Loose/in: cexp:0:c:23
cloud:PWMD:60
cloud:PWMD2:84
cloud:WL1:96
cloud:WL2:91
cloud:PH:821
cloud:CEXP0:5123
Loose/in: cexp:0:c:13
cloud:PWMD:58
cloud:PWMD2:86
cloud:WL1:98
cloud:C0:249
cloud:PH:820
cloud:CEXP0:5113
cloud:PWMD:56
cloud:PWMD2:88
cloud:WL1:93
cloud:WL2:89
cloud:C0:6
cloud:T1:719
cloud:CEXP0:518
Loose/in: cexp:0:c:6
cloud:PWMD:54
cloud:PWMD2:90
cloud:WL1:95
cloud:C0:4
cloud:T1:721
cloud:CEXP0:516
cloud:PWMD:52
cloud:PWMD2:92
cloud:WL2:88
cloud:C0:2
cloud:CEXP0:514
cloud:PWMD:50
cloud:PWMD2:94
cloud:WL1:93
cloud:WL2:87
cloud:C0:1
cloud:T1:719
cloud:CEXP0:513
cloud:PWMD:49
cloud:PWMD2:95
cloud:WL1:91
cloud:WL2:86
cloud:T1:721
cloud:PWMD:47
cloud:PWMD2:97
cloud:WL1:88
cloud:WL2:85
cloud:C0:0
cloud:CEXP0:512
cloud:PWMD:46
cloud:PWMD2:98
cloud:WL1:99
cloud:WL2:84
cloud:PWME0:18
PWME0:18
cloud:PH:821
cloud:PWMD:45
cloud:PWMD2:99
cloud:WL1:98
cloud:PH:820
cloud:WL1:93
cloud:WL2:83
cloud:C0:255
cloud:CEXP0:511
cloud:WL1:97
cloud:WL2:82
cloud:WL1:94
cloud:WL2:81
cloud:PH:821
cloud:PWMD:46
cloud:PWMD2:98
cloud:WL1:97
cloud:PH:820
cloud:PWMD:47
cloud:PWMD2:97
cloud:WL1:95
cloud:PWMD:48
cloud:PWMD2:96
cloud:WL1:97
cloud:PWMD:49
cloud:PWMD2:95
cloud:PWMD:51
cloud:PWMD2:93
cloud:WL1:96
cloud:PWMD:53
cloud:PWMD2:91
cloud:WL1:97
cloud:WL2:82
Loose/in: cexp:0:c:163
cloud:PWMD:55
cloud:PWMD2:89
cloud:WL1:96
cloud:C0:219
cloud:CEXP0:-14373
Loose/in: cexp:0:c:1066
cloud:PWMD:57
cloud:PWMD2:87
cloud:WL1:94
cloud:C0:90
cloud:CEXP0:-13222
Loose/in: cexp:0:c:1470
cloud:PWMD:59
cloud:PWMD2:85
cloud:WL1:96
cloud:C0:238
cloud:CEXP0:-12818
Loose/in: cexp:0:c:1662
cloud:PWMD:62
cloud:PWMD2:82
cloud:WL1:95
cloud:WL2:81
cloud:C0:174
cloud:PH:821
cloud:CEXP0:-12626
Loose/in: cexp:0:c:1753
cloud:PWMD:64
cloud:PWMD2:80
cloud:C0:9
cloud:PH:820
cloud:CEXP0:-12535
Loose/in: cexp:0:c:1797
cloud:PWMD:67
cloud:PWMD2:77
cloud:WL1:96
cloud:C0:53
cloud:CEXP0:-12491
Loose/in: cexp:0:c:1818
cloud:PWMD:69
cloud:PWMD2:75
cloud:WL1:97
cloud:C0:74
cloud:CEXP0:-12470
While I had the serial monitor, I wanted to see why it wouldn't auto connect back to the cloud server when power was removed. Does the inability to open the config file for saving have something to do with it?
*WM: DIRECT-6C-HP ENVY 7640 series
*WM: -93
*WM: Sent config page
*WM: Request redirected to captive portal
*WM: Handle root
*WM: WiFi save
*WM: Parameter
*WM: Cloud Username
*WM: Loose
*WM: Parameter
*WM: Cloud Password
*WM: ##########
*WM: Sent wifi save page
*WM: Connecting to new AP
*WM: Connecting as wifi client...
*WM: Connection result:
*WM: 3
Should save config
username: Loose
Start
saving config
{"mqtt_username":"Loose","mqtt_password":"#######"}
IP address: 192.168.1.22
Connected
I can see that the hub is reading fine. It does report numbers around 1828.
There may be something wrong with the calibration process and storing that number into the memory.
Let me dig it up and see what I can find out.
Good evening Roberto,
I tried doing all of the steps again and still have the two main issues.
1) Cloud wifi Hub will no longer auto-connect to cloud server if power is disconnected. I have to use a paper clip to enter setup mode.
2) Information from attached salinity module doesn't make sense.
- shows as 227 on android app
- RA* screen shows:
- RA* screen shows:
- RA Star custom0.jpg (35.99 KiB) Viewed 8330 times
Load this code and send me the log.
// Example: storing JSON configuration file in flash file system
// Uses ArduinoJson library by Benoit Blanchon.
// https://github.com/bblanchon/ArduinoJson
// Created Aug 10, 2015 by Ivan Grokhotkov.
// This example code is in the public domain.
#include "FS.h"
bool loadConfig() {
if (!configFile) {
Serial.println("Failed to open config file");
return false;
if (size > 1024) {
Serial.println("Config file size is too large");
return false;
// We don't use String here because ArduinoJson library requires the input
// buffer to be mutable. If you don't use ArduinoJson, you may as well
// use configFile.readString instead.
StaticJsonBuffer<200> jsonBuffer;
if (!json.success()) {
Serial.println("Failed to parse config file");
return false;
const char* serverName = json["serverName"];
const char* accessToken = json["accessToken"];
// Real world application would store these values in some variables for
// later use.
Serial.print("Loaded serverName: ");
Serial.println(serverName);
Serial.print("Loaded accessToken: ");
Serial.println(accessToken);
return true;
bool saveConfig() {
json["serverName"] = "api.example.com";
json["accessToken"] = "128du9as8du12eoue8da98h123ueh9h98";
if (!configFile) {
Serial.println("Failed to open config file for writing");
return false;
return true;
void setup() {
Serial.begin(57600);
Serial.println("");
delay(1000);
Serial.println("Mounting FS...");
if (!SPIFFS.begin()) {
Serial.println("Failed to mount file system");
return;
if (!saveConfig()) {
Serial.println("Failed to save config");
Serial.println("Config saved");
if (!loadConfig()) {
Serial.println("Failed to load config");
Serial.println("Config loaded");
void loop() {
Log below:
SDK:3.0.0-dev(c0f7b44)/Core:2.5.0=20500000/lwIP:STABLE-2_1_2_RELEASE/glue:1.1/BearSSL:6778687
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with K2GVR, channel 6
dhcp client start...
Mounting FS...
ip:192.168.1.16,mask:255.255.255.0,gw:192.168.1.1
pm open,type:2 0
Are you sure you loaded the code.
It is supposed to have a different log.
There is nothing related to wifi on that code.
Yes but I guess I need to confirm something. I uploaded that code to the Cloud Wifi Hub. Was I supposed to upload it to the RA*?
