Page 2 of 2
Re: RA Net with Relay doesn't seem to be working correctly.
Posted: Wed Jan 28, 2015 8:06 pm
by Sacohen
I had to unplug the relay from the power strip again today and I plugged it directly into the outlet and the same thing happened.
Red light on switch is on.
Logo is not illuminated at all.
No Ports on even fallback 8 and not control from Portal or App.
While I was sitting in the man cave watching TV I noticed that the lights would turn off for a second and then come back on. This happened twice.
Also my ATO was on forever, even past the 10 limit and the app would not update ate all, while the ATO was running.
So I looked at the head unit and the screen was flashing on and off. No display just white to off.
[youtube]http://youtu.be/wxJQJp_mneo[/youtube]
As Roberto always asks, what is new with the system and what have you added.
Well in this case it was the RA Net and Relay.
I opened the head unit up, disconnected the serial cable, and removed the RA Net board.
Connected it back up and the ATO was off, the screen display was on and the App was interfacing with it.
Something strange is up with the RA Net board.
I just looked at my head unit now and the screen is blank, just a grey screen, but not flashing.
This is with the RA Net board out of the head unit.
Posted: Wed Jan 28, 2015 10:21 pm
Something is definitely wrong.
Can you send it back for me to look at it?
Posted: Thu Jan 29, 2015 12:55 pm
by Sacohen
Do you want the relay too or just the board?
You probably just need the board.
Do I need an RMA?
Also why would I still have no display on the screen, just a grey blank screen?
Posted: Thu Jan 29, 2015 12:56 pm
I think the relay box too just in case.
Send me a PM
Posted: Thu Jan 29, 2015 1:02 pm
by Sacohen
No Problem. PM sent.
Posted: Thu Jan 29, 2015 4:52 pm
by Sacohen
Strange thine happened today.
Like I said I unplugged the Relay again yesterday and lost everything except the Red Power switch Illumination.
Well today I gained sync (Solid White Logo) and port 8 fallback came on.
Now this is the strange part, I removed the RA Net board from the head unit yesterday so what is the Relay synching with?
Posted: Wed Feb 18, 2015 6:48 am
by Sacohen
I got the replacement RANet and relay yesterday. hooked it all up and it works fine.
Roberto said there was a problem with the receiver on the other unit.
Thanks for all the help with it though.
Posted: Fri Mar 06, 2015 3:11 am
by phrusher
davaraj wrote: LED on relay unit when Head unit is on but not in sync.
http://m.youtube.com/watch?v=067azYoRu74
That is pretty much exactly what the logo looks like for me too :/
Posted: Fri Mar 06, 2015 8:38 am
Does it ever sync?
Posted: Fri Mar 06, 2015 2:11 pm
by phrusher
rimai wrote:Does it ever sync?
It synced at some time when I just received the RANet and relay but I haven't used it in a while. Now when I tried it the logo has been flickering but never fading smoothly white/blue.
I just disconnected the RA and removed the RANet for a while before putting it back in. Now the logo on the relay box is not lit up at all, just the red power switch is lit. On the RANet ASC is blinking green.
I use this to test with now:
ReefAngel.AddRANet();
ReefAngel.Relay.RANetFallBackE[1] = Port3Bit;
Dip switch nr 1 is down and the other two in up position on the relay. Is that correct or is my head a bit slowish? Just want to see if it ever sync. Or should it be [0]? I also have the Power Control Expansion so I guess that would be [0]?
Posted: Fri Mar 06, 2015 8:00 pm
Power control is [0] and your relay box would be [1].
But I don't think it is that.
Maybe it is the RANet Add-On that is not good. I had to replace Sacohen when he sent me his stuff to troubleshoot.
I could never find out what the problem was.
I think it was a bad baking of the pcb when it went to the oven for reflow.
I'm assuming that you can't reprogram the RANet module either, right?
Posted: Sat Mar 07, 2015 6:57 am
by phrusher
rimai wrote:I'm assuming that you can't reprogram the RANet module either, right?
Do you mean reflash the firmware? I don't know but I can give it a try. I think I saw some step by step here somewhere, I'll see if I can find it again.
Posted: Mon Mar 09, 2015 8:14 am
by phrusher
Btw, are you referring to the sender or receiver? I only found instructions for reprogramming the receiver: http://forum.reefangel.com/viewtopic.php?p=45104#p45104
Posted: Mon Mar 09, 2015 8:35 am
Correct, the receiver.
Posted: Thu Mar 12, 2015 1:26 pm
by phrusher
The blue led on RSSI lights up when connecting the cable but in Arduino studio I get error uploading (w/ optiboot). See below for full output.
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done.  Thank you.
Posted: Thu Mar 12, 2015 1:28 pm
Can you try uploading without the xbee module?
If that doesn't work, we may need to get you another board.
Posted: Thu Mar 12, 2015 1:54 pm
by phrusher
Exactly the same error without the module mounted, but the RSSI LED did not light up.
Posted: Fri Mar 13, 2015 8:19 am
Yeah, we may need to replace.
I'm going to make a small batch.
Posted: Sat Mar 14, 2015 4:43 pm
by davaraj
I have a RANet wireless dimming module. For the past 2 days the lunar module connected to the wireless dimming module is not working. I think the dimming module is not syncing with the head unit. Can I reprogram the receiver in the wireless dimming module? I had done this to the receiver in the wireless relay box earlier when there were syncing problems.
Dr Davaraj
Posted: Sun Mar 15, 2015 12:06 pm
Yes, you can. Same way.
Posted: Mon Mar 16, 2015 5:43 am
by davaraj
phrusher wrote:The blue led on RSSI lights up when connecting the cable but in Arduino studio I get error uploading (w/ optiboot). See below for full output.
avrdude: Recv:
I get the exact same error when I try to reprogram the receiver on the dimming module. I also get the same error without the xbee module installed. The RSSI LED lights up for a fraction of a second when the code uploads before it fails.
Dr Davaraj
Posted: Wed Aug 19, 2015 11:08 pm
by phrusher
rimai wrote:Yeah, we may need to replace.
Any progress on the new batch?
Posted: Thu Aug 20, 2015 8:36 am
Huh.. Totally missed this :(
I'll work on this.
