aqua illumination
wijigong
aqua illumination
Post by wijigong »
i try this code
i receive this error
Ai_Clouds.cpp: In function 'void CheckCloud()':
Ai_Clouds:168: error: 'ReversePWMSlope' was not declared in this scope
Ai_Clouds:205: error: a function-definition is not allowed here before '{' token
Ai_Clouds:231: error: a function-definition is not allowed here before '{' token
Ai_Clouds:265: error: expected `}' at end of input
//#include <Salinity.h>
//#include <RF.h>
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
//custom dysplay temp+on and off relay
   byte x = 6;
   byte y = 2;
   byte t;
   ReefAngel.LCD.DrawDate(6, 2);
   x = 12;
   y += MENU_START_ROW+1;
    ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "TEMP        pH");
   char text[7];
   ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);
   y += MENU_START_ROW*2;
   x = 10;
   ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y,text);
   ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
else lightningstatus=0;
if (lightningstatus)
WhiteValue=50;
BlueValue=50;
RoyalBlueValue=50;
WhiteValue=0;
BlueValue=0;
RoyalBlueValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
   randomSeed(analogRead(0));
   ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
   ReefAngel.Timer[1].Start();
   ReefAngel.Relay.On(Port6);
   ReefAngel.FeedingModePorts = B00110000;
   ReefAngel.OverheatShutoffPorts = B00001110;
   ReefAngel.WaterChangePorts = B11110001;
   ReefAngel.Relay.On(Port8);
   ReefAngel.Relay.On(Port7);
   ReefAngel.Relay.On(Port2);
    CheckCloud();
    ReefAngel.AI.SetChannel(White,WhiteValue);
    ReefAngel.AI.SetChannel(Blue,BlueValue);
    ReefAngel.AI.SetChannel(RoyalBlue,RoyalBlueValue);
  ReefAngel.AI.SetPort(lowATOPin);
  ReefAngel.StandardHeater(Port4);
  ReefAngel.SingleATOHigh(Port1);
  //wave maker fonction with night mode
   if ( (hour() >= 22) || (hour() <= 8) ) // from 10p - 8a
      ReefAngel.Relay.Off(Port6);
      ReefAngel.Relay.On(Port5);
      // during the day
         ReefAngel.Timer[1].SetInterval(random(25,50));
         ReefAngel.Relay.Toggle(Port6);
    if (hour()>=22 || hour()<9)
  ReefAngel.AI.SetChannel(White,0);
  ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.06);
  ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.06);
  ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
  ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,21,0,8,35,240,8));
  ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,21,0,8,35,240,8));
Re: aqua illumination
You forgot to add the ReversePWMSlope to your code.
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
wijigong
Post by wijigong »
the prog for the aqua illumination work on 0 to 240 range
if rules of three work for find in %
and this ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
is 9 am to 21 pm and 3,30,200,3????
yes, it is simple interpolation.
Here is the PWMSlope function description:
http://forum.reefangel.com/viewtopic.php?f=12&t=16
wijigong
Post by wijigong »
is that working on the low ato port or just on the high ato
You can do either.
Check this thread:
http://forum.reefangel.com/viewtopic.php?f=2&t=459
If using low you need to change the pin assignment:
Or
ReefAngel.AI.SetPort(highATOPin);
