cloud wifi attachment constantly uploading
Posted: Wed Feb 21, 2024 10:20 am
by javisaman
Hi,
I've updated both my Reef Angel Plus and the Wifi attachment per the instructions. The UAPP seems to be working fine, however, I've noticed that the indicator light (for the Cloud Wi-Fi attachment) is constantly blinking. This wasn't the behavior before as it was only blinking when it was uploading to cloud. Is this the correct behavior?
Re: cloud wifi attachment constantly uploading
Posted: Wed Feb 21, 2024 10:24 am
by brennyn21
What color is it blinking? The colors should all be the same as before
Posted: Wed Feb 21, 2024 10:30 am
by javisaman
It's blinking cyan. The difference now it is constantly blinking (like 5Hz)
Posted: Wed Feb 21, 2024 11:43 am
by brennyn21
Try factoring resetting it, then updating the firmware. The manual is here https://reefangel.com/wp-content/upload ... -2.0.1.pdf I'll look through the code to see if i can find the issue.
Posted: Thu Feb 22, 2024 8:32 pm
by brennyn21
Can you try updating your cloud Wi-Fi attachment I just uploaded a new firmware that should fix the issue.
Posted: Fri Feb 23, 2024 8:53 am
by javisaman
I will update the firmware. But it does seem to have fixed itself when I put it in waterchange mode.
