Help me develop my PDE
Posted: Fri Feb 24, 2012 7:11 pm
by jcm2m9
I have owned my ReefAngel now for around 6 months and have been lurking the forums and begging Robert to help me develop my PDE. I have decided to start a thread to get all my ideas completed.
My RA is on my 14g biocube with retrofitted leds from Modularled. I have my whites and blues on two separate drivers. My whites are on a meanwell that is dimmed through PWM. I am successfully controlling my leds with the controller and simulating clouds and T-storms.
The first thing I would like to add is the code for a single low ATO. I have ordered the ATO kit from AVAST marine with the RA connection. I know I need to add the following line of code, but do not understand all the functions.
ReefAngel.SingleATO(true, Port1, 60, 1);
Could someone tell me what all the options do?
In the future I would like to make a custom main and menu system, but I would like to get the small things working first.
Below is my current PDE.
// Autogenerated file by RAGen (v1.1.0.126), (01/30/2012 21:35)
// RA_013012_2135.pde
#define MetalHalideSetup
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define WDT
#define PWMEXPANSION
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Give labels to outlets for easier programming
#define Fan                 8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
byte DaylightPWMValue=0;
	ReefAngel.LCD.DrawDate(6, 112);
	ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
	ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
	ReefAngel.LCD.DrawGraph(5, 5);
    ReefAngel.FeedingModePorts = B00010000;
    ReefAngel.WaterChangePorts = B00011100;
    ReefAngel.OverheatShutoffPorts = B00000011;
    ReefAngel.LightsOnPorts = B00000011;
    ReefAngel.Relay.On(Skimmer);
    ReefAngel.Relay.On(Return);
    ReefAngel.Relay.On(Vortech);
    ReefAngel.Relay.On(Fan);
    // Specific functions
    ReefAngel.MHLights(WhiteLED);
    ReefAngel.StandardLights(BlueLED);
    ReefAngel.StandardHeater(Heater);
    DaylightPWMValue=PWMSlope(12,00,20,00,13,40,200,DaylightPWMValue);
    //ReefAngel.PWM.SetActinic(MoonPhase());
    //DaylightPWMValue=100;
    CheckCloud();
  void CheckCloud()
  #define Clouds_Every_X_Days 1
  #define Min_Cloud_Duration 5
  #define Max_Cloud_Duration 20
  #define Min_Clouds_per_Day 0
  #define Max_Clouds_per_Day 5
  #define Start_Cloud_After NumMins(00,00)
  #define End_Cloud_Before NumMins(23,59)
  #define Lightning_Change_per_Cloud 50
    static byte cloudchance=255;
    static byte cloudduration=0;
    static int cloudstart=0;
    static byte numclouds=0;
    static byte cloudindex=0;
    static int LastNumMins=0;
#ifdef forcecloudcalculation
      if (cloudchance==255)
  #else
  #endif
        cloudchance=random(100);
        // If we have cloud today
        if (cloudchance)
          lightningchance=random(100);
   if (cloudchance)
      //is it time for cloud yet?
        if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<10)
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
        if (cloudindex < numclouds)
        int x=0;
        if ((cloudstart/60)>=10) x=11; else x=17;
        if ((cloudstart%60)>=10) x=29; else x=35;
      if (lightningchance)
        int x=0;
        if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
        if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
        ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
    cstart*=60;
    cend*=60;
    if (n>cend) return PWMStart;
Re: Help me develop my PDE
Posted: Fri Feb 24, 2012 8:56 pm
Here's what the options mean:
true - Use the LOW ato switch / connection
Port1 - The port / relay that is toggled based on the status of the port
60 - The number of seconds for the timeout.  This is the maximum number of seconds that the relay will be on before triggering an alert.
1 - This is the hour interval.  This means that the ATO port is only able to run 1 time per hour.  This can prevent it from running too often if the water fluctuates a lot.  You can put a 0 in to disable the hour interval.
Hopefully this explains and helps.
Posted: Sat Feb 25, 2012 7:02 am
by jcm2m9
binder wrote:Here's what the options mean:
Awesome, that is exactly what I was looking for. I searched the forum for an hour and never found that.
