adding expansion hub
rossbryant1956
Post by rossbryant1956 »
Added expansion hub and additional outlet box; used test code - all seems well. Went to reload my regular *.ino and get a "undefined custom menu" error.
That would be correct since I haven't defined a custom menu, but I wasn't really ready to take that on yet; just wanted to get my regular code working again so I could begin programming for the new ports. When I attempted to remove references to the custom menu, I now get "too big" error.
Read a few of the posts about Arduino being a hog, tried that...no avail. Please help.
// Autogenerated file by RAGen (v1.2.1.158), (02/17/2012 22:55)
// RA_021712_2255.ino
// Current Prod Code
#define DateTimeSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define RelayExp
Ports assignment:
Port1 - Reservoir Heater
Port2 - Standard Lights
Port3 - Moon Lights
Port4 - Refugium Pumps
Port5 - WaveMaker One
Port6 - WaveMaker Two
Port7 - Heater
Port8 - Return Pump
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit; // Turn off Port4, Port 5, Port 6, Port8 when feeding mode is activated
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Port4, Port5, Port6, Port7 and Port8 when water change mode is activated
    ReefAngel.TempProbe = T2_PROBE;  // Set the 1st plug (which acts like the 2nd plug)
    ReefAngel.OverheatProbe = T2_PROBE;  // to monitor the overheat and temperatures
    ReefAngel.Relay.On(Port8); // Turn on Pump
    // Specific functions
    ReefAngel.StandardLights(Port2,8,00,23,00); // Regular Lights on at 8:00am and off at 11:00pm
    ReefAngel.StandardLights(Port3,00,30,03,30); // Moon Lights on at 12:30pm and off at 11:30pm
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.WavemakerRandom(Port5,15,60); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
    ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Turn Port6 on/off on opposite cycle as Port 5
    // Port 5 and 6 are synchronized.
    // They work in opposing motion of each other at random times.
    // turn on port 7 when temp falls below 76.0 and turn off when temp gets above 80.0
    if (ReefAngel.Params.Temp[T2_PROBE] <= 780 && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(Port7);
    if (ReefAngel.Params.Temp[T2_PROBE] >= 791) ReefAngel.Relay.Off(Port7);
    if (ReefAngel.Params.Temp[T1_PROBE] <= 780 && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(Port1);
    if (ReefAngel.Params.Temp[T1_PROBE] >= 791) ReefAngel.Relay.Off(Port1);
    ReefAngel.Portal("rossbryant1956");
rossbryant1956
Re: adding expansion hub
// AutoGenerated file by RAGen (v1.2.1.158), (03/04/2012 15:52)
 * Copyright 2010-12 Curt Binder
 * Licensed under the Apache License, Version 2.0 (the "License")
#define DisplayImages
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 0
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define IOEXPANSION
#endif  // __REEFANGEL_FEATURES_H__
My original goal was to add one thing at a time, following best practices so I'll know what broke when troubleshooting, so that is what I was doing, adding the additional outlets. Since I am having to seek help I went ahead and added the I/O expansion unit. I redid the instructions in re: RAGen and am attaching my *.h file for review.
Get rid of these:
rossbryant1956
I assume you mean these lines from both my .ino as well as from my .h files. I found some in both files and 1 only in the .h file. thx
The ones on the ino are just comments. I meant the ones in the .h file
rossbryant1956
thx, did it. Should I have both of these in my .h
#define SIMPLE_MENU
#define CUSTOM_MAIN
Simple menu is a good one to reduce size and custom main is going to be applicable when you start creating your own screen.
I'm sure that with the I/O and Relay module, you will want to create your own screen.
Custom main is not being used on the cobe you posted above though.
rossbryant1956
I am going to pull it out so I can get the code working on simple menu. I now get this error:
reefangel.h: 106: error: "IOClass" does not name a type when I try to verify the code
You need the IOExpansion module in your .h file.
Open RAGen->Features Tab
Check I/O Expansion and hit save.
rossbryant1956
it was in my .h
This line was not in my .ino
