I am trying to compile the cloud wifi locally in the Arduino IDE 1.8.9. What board must I select from the IDE? I selected generic ESP8266 and this is the errors I am getting. I did fix the errors from the defined parameters in RA_CustomSettings.h
Arduino: 1.8.9 (Windows 7), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), ck, 26 MHz, 40MHz, DOUT (compatible), 512K (no SPIFFS), 2, nonos-sdk 2.2.1 (legacy), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,ssl=all,ResetMethod=ck,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=512K,led=2,sdk=nonosdk221,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0403_6001 -ide-version=10809 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_132919 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_915058 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,ssl=all,ResetMethod=ck,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=512K,led=2,sdk=nonosdk221,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=0403_6001 -ide-version=10809 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_132919 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_915058 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.python-3.7.2-post1.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\python\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino
Using board 'generic' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Using core 'esp8266' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2
Build options changed, rebuilding all
Detecting libraries used...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFi.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFiMDNSResponder.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFiSSLClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\bsp\\source\\nm_bsp_arduino.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\bsp\\source\\nm_bsp_arduino_avr.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\bus_wrapper\\source\\nm_bus_wrapper_samd21.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\common\\source\\nm_common.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\m2m_hif.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\m2m_ota.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\m2m_periph.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\m2m_wifi.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmasic.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmbus.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmdrv.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmi2c.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmspi.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\driver\\source\\nmuart.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\socket\\source\\socket.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\socket\\source\\socket_buffer.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src\\spi_flash\\source\\spi_flash.c" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient\\PubSubClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\Dhcp.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\Dns.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\Ethernet.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\EthernetClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\EthernetServer.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\EthernetUdp.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\utility\\socket.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src\\utility\\w5100.cpp" -o nul
Generating function prototypes...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/lwip2/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK221=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10809 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\cores\\esp8266" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\variants\\generic" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\SPI" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\WiFi101\\src" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\PubSubClient" "-IC:\\Users\\User\\Documents\\Arduino\\libraries\\RA_CustomSettings" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.2\\libraries\\Ethernet\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_132919\\sketch\\Cloud_hub.ino.cpp.o"
In file included from C:\Users\User\Documents\Arduino\libraries\WiFi101\src/common/include/nm_common.h:45:0,
from C:\Users\User\Documents\Arduino\libraries\WiFi101\src/driver/include/m2m_wifi.h:49,
from C:\Users\User\Documents\Arduino\libraries\WiFi101\src/WiFi101.h:28,
from C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino:2:
C:\Users\User\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:110:23: error: conflicting declaration 'typedef long unsigned int uint32'
typedef unsigned long uint32;
In file included from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/esp8266_peri.h:24:0,
from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Arduino.h:38,
from C:\Users\User\AppData\Local\Temp\arduino_build_132919\sketch\Cloud_hub.ino.cpp:1:
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2/tools/sdk/include/c_types.h:49:29: error: 'uint32' has a previous declaration as 'typedef unsigned int uint32'
typedef unsigned int uint32;
C:\Users\User\Documents\Arduino\libraries\WiFi101\src/bsp/include/nm_bsp.h:133:22: error: conflicting declaration 'typedef long int sint32'
typedef signed long sint32;
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2/tools/sdk/include/c_types.h:52:29: error: 'sint32' has a previous declaration as 'typedef int sint32'
typedef signed int sint32;
In file included from C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Arduino.h:264:0,
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino: In function 'void setup()':
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:90:47: error: call of overloaded 'wdtEnable()' is ambiguous
#define wdt_enable(time) ESP.wdtEnable(time)
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino:39:3: note: in expansion of macro 'wdt_enable'
wdt_enable();
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:90:47: note: candidates are:
wdt_enable();
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:134:14: note: void EspClass::wdtEnable(uint32_t)
void wdtEnable(uint32_t timeout_ms = 0);
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:136:14: note: void EspClass::wdtEnable(WDTO_t)
void wdtEnable(WDTO_t timeout_ms = WDTO_0MS);
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino: In function 'void wdt_initialize()':
Cloud_hub:258:3: error: 'GCLK' was not declared in this scope
GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
Cloud_hub:258:38: error: 'GCLK_GENDIV_ID' was not declared in this scope
Cloud_hub:258:59: error: 'GCLK_GENDIV_DIV' was not declared in this scope
Cloud_hub:259:40: error: 'GCLK_GENCTRL_ID' was not declared in this scope
GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
Cloud_hub:260:23: error: 'GCLK_GENCTRL_GENEN' was not declared in this scope
GCLK_GENCTRL_GENEN |
Cloud_hub:261:23: error: 'GCLK_GENCTRL_SRC_OSCULP32K' was not declared in this scope
GCLK_GENCTRL_SRC_OSCULP32K |
Cloud_hub:262:23: error: 'GCLK_GENCTRL_DIVSEL' was not declared in this scope
GCLK_GENCTRL_DIVSEL;
Cloud_hub:264:23: error: 'GCLK_CLKCTRL_ID_WDT' was not declared in this scope
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
Cloud_hub:265:23: error: 'GCLK_CLKCTRL_CLKEN' was not declared in this scope
GCLK_CLKCTRL_CLKEN |
Cloud_hub:266:23: error: 'GCLK_CLKCTRL_GEN_GCLK2' was not declared in this scope
GCLK_CLKCTRL_GEN_GCLK2;
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino: At global scope:
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:90:32: error: expected initializer before '.' token
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino:269:6: note: in expansion of macro 'wdt_enable'
void wdt_enable()
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:91:32: error: expected initializer before '.' token
#define wdt_disable() ESP.wdtDisable()
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino:280:6: note: in expansion of macro 'wdt_disable'
void wdt_disable()
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/Esp.h:92:32: error: expected initializer before '.' token
#define wdt_reset() ESP.wdtFeed()
C:\Users\User\Documents\Arduino\Cloud_hub\Cloud_hub.ino:286:6: note: in expansion of macro 'wdt_reset'
void wdt_reset()
Multiple libraries were found for "Ethernet.h"
Used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\Ethernet
Not used: C:\Users\User\Documents\Arduino\libraries\Ethernet
Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
Using library SPI at version 1.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\SPI
Using library WiFi101 at version 0.9.1 in folder: C:\Users\User\Documents\Arduino\libraries\WiFi101
Using library PubSubClient at version 1.1.3 in folder: C:\Users\User\Documents\Arduino\libraries\PubSubClient
Using library RA_CustomSettings at version 1.1.3 in folder: C:\Users\User\Documents\Arduino\libraries\RA_CustomSettings
Using library Ethernet at version 1.0.4 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\Ethernet
exit status 1
