Help with kalk dosing, base on PH and ReefAngel.HighATO.IsActive()
Posted: Mon Jan 15, 2024 7:23 pm
by acabano13
Hello,
tried the code below, but looks like with the float switch moving up and down(water flow), the ATO SW relay port is toggling, any pointers is greatly appreciated.
if ( ReefAngel.Params.PH > 810 ) ReefAngel.Relay.Off( Port7 );
if ( ReefAngel.Params.PH < 800 && ReefAngel.HighATO.IsActive() < 1) ReefAngel.Relay.On( Port7 );
Note:
kalk dosing, base on PH and ReefAngel.HighATO.IsActive() if possible.
Re: Help with kalk dosing, base on PH and ReefAngel.HighATO.IsActive()
Posted: Mon Jan 15, 2024 7:51 pm
by brennyn21
Do you have another port that is also based off the HighATO port then?
Posted: Mon Jan 15, 2024 7:56 pm
by acabano13
yes, port 6 I'm currently using as a standard ATO
Posted: Mon Jan 15, 2024 8:29 pm
by brennyn21
Can you post your code?
Posted: Mon Jan 15, 2024 8:44 pm
by brennyn21
this will keep port 6 off if that is your goal when port 7 is on
if ( ReefAngel.Relay.Status( Port7 ) ) ReefAngel.Relay.Off( Port6 );
if (ReefAngel.Params.PH > 810) {
ReefAngel.Relay.Off(Port7);
if (ReefAngel.Params.PH < 800 && ReefAngel.HighATO.IsActive() < 1) {
ReefAngel.Relay.On(Port7);
Posted: Tue Jan 16, 2024 1:24 am
by acabano13
My observation with the kalk code below, is that the port 7 toggles when PH value fluctuates, same with the float sw (movement)
//#include <Salinity.h>
//#include <ORP.h>
//#include <DCPump.h>
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
// Calibrate PH probe
ReefAngel.PHMin=567;
ReefAngel.PHMax=872;
ReefAngel.Relay.On( Port2 ); // DayActLight
ReefAngel.Relay.On( Port5 ); // Lifter, Refugium pump, UV Pump and UV Sterilizer
ReefAngel.Relay.On( Port8 ); // Return, Powerhead, Skimmer and Wavemaker Pump
// Ports that are always off
ReefAngel.Relay.Off( Port7 ); // Kalk Pump
// Delayed On
//ReefAngel.Relay.DelayedOn( Port2,8 ); for Skimmer
// Tank Heater code
ReefAngel.StandardHeater( T1_PROBE,Port3,770,780 ); // Main tank Heater
if ( ReefAngel.Params.Temp[ T1_PROBE ] <= 750 ) ReefAngel.Relay.On( Port3 ); // Tank Temperature low limit
// Refugium Lights code
ReefAngel.StandardLights( Port4,23,0,5,0 ); // Refugium Lights
// ATO code
ReefAngel.StandardATO( Port6,90 ); // ATO Port
// LED Lights code
//ReefAngel.StandardLights( Port2,13,0,24,0 ); // LED fixture power
//ReefAngel.PWM.SetDaylight( PWMSlope( 16,0,22,0,2,50,60,0 ) ); // Daylight PWMSlope
//ReefAngel.PWM.SetActinic( PWMSlope( 15,0,23,0,2,45,60,0 ) ); // Actinic PWMSlope
// Feeding code
ReefAngel.StandardLights( Port1,18,55,19,20 );
//if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port8 ); // During Feeding Mode, port turned Off
else ReefAngel.Relay.On( Port8 );
// Kalk dosing code
if ( ReefAngel.Params.PH >= 100 && ReefAngel.Params.PH <= 620 ) ReefAngel.Relay.Off( Port7 ); // Failsafe to shut-off reactor.
ReefAngel.Portal( "acabano" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT5=LftrRefuPmpUv
// RA_LABEL LABEL_PORT8=RtnSkmWavePwrHd
// RA_LABEL LABEL_PORT2=DayActLight
// RA_LABEL LABEL_PORT6=ATO
// RA_LABEL LABEL_PORT1=Feed
// RA_LABEL LABEL_PORT4=RefuLight
// RA_LABEL LABEL_PORT7=Kalk
// RA_LABEL LABEL_PORT3=Heater
Posted: Wed Jan 17, 2024 10:15 pm
by acabano13
ended up using the below statements, but would like to add some kind of a timeout to "if ( ReefAngel.Params.PH <= 8000 ) ReefAngel.Relay.On( Port7 );"
// Kalk dosing code
if ( ReefAngel.Params.PH >= 1000 && ReefAngel.Params.PH <= 6200 ) ReefAngel.Relay.Off( Port7 ); // Failsafe to shut-off reactor
if ( ReefAngel.Params.PH >= 8100 ) ReefAngel.Relay.Off( Port7 );
