need help with custom menu.
kevin36
Post by kevin36 »
When I go to menu and press on "PH Calibration" it bring me right back to the main menu, only feeding work but the rest just bring back to the main menu.I did load the Internal Mem prior to this. here' my code:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define RemoveAllLights
#define SIMPLE_MENU
#define CUSTOM_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x16
    #define AutoTopOff        1
    #define Daylight          2
    #define Actinic           3
    #define StandardLight     4
    #define Moonlight         5
    #define Heater            6
    #define Skimmer           7
    #define Return            8
#include <avr/pgmspace.h>
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Port7);
    ReefAngel.FeedingModePorts = Port8Bit;
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1,5);
    ReefAngel.StandardLights(Port2,13,30,22,0);
    ReefAngel.StandardLights(Port3,13,30,22,0);
    ReefAngel.StandardLights(Port4,15,0,21,30);
    ReefAngel.StandardLights(Port5,21,30,9,0);
    ReefAngel.StandardHeater(Port6,885,840);
    ReefAngel.PWM.SetActinic(PWMSlope(13,30,22,0,30,60,60,20));
    ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,0,20,50,60,20));
Re: need help with custom menu.
I'm getting the same thing :(
Let me see if I can find out anything.
kevin36
Post by kevin36 »
Can you help me build my pde .I just want to add couple menu to my pde
, on/off skimmer and on/off lighting (port 2,3,4).
I think I'm gonna need Curt's help on this one :(
None of the menus work.
There were several errors with the INO file when I tried to compile it (using the Features that were listed in the comments). I fixed it up and everything is working now. The reason why you were having issues was you did not specify how many menu entries there were. If that is left off, the libraries assume that there is only 1 menu entry and will only process 1 entry. You will still display all the entries but only 1 is active.
I also had to remove the "RemoveAllLights" define because that will not work with PWM stuff enabled and I removed the "SIMPLE_MENU" define because it was not needed since CUSTOM_MENU overrides it.
With that being said, you just need to update your ReefAngel_Features.h file and replace it with this:
// AutoGenerated file by RAGen (v1.2.2.162), (02/19/2012 17:34)
 * Copyright 2010-12 Curt Binder
 * Licensed under the Apache License, Version 2.0 (the "License")
#define VersionMenu
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES	9
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x16
#endif  // __REEFANGEL_FEATURES_H__
And for completeness, here is the INO file:
#define VersionMenu
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x16
    #define Daylight          2
    #define Actinic           3
    #define Moonlight         5
    #define Heater            6
    #define Skimmer           7
    #define Return            8
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
void MenuEntry9()
Now it works great for me.
kevin36
Post by kevin36 »
Many thanks to binder and rimai ,I'll try tomorrow.
