cloud wifi attachment constantly uploading
javisaman
Post by javisaman »
Hi,
I've updated both my Reef Angel Plus and the Wifi attachment per the instructions. The UAPP seems to be working fine, however, I've noticed that the indicator light (for the Cloud Wi-Fi attachment) is constantly blinking. This wasn't the behavior before as it was only blinking when it was uploading to cloud. Is this the correct behavior?
brennyn21
Re: cloud wifi attachment constantly uploading
Post by brennyn21 »
What color is it blinking? The colors should all be the same as before
Sincerely, Brennyn
javisaman
Post by javisaman »
It's blinking cyan. The difference now it is constantly blinking (like 5Hz)
brennyn21
Post by brennyn21 »
Try factoring resetting it, then updating the firmware. The manual is here https://reefangel.com/wp-content/upload ... -2.0.1.pdf I'll look through the code to see if i can find the issue.
Sincerely, Brennyn
brennyn21
Post by brennyn21 »
Can you try updating your cloud Wi-Fi attachment I just uploaded a new firmware that should fix the issue.
Sincerely, Brennyn
javisaman
Post by javisaman »
I will update the firmware. But it does seem to have fixed itself when I put it in waterchange mode.
