I have a little problem. My controller boots up, and then the screen flashes and the red led blinks.
I cannot go to any menu
here is my code
// Autogenerated file by RAGen (v1.2.1.158), (03/29/2012 21:11)
// RA_032912_2111.ino
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define wifi
#define SaveRelayState
#define RelayExp
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 1
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_EXCEED_FLAGS
#define SALINITYEXPANSION
#define RFEXPANSION
#define IOEXPANSION
#define FONT_8x8
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Item 1";
menu0_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.Relay.DelayedOn(Port2, 1);
ReefAngel.StandardATO(Port3);
ReefAngel.MoonLights(Port5);
ReefAngel.Portal("Jnieuwenhuizen");
ReefAngel.Refresh();
//Custom Main, Graph & Menu
byte x = 6;
byte y = 2;
byte t;
char text[7];
byte vtechmode;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
vtechmode=ReefAngel.RF.Mode;
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawOutletBox(12, 89, TempRelay);
ReefAngel.LCD.DrawText(0,255,70,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
