need help with custom menu.
Posted: Sun Mar 04, 2012 7:50 am
				When I go to menu and press on "PH Calibration" it bring me right back to the main menu, only feeding work but the rest just bring back to the main menu.I did load the Internal Mem prior to this. here' my code:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define RemoveAllLights
#define SIMPLE_MENU
#define CUSTOM_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x16
    #define AutoTopOff        1
    #define Daylight          2
    #define Actinic           3
    #define StandardLight     4
    #define Moonlight         5
    #define Heater            6
    #define Skimmer           7
    #define Return            8
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Port7);
    ReefAngel.LCD.DrawDate(6, 112);
    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
    ReefAngel.LCD.DrawGraph(5, 5);
    ReefAngel.FeedingModePorts = Port8Bit;
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1,5);
    ReefAngel.StandardLights(Port2,13,30,22,0);
    ReefAngel.StandardLights(Port3,13,30,22,0);
    ReefAngel.StandardLights(Port4,15,0,21,30);
    ReefAngel.StandardLights(Port5,21,30,9,0);
    ReefAngel.StandardHeater(Port6,885,840);
    ReefAngel.PWM.SetActinic(PWMSlope(13,30,22,0,30,60,60,20));
    ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,0,20,50,60,20));
