Hello,
tried the code below, but looks like with the float switch moving up and down(water flow), the ATO SW relay port is toggling, any pointers is greatly appreciated.
if ( ReefAngel.Params.PH > 810 ) ReefAngel.Relay.Off( Port7 );
if ( ReefAngel.Params.PH < 800 && ReefAngel.HighATO.IsActive() < 1) ReefAngel.Relay.On( Port7 );
Note:
kalk dosing, base on PH and ReefAngel.HighATO.IsActive() if possible.
Help with kalk dosing, base on PH and ReefAngel.HighATO.IsActive()
acabano13
- brennyn21
Re: Help with kalk dosing, base on PH and ReefAngel.HighATO.IsActive()
Do you have another port that is also based off the HighATO port then?
Sincerely, Brennyn
acabano13
yes, port 6 I'm currently using as a standard ATO
- brennyn21
Can you post your code?
Sincerely, Brennyn
- brennyn21
this will keep port 6 off if that is your goal when port 7 is on
if ( ReefAngel.Relay.Status( Port7 ) ) ReefAngel.Relay.Off( Port6 );
if (ReefAngel.Params.PH > 810) {
ReefAngel.Relay.Off(Port7);
if (ReefAngel.Params.PH < 800 && ReefAngel.HighATO.IsActive() < 1) {
ReefAngel.Relay.On(Port7);
Sincerely, Brennyn
acabano13
My observation with the kalk code below, is that the port 7 toggles when PH value fluctuates, same with the float sw (movement)
//#include <Salinity.h>
//#include <ORP.h>
//#include <DCPump.h>
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
// Calibrate PH probe
ReefAngel.PHMin=567;
ReefAngel.PHMax=872;
ReefAngel.Relay.On( Port2 ); // DayActLight
ReefAngel.Relay.On( Port5 ); // Lifter, Refugium pump, UV Pump and UV Sterilizer
ReefAngel.Relay.On( Port8 ); // Return, Powerhead, Skimmer and Wavemaker Pump
// Ports that are always off
ReefAngel.Relay.Off( Port7 ); // Kalk Pump
// Delayed On
//ReefAngel.Relay.DelayedOn( Port2,8 ); for Skimmer
// Tank Heater code
ReefAngel.StandardHeater( T1_PROBE,Port3,770,780 ); // Main tank Heater
if ( ReefAngel.Params.Temp[ T1_PROBE ] <= 750 ) ReefAngel.Relay.On( Port3 ); // Tank Temperature low limit
// Refugium Lights code
ReefAngel.StandardLights( Port4,23,0,5,0 ); // Refugium Lights
// ATO code
ReefAngel.StandardATO( Port6,90 ); // ATO Port
// LED Lights code
//ReefAngel.StandardLights( Port2,13,0,24,0 ); // LED fixture power
//ReefAngel.PWM.SetDaylight( PWMSlope( 16,0,22,0,2,50,60,0 ) ); // Daylight PWMSlope
//ReefAngel.PWM.SetActinic( PWMSlope( 15,0,23,0,2,45,60,0 ) ); // Actinic PWMSlope
// Feeding code
ReefAngel.StandardLights( Port1,18,55,19,20 );
//if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port8 ); // During Feeding Mode, port turned Off
else ReefAngel.Relay.On( Port8 );
// Kalk dosing code
if ( ReefAngel.Params.PH >= 100 && ReefAngel.Params.PH <= 620 ) ReefAngel.Relay.Off( Port7 ); // Failsafe to shut-off reactor.
ReefAngel.Portal( "acabano" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT5=LftrRefuPmpUv
// RA_LABEL LABEL_PORT8=RtnSkmWavePwrHd
// RA_LABEL LABEL_PORT2=DayActLight
// RA_LABEL LABEL_PORT6=ATO
// RA_LABEL LABEL_PORT1=Feed
// RA_LABEL LABEL_PORT4=RefuLight
// RA_LABEL LABEL_PORT7=Kalk
// RA_LABEL LABEL_DAYLIGHT=Daylight
// RA_LABEL LABEL_PORT3=Heater
// RA_LABEL LABEL_ACTINIC=Actinic
//#include <ORP.h>
// Delayed On
// Tank Heater code
// ATO code
// LED Lights code
// Feeding code
// Kalk dosing code
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
acabano13
ended up using the below statements, but would like to add some kind of a timeout to "if ( ReefAngel.Params.PH <= 8000 ) ReefAngel.Relay.On( Port7 );"
// Kalk dosing code
if ( ReefAngel.Params.PH >= 1000 && ReefAngel.Params.PH <= 6200 ) ReefAngel.Relay.Off( Port7 ); // Failsafe to shut-off reactor
if ( ReefAngel.Params.PH >= 8100 ) ReefAngel.Relay.Off( Port7 );
// Kalk dosing code