Posted: Sat Feb 25, 2012 7:11 am
yeah that information isn't really on the forum. it's all in the library source code. it has been tough to get a good list of things since the code continually evolves and improves. good suggestions. glad it helped.
Posted: Sun Feb 26, 2012 6:10 pm
by jcm2m9
I have worked a little on my PDE. I added the code for the ATO and found a mainscreen that like. I edited the layout and colors slightly.
When go to compile the code I get a compile error at:
#define Vortech 5
Here is the error:
Current_PDE_0226:42: error: 'vvoid' does not name a type
Current_PDE_0226:50: error: 'vvoid' does not name a type
#define wifi
#define WDT
#define ATO                 8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
vvoid DrawCustomMain()
  ReefAngel.LCD.DrawText(COLOR_RED, COLOR_BLUE, 0, 0, "                       "); //Top Banner
  ReefAngel.LCD.DrawText(COLOR_RED, COLOR_BLUE, 0, 2, " BioCube 14 Nano Reef  "); //Top Banner
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
  // Display the T1 temp value 10,22
  char text[7];
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 10, 22, text, Num8x16);
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,100,12,"pH");
  // Display pH Value
  ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 90, 22, text, Num8x16);
  // Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
  // Display the Actinic PWM channel value at 90,40
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_RED, 90, 40, 1);
  // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
  // Display the Daylight PWM channel value at 90,50
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_RED, 90, 50, 1);
  // Display T2 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,60,"LED Temp");
  // Display the T2 temperature value at 90,60
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_RED, 90, 60, 10);
  // Display T3 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,70,"Ambient Temp");
  // Display the T3 temperature at 90,70
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_RED, 90, 70, 10);
  // Display Vortech MP10ew Mode Text at 90, 80
  ReefAngel.LCD.DrawText(0,255,8,80,"ATO On?");
  // Display EcoSmart Mode Value
  ReefAngel.LCD.DrawText(COLOR_RED,255,90,80,"Yes");
  //#if defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params,
    //ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
  //#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params);
  //#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
// ReefAngel.LCD.DrawGraph(5,7);
    DaylightPWMValue=PWMSlope(12,00,20,00,13,20,200,DaylightPWMValue);
    CheckCloud();
    ReefAngel.SingleATO(true, ATO, 60, 1);
  void CheckCloud()
  #else
  #endif
        if (cloudchance)
   if (cloudchance)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
        int x=0;
        int x=0;
    cstart*=60;
    cend*=60;
Posted: Sun Feb 26, 2012 6:21 pm
change this:
To this:
Posted: Mon Feb 27, 2012 10:01 am
by jcm2m9
WOW! I feel stupuid now. I can not believe that I missed that!
Next question.
In my custommain area I have this snipet of code:
  // Display ATO Text at 90, 80
  // Display ATO value
What I would like this to do is tell me if the ATO pump is running. This would be done in the //Display ATO value line
Posted: Mon Feb 27, 2012 10:31 am
Try this:
if (bitRead(ReefAngel.Relay.RelayData,7)
ReefAngel.LCD.DrawText(COLOR_RED,255,90,80,"No ");
Posted: Thu Mar 01, 2012 10:31 am
by jcm2m9
Ok, everything is working so far. I have a few other questions though.
On my custom main where is the code to show when clouds and lighting will happen? On my screen this and the date are covering eachother up.
Also, if I wanted to add a second float switch for high water lever, how would I do this? What code needs to be added?
Posted: Thu Mar 01, 2012 12:51 pm
Can you post your latest code?
Posted: Fri Mar 02, 2012 6:08 am
by jcm2m9
I forgot to grab my latest code, but it should be all the same as the one I posted above except f or the snipets of code I asked you about.
