Controller freez
Posted: Thu Mar 29, 2012 9:50 am
by JNieuwenhuizen
Hi.
I have a little problem. My controller boots up, and then the screen flashes and the red led blinks.
I cannot go to any menu
here is my code
// Autogenerated file by RAGen (v1.2.1.158), (03/29/2012 21:11)
// RA_032912_2111.ino
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define wifi
#define SaveRelayState
#define RelayExp
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 1
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_EXCEED_FLAGS
#define SALINITYEXPANSION
#define RFEXPANSION
#define IOEXPANSION
#define FONT_8x8
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Item 1";
menu0_label  };
void MenuEntry1()
    ReefAngel.DisplayMenuEntry("Item 1");
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Box1_Port2);
    ReefAngel.Relay.On(Box1_Port6);
    ReefAngel.Relay.On(Box1_Port8);
    // Specific functions
    ReefAngel.Relay.DelayedOn(Port2, 1);
    ReefAngel.StandardATO(Port3);
    ReefAngel.MoonLights(Port5);
    ReefAngel.StandardHeater(Port6);
    ReefAngel.Portal("Jnieuwenhuizen");
    ReefAngel.Refresh();
//Custom Main, Graph & Menu
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  byte vtechmode;
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  vtechmode=ReefAngel.RF.Mode;
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawOutletBox(12, 89, TempRelay);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
Any help please?
Re: Controller freez
Posted: Thu Mar 29, 2012 1:54 pm
by jsclownfish
Not sure if this is it or not, but I have changed these 0's to 1's in my ino file.
menu0_label  };
to
prog_char menu1_label[] PROGMEM = "Item 1";
menu1_label  };
-Jon
Posted: Thu Mar 29, 2012 5:39 pm
by JNieuwenhuizen
Thank You, did not solve it, had to unplug everything and start again.
At least it does not freeze now
Posted: Fri Mar 30, 2012 4:30 am
by Sebyte
You might try putting
At the bottom of the loop. I had a problem similar to what you are saying, and it appeared to be this.
Posted: Sat Mar 31, 2012 7:03 am
you do not need the:
line in there. That is called inside ShowInterface().
Posted: Mon Apr 02, 2012 1:51 pm
by JNieuwenhuizen
Thany you for the help - It was my expansion hub that made the controler freez-up
