Overheat shut off and always on ports
howaboutme
Post by howaboutme »
Will the overheat shut off function superseded the always on function?
I am using an inkbird to control my heaters. I have the RA set to turn off the heater at a certain temp as part of the overheat function. I originally put my heater port as always on but now I'm wondering if keeping it always on will prevent the overheat function? When I take it off of always on, the port stays off as a default (which means off when reboot, etc), which is no good of course.
Thanks.
Jack
Re: Overheat shut off and always on ports
The overheat will still turn off the port