#define wifi
#define WDT
#define ATO                 8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
  char text[7];
  // Display pH Text
  // Display pH Value
    CheckCloud();
  void CheckCloud()
  #else
  #endif
        if (cloudchance)
   if (cloudchance)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
        int x=0;
        int x=0;
    cstart*=60;
    cend*=60;
Posted: Fri Mar 02, 2012 9:42 am
Try this:
#define wifi
#define WDT
#define ATO                 8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
  char text[7];
  // Display pH Text
  // Display pH Value
    CheckCloud();
  void CheckCloud()
  #else
  #endif
        if (cloudchance)
   if (cloudchance)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
      ReefAngel.LCD.Clear(255,0,112,132,122);
      ReefAngel.LCD.DrawText(0,255,5,112,"C");
      ReefAngel.LCD.DrawText(0,255,11,112,"00:00");
      ReefAngel.LCD.DrawText(0,255,45,112,"L");
      ReefAngel.LCD.DrawText(0,255,51,112,"00:00");
        int x=0;
        ReefAngel.LCD.DrawText(0,255,x,112,(cloudstart/60));
        ReefAngel.LCD.DrawText(0,255,x,112,(cloudstart%60));
      ReefAngel.LCD.DrawText(0,255,90,112,cloudduration);
        int x=0;
        ReefAngel.LCD.DrawText(0,255,x,112,((cloudstart+(cloudduration/2))/60));
        ReefAngel.LCD.DrawText(0,255,x,112,((cloudstart+(cloudduration/2))%60));
    cstart*=60;
    cend*=60;
C=Cloud in military time
L=Lightning in military time
3rd number is cloud duration
Posted: Fri Mar 02, 2012 10:04 am
by jcm2m9
What line in the code is telling it to display that information?
Posted: Fri Mar 02, 2012 10:12 am
        int x=0;
        int x=0;
Posted: Mon Mar 05, 2012 10:20 am
by jcm2m9
Awesome, I have everything working!
The only issue I have been having is with changing the background color. I want to change it all to blue, but can not get the background behind the switch from white. Any ideas?
Posted: Mon Mar 05, 2012 8:25 pm
Behind what switch are you talking about?
When you use the LCD.DrawText(...) function, the first parameter is the foreground color (text) and the second parameter is the background color. In the previous code post that Roberto did, it's hard coded to use black text (0) and white background (255). I would change the 255 to be COLOR_BLUE or whatever color you want it to be to match the rest of your controller.
Then, you would also want to change the first parameter in the LCD.Clear(...) function from 255 to COLOR_BLUE (or whatever color you use).
If you have the custom colors enabled and change your default background and foreground values, then you can just change those values to DefaultBGColor and DefaultFGColor.
Hopefully that makes sense to you.
Posted: Tue Mar 06, 2012 6:06 am
by jcm2m9
binder wrote:Behind what switch are you talking about?
I will take a look at this tonight
Also, I have been noticing that the internal memory seems to take precedence over the timeout of the ATO. is this the case? I have been adjusting the 60 in the following lien and it does not seem to change anything.
Posted: Tue Mar 06, 2012 10:42 am
jcm2m9 wrote:Also, I have been noticing that the internal memory seems to take precedence over the timeout of the ATO. is this the case? I have been adjusting the 60 in the following lien and it does not seem to change anything.
The function you mention only uses the values that are given to it. The SingleATOLow() and SingleATOHigh() use the internal memory values.
When I look at your function you are showing, it tells me that you want to use the Low ato port and that it can run only 1 time in a given hour time frame for a maximum of 60 seconds per run. So if it activates at 8:30a, it can only run for a max of 60 seconds before the timeout kicks in. It's then not able to run again until 9:30a. The 60 just tells the maximum number of seconds that the port will be allowed to stay on before an error is triggered and the port gets shutoff.
Posted: Tue Mar 06, 2012 11:23 am
by jcm2m9
That is exactly what happens, but if I change the 60 to say 120 it still only runs for 60s and then timesout. It will only run longer if I change the internal memory.
Posted: Sat Mar 10, 2012 9:03 am
by jcm2m9
Ok, I am having problems with my ATO, or so I think. I am not 100% positive that it is shutting off.
I am using the Avast ATO and I am not positive that it is working correctly. Is there anyway for me to display on the controller what the last time the ATO pump ran and possible for how long it ran? It would make my troubleshooting much easier.
Here is my current PDE.
