Were the internal memory options under settings removed with the recent uapp updates? Previously I could adjust the dosing times in the internal memory section of the uapp. What would be the best way to update these values now?
Thanks.
UApp internal memory options
- brennyn21
Re: UApp internal memory options
Hi Tngo, they were not removed. You may need to log back into the Uapp to reauthenticate to show the Internal Memory Settings and other tabs.
If that doesn't work please post a screenshot.
Sincerely, Brennyn
tngo
Logging and logging back in did the trick. Thanks for all your efforts on the new updates.
tngo
tngo
- brennyn21
Glad you like them! I have a lot of exciting new things in the works. Thank you and to everyone else for being patient in this transition!
Sincerely, Brennyn
