clw143
Posts: 127 Joined: Fri Jun 21, 2013 8:20 pm
Post
by clw143 » Sun Jan 24, 2021 11:07 pm
Anyone shine some light on why this does not work?
long SetTime;
long RiseTime;
//Fuge Light on 1 hour before sunset and off 1 hour after sunrise
if (now()>(SetTime - 3600) || now()<(RiseTime + 3600)) ReefAngel.Relay.On(Port6);
else ReefAngel.Relay.Off(Port6);
SetTime = (InternalMemory.StdLightsOnHour_read() * 60 * 60) + (InternalMemory.StdLightsOnMinute_read() * 60);
RiseTime = (InternalMemory.StdLightsOffHour_read() * 60 * 60) + (InternalMemory.StdLightsOffMinute_read() * 60);
Piper
Posts: 304 Joined: Fri Jul 20, 2012 7:13 am
Post
by Piper » Mon Jan 25, 2021 8:23 am
Try using hour() instead of now().
if (hour() >= (InternalMemory.StdLightsOnHour_read() - 1) && hour() <= (InternalMemory.StdLightsOffHour_read() + 1)) {
This compiles but I have not tested it.
clw143
Post
by clw143 » Mon Jan 25, 2021 9:50 pm
Yeah that is a possibility, but I'm not understanding why what I am trying to do is not working.
Posts: 2865 Joined: Fri Mar 18, 2011 6:20 pm
Post
by binder » Tue Jan 26, 2021 6:54 am
Looking at your code, you are not initializing SetTime and RiseTime before you try to use them. You have:
Then, the next statement you are trying to use those variables in an IF statement. The values stored in them are "undefined" or whatever else the system decided to put in them when initializing. You need to move the initializing code segment before you use the variables.
long SetTime = (InternalMemory.StdLightsOnHour_read() * 60 * 60) + (InternalMemory.StdLightsOnMinute_read() * 60);
long RiseTime = (InternalMemory.StdLightsOffHour_read() * 60 * 60) + (InternalMemory.StdLightsOffMinute_read() * 60);
This should work now.
