Migrating to 0.9
rwijbenga
Migrating to 0.9
Post by rwijbenga »
Hi All,
I am trying to get my very simple sketch to work in 0.9 but I get compile errors about relay has no member. Has there something been changed with the relay function ?
What should be changed ? :?
This is my sketch:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port8);
  // Specific functions
  ReefAngel.StandardLights(Port3);
  ReefAngel.MHLights(Port2);
  ReefAngel.StandardHeater(Port4);
//CO2
  if ( ReefAngel.Params.PH <= 675 )
    ReefAngel.Relay.Off(Port5);
  if ( ReefAngel.Params.PH >= 690  )
    ReefAngel.Relay.On(Port5);
//Bubbles
  if ( ReefAngel.Params.PH <= 580 )
    ReefAngel.Relay.On(Port7);
  if ( ReefAngel.Params.PH >= 595 )
    ReefAngel.Relay.Off(Port7);
//Chiller
  if ( ReefAngel.Params.Temp1 >=315 )
    ReefAngel.PWM.SetDaylight(100);
  if ( ReefAngel.Params.Temp1 <=300 )
    ReefAngel.PWM.SetDaylight(0);
  if (hour()>20 || hour()<9)
    // ReefAngel.Relay.On(Port3);
    ReefAngel.PWM.SetActinic(0);
Re: Migrating to 0.9
What has been changed is the library names.
So the headers on top of the code needs renaming.
http://forum.reefangel.com/viewtopic.php?f=7&t=725
Try this:
//CO2
//Bubbles
//Chiller
  if ( ReefAngel.Params.Temp[T1_PROBE] >=315 )
  if ( ReefAngel.Params.Temp[T1_PROBE] <=300 )
rwijbenga
Post by rwijbenga »
I still get a strange error about the twowire.
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp: In static member function 'static void DS1307RTC::read(tmElements_t&)':
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:56: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:65: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:66: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:67: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:68: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:69: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:70: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:71: error: 'class TwoWire' has no member named 'read'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp: In static member function 'static void DS1307RTC::write(tmElements_t&)':
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:87: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:88: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:89: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:90: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:91: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:92: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:93: error: 'class TwoWire' has no member named 'write'
C:\Users\rwijbenga.WA\Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:94: error: 'class TwoWire' has no member named 'write'
I could not find the name change for the DS1307RTC library.
Any sugestions ?
I think you got a mix of old and new libraries...
You should just rename the entire libraries folder located at "Documents\Arduino\libraries" to librariesold.
Then just download latest using update utility: http://www.reefangel.com/update
