RA* temp sensors
tngo
RA* temp sensors
Post by tngo »
Hi.
All of my temperature sensors on the RA* are suddenly reading zeros. I tried to reboot and reflash firmware but still no response from any of the temperature sensors. I have one temperature sensor sitting in air to read room temperature so I'm not sure why that would go bad, the other 2 are submersed in the tank and sump. What would be the best way to troubleshoot this?
Tim
Re: RA* temp sensors
Connect just one at a time to find the culprit
tngo
Post by tngo »
Ok. Will try that later today.
tngo
Post by tngo »
Tried what you suggested and found the bad temperature sensor. Everything is working normally now.
Thanks.
Tim