#define wifi
#define WDT
#define ATO                 8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
  char text[7];
  // Display pH Text
  // Display pH Value
  if bitRead(ReefAngel.Relay.RelayData,7)
    ReefAngel.WaterChangePorts = B10011100;
    ReefAngel.LightsOnPorts = B01000011;
    ReefAngel.MHLights(Sump);
    DaylightPWMValue=PWMSlope(14,00,18,00,13,45,60,DaylightPWMValue);
    CheckCloud();
    //ReefAngel.SingleATO(true, ATO, 360, 1);
    ReefAngel.SingleATOLow(ATO);
  void CheckCloud()
  #else
  #endif
        if (cloudchance)
   if (cloudchance)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
        int x=0;
        int x=0;
    cstart*=60;
    cend*=60;
Posted: Sat Mar 10, 2012 10:11 am
Try this:
#define wifi
#define WDT
#define AutoTopOff          8
#define Sump                7
#define Heater              6
#define Vortech             5
#define Return              4
#define Skimmer             3
#define BlueLED             2
#define WhiteLED            1
byte ATOrunning=0;
time_t lastATO=0;
  char text[7];
  // Display pH Text
  // Display pH Value
     if (!ATOrunning)
       int x;
       ReefAngel.LCD.DrawText(COLOR_RED,255,10,89,"00:00");
       if (hour()<10) x=16; else x=10;
       ReefAngel.LCD.DrawText(COLOR_RED,255,x,89,hour());
       if (minute()<10) x=32; else x=28;
       ReefAngel.LCD.DrawText(COLOR_RED,255,x,89,minute());
       ATOrunning=true;
       lastATO=now();
    ReefAngel.LCD.DrawText(COLOR_RED,255,90,89,"    ");
    if (ATOrunning) ReefAngel.LCD.DrawText(COLOR_RED,255,90,89,int(now()-lastATO));
    ATOrunning=false;
    CheckCloud();
    ReefAngel.SingleATOLow(AutoTopOff);
  void CheckCloud()
  #else
  #endif
        if (cloudchance)
   if (cloudchance)
            DaylightPWMValue=0;
          delay(1);
        cloudindex++;
        int x=0;
        int x=0;
    cstart*=60;
    cend*=60;
Posted: Wed Mar 14, 2012 4:49 pm
by jcm2m9
Quick question, if the controller hits the time out (IE exceeds the ato timelimit) will the ato run the next hour when it is supposed to turn on or does the ATO have to be "cleared"?
Posted: Wed Mar 14, 2012 5:00 pm
by jcm2m9
K, dumb question. If I am using a single ATO to detect a low water scenario in my sump and to add water when this happens should I be using the Low or High ATO funtion?
Posted: Wed Mar 14, 2012 5:10 pm
jcm2m9 wrote:K, dumb question. If I am using a single ATO to detect a low water scenario in my sump and to add water when this happens should I be using the Low or High ATO funtion?
You can use either function. The function correlates with the ato switch you are using.
Posted: Wed Mar 14, 2012 5:38 pm
by jcm2m9
jcm2m9 wrote:Quick question, if the controller hits the time out (IE exceeds the ato timelimit) will the ato run the next hour when it is supposed to turn on or does the ATO have to be "cleared"?
What's the answer to this question? I am just trying to get my ATO figured out. It does not seem to work properly
Posted: Wed Mar 14, 2012 5:46 pm
No. If the timeout expires, the ATO port will shutoff and the LED will turn on. Next time it tries to run, it will NOT run. It will not run again until you clear the ato timeout.
If you haven't read the ATO guide, it may help you: http://forum.reefangel.com/viewtopic.php?f=7&t=240
Posted: Thu Mar 15, 2012 5:12 am
by jcm2m9
Here is my issue, the controller will not let my ato run long enough to trip my float switch. I have the timeout set for 250 with the hour portion being set at 0.
My aqualifter is about 3' from my tank so when it kicks on there is only a slow dribble.
Could I use this code instead?
void loop(){
    //ATO Sump too low
    if(ReefAngel.LowATO.IsActive()){
      //Water in sump too low, turn ATO on
      ReefAngel.Relay.On(AutoTopOff)
   else{
        ReefAngel.Relay.Off(AutoTopOff)
Posted: Thu Mar 15, 2012 5:37 am
Yes, you can use that. That should work just fine for you.
Posted: Thu Mar 15, 2012 6:20 am
by jcm2m9
Awesome, Thanks.
I am going to have a few questions about my custom main screen, but cant access my pde until I get home tonight.
